Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Energysaver 403 ft Rinnai
Hi
Our heater has come up with E:05 which says the the burner is extinguished, how do we re light the burner??
  • 1,420 Answers
This is a New Zealand model. There is no pilot to relight, the unit will cycle again when you stop and restart the unit. You will need to find out why you are getting this code. I would check out the venting system for blockage. Make sure you are getting gas. You may want to take off the front panel and look into two small rectangular holes covered by small metal plates to see if, in fact the flame is starting then stopping. I have seen many of these with spider webs inside the gas train and burners not allowing the heater to start.
If you can get to the backside of the heater, you will see a rubber hose about 1" (US) in diameter. Remove it from the vent and see if the unit ignites. If it does, this indicates blockage in the outer vent passage.
If not, you may need to contact a technician to investigate your issue.
Posted on Nov 02, 2007
Rinnai energysaver 551 ft starts but won't stay running
Those water heaters are very sensitive to flow rates. The service manual appears to be here: http://rdjxmmyvbu.blogcu.com/rinnai-551f-service-manual/13623970
But there is no guarantees
Jul 24, 2016 | Rinnai Heating & Cooling
Rinnai energysaver 556f manual
Here is a link to the 556FTR from Australia.
They are all pretty much the same. The US site has similar info. Just google Rinnai. Open the site, go to resources tab and click downloads. The manuals are easy to locate.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/556&431FTR.pdf
Jul 27, 2010 | Panasonic Heating & Cooling
When heater first turned on light is green then turns red
Yes this is OK. The green light is showing you that you have power. When the light goes red it means that the burner is alight.
Cheers
May 03, 2010 | Rinnai EnergySaver 556 Air Conditioner
Where is the pilot light on Rinnai EnergySaver 1001F
If you smell gas in a Rinnai you have a big issue. This heater is what is called a direct vent heater with an electronic ignition so the combustion chamber is sealed and the smell of gas is an indication that you have a gas leak. Please call a professional today.
Oct 13, 2009 | Rinnai Heating & Cooling
Energysaver 1004FTR
Check for a blockage in the heat exchanger. Spiders love to make nests in these units. Remove the front cover and the two rectangular viewing ports on the front of the heat exchanger. Watch as the unit ignites. There are three burners you need to watch and the first one is in the center and hard to see. If there is flame but it goes out quickly, you have a blockage in the unit. Check the venting to make sure it is clear of debris.
Aug 19, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Energysaver 403 FT
I may not be much help here in the states but if you have the owners manual you will find a page that will tell you what the error code represents. Not knowing and unable to find the NZ error codes, most likely it represents a flame failure. You will need to remove the front cover and inspect the flame as it starts. If it starts and goes out quickly, you may have debris attached to the flame rod not allowing it to get the proper signal. Or you may have a spider web in your burner. These units are not eazy to repair and I strongly suggest you call a proffessional. Sorry.
Jun 29, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 403 FT
who did you talk to at rennnai?
let me know i deal with them on a buisness leval.
Mar 27, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
226 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
