Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet ht, motor running but nothing happening, says 48 mins to go, cancel does not work. Have unplugged but will not reset. Left over night unplugged, stiil not reset. Cannot open door to even get clothes out.
  • steve
    steve May 11, 2010
    Check the belt.
Our Duet washer (5 years old) would not pump the water out, and would not spin. It displayed no error codes. Tried reset, would cancel but still not work. I started disassembly (found the Whirlpool maintenance/ repair manual on line to refer to); everything seemed to check OK. Cleaned filter, fortunately the washer sits on a pedestal drawer as the washer had at least 3 gallons of water in it I had to drain into a bucket. As I went through the diagnostic test sequence found in the repair manual it was apparent that although the pump had power and made noise, no water pumped out. I removed the pump assembly and found the remains of a small plastic baggy fouling the pump impeller. It was left in a clothes pocket and run through the washer. No idea why the filter basket didn't stop it. Pulled baggy out with needle-nosed pliers and presented it to my wife (her baggy). Reassembled and all works great. No cost, actually made 1 cent on the penny found in the filter basket. You need a Torx screwdriver to access most of the panels. Reason for not spinning was the massive weight of wet towels and water sitting in basket.
Posted on May 24, 2009
I have the f13 error, on whirlpool duet ht, 9150. I have removed the top and I'm trying to run a drain and spin. The motor seems to work fine as it cycles through all four steps, but never seems to...
F13 codeindicates that the dispenser motor is not able to be driven to it's properposition.
*Check mechanical linkage from the dispenser motor to the top of thedispenser.
*Check wire harness connections to the dispenser motor and CentralControl Unit (CCU).
*Check the Dispenser Motor.
Toremove the error display, press Pause/Cancel twice. IfPause/Cancel does not work: *Unplug washer or disconnect power for oneminute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start. Hopethis helps.. Good luck! :)
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open
Try pressing PAUSE\CANCEL . if it doesn't work , unplug the washer and wait 5 min before plugging it back in . It should reset it.
Mar 15, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
F 01 code comes on when trying to start another load. Pushed the cancel button and the machine shuts off also tried unplugging it and that does not work either
F1 error means a communication error, if you unplugged it, for more then 2 mins that should have work, but you also have to verify ccu operation by running a diagnostic test
Jan 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool Duet HT Washer
I guess electric door lock just stacked. To prevent door breakage call to your local appliance repair company.
_______________________________________
http://www.allstarsappliance.com
Aug 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock is on, how do I reset the machine?
Press and hold down "end of cycle" button at right side of panel for 3 - 5 seconds. This is the child lock feature, do it again and the machine locks.
Dec 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
236 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
