Dear Rusty, first I want to thank you for what you do,I have a 65kp65ws500tv, for the past 12 months, it has been acting up, first red line, than redish pic ! I was on the way to the store to buy a new TV, (not to mention that I live in thecaribbean, and shopping is a different ball game !prices etc...)but I wanted to believe that something could be done !I than went on the internet, put a quick search phrase, and I got to Fixya, than to you. I than find out that this red line and redish pic, was kind of commun ! your email pop out, I follow the intrction (10min) than turn thatlittle bottom left nub, first the color came back to normal, than I check the red line, they were still there, so I turned slowly a bit more, and than gone ! That's it, the TV has its colors back, hope it will last a bit ! Thanks a mil, that was pretty good ! I have few questions: 1.Is there anyway to adjust pic focus, I won't says that it is bad, but seems like it could be a bit better ? any other tips ? 2.When I srtaed the TV (cold), the pic is only showing on the 2/3 top of the screen, and than slowly take the all screen, that will take about 1 or 2 minutes ? I try to restart TV after red line adjustemnet, it didn't do that, but TV is worn ! I will see if that happen when TV is cold again ! any tricks about that one ? Thanks Philippe
  • caicosadvent May 25, 2009
    I am not sure what is the "convergent" board but it seems like they are ekectric scomponents to be change ! I got to say that the focus is fine after all.
    The only other siyuation I am having, is smaller pic when I start the TV.
    If the Tv is cold, like in the AM, when I start it, the pic is about 2/3 of the screen from the top, and than after 1 or 2 min it fill up the screen.
    After that it is fine ! is there some adustment somewhere, or anything I should worry about ?
    Any help
    Thanks
    Philippe
    Sergeant:
  • 326 Answers
Actually it is nothing to worry about this problem.but still if you want to get rid of this problem.there is a solution.that in the tv on all the electric boards.there are minute components .the soldering of that minute components gets bit loose.so just dry solder all the boards.so all the componets gets tight soldered.in dry solder you dont have to solder each and every minute component.the hot soldered air comes from the machine.you just have to apply that hor air on the circuit boards.many users who dont have dry soldering machine apply hair dryer in place of dry soldering machine.the effect will be one and the same.but in hair dryer you will have to apply it for bit more time.
but as per the situation.if you dont try all this then also its normal at present.and nothing to do worry.as this are climatic problems.it vanishes as the climate changes.for example --- in winter it comes ,in summer it goes.
thanks.
please do rate the solution.
Posted on May 25, 2009
    Novelist:
  • 130 Answers
To adjust the focus manually there is no such buttons.but on the convergence board there are two IC  on the board.the number is  392k------ 100/150/180.any one it can be.there are two such ic on the convergence board.if any of that is going weak the focus gets misallighned. the cost of the ic is bit negligible.its $10 for per ic.and you can get it at  www.radioshack.com
and very much thaks for keeping updated,thank you for using fixya.keep updated.and please do rate the solution.thank you for appreciation.
Posted on May 24, 2009
Brakes seizing up after 10-15 miles
Do you live in a rusty climate? You don't say what car or if it's front or back, but rusty parking brakes that don't release is a common problem. Also, brake lines CAN have a little pinch/break in them that make them act like a valve and you step on the brake and push fluid down, but then the 'valve' closes and the fluid can't be released back and release the brakes leading them to grab/overheat.
Dec 29, 2017 | Volvo Cars & Trucks
DOTS pattern and WHITE LINE along the page
The Problem is your Copy Print Module it has a scracht on it if you replace the module it will desapear the dots and lines.
Nov 26, 2009 | Xerox DocuColor 12 Printer
Red Line, intermittent
Dust will not ever cause that problem.
It sounds like your driver board/assy boards/video board inside maybe faulty or the cables have come loose.
The driver board/assy boards feed the display panel with the images.
The video board decodes the input signals, when you say its intermittent I wouldn't say it was the panel more the video board or the driver board/assy boards.
Just call the manufacturer and they can get a service engineer out to resolve it or get a replacement organised for you with the manufacturer with no problems as you are still within your 12 months warranty period.
Thanks
Oct 01, 2009 | Televison & Video
Red Line on the left side of the screen
This is a serious problem, you have to call SS right away since it is in warrantee. They need to check whether the panel is defective.
Aug 13, 2009 | Samsung PN42A450 Plasma TV
Line red,yellow,green are all over picture and images
No you will need to replace the Convergence Ics and possibly some of the 12 feed resistors. You can get the repair kit for your model at the following link which contains both cinvergence ICs and all 12 resistors plus free instructions with pictures so you can do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
May 25, 2009 | Philips 60PP9202 60" Rear Projection...
S3601 Power Cord Mainspring Has NO Tension.
cord reel assembly maybe the spring jumped one time over out over 1 of the confirmationpoints of the reel assembly or the roller on the shaft is worn something is broken on the shaft and or mounting points that it tilts and walks somewhere against, sometime its better to get out the spring of the unit instead of repair because of the costs.
Jun 15, 2017 | Hoover Powermax S3601 Bagged Canister...
Sanyo Bravo
check if its on all the video sources. check it on dvd if its there then contact the customer care
Jan 07, 2009 | Sanyo DP32746 32 in. LCD Television
Fuel line leak on 1994 toyota camry
stell line front to back you can put high pressure rubber line but mush more expensivedont remove the old one tie rap the new line to the old line if you remove thr line sometime other start to leak brake line are very close if gas line rusty brake line are rusty too hope it help fixya our post thanks pierre
Jul 16, 2008 | Toyota Camry Cars & Trucks
Insignia 32-lcd black screen and thin colored lines vertically
Most likly the signal connector is loose or dirty. (input) this would cause the red, gree, blue or a combination to not be connected.
Mar 22, 2008 | Insignia IS-LCDTV32 32 in. Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
