Question about Dell Inspiron 1525 Notebook
No internal hard disk found during booting when i am going to format
I have a dell 1525 laptop. when i buy it. it contains two hard disk partioned. one is 220gb and 2nd is 10 gb. now i want to create partion of it. when i want to partion it. it says during booting no internal hard disk found. and i am unable to partioned it...............
  • Rashmikiran Pandey May 24, 2009
    yes when i go to format my system with f12 with the windows vista cd. it shows hard disk. but i cant partioned. and xp cant support.........
  • Edwin Meyer
    Edwin Meyer May 11, 2010
    If you enter the bios (either f2 or f10 upon boot) does the drive show up in bios?
  • 4 Answers
It is possible that the HD has failed completely. However, this is a relatively new laptop, so I would suspect that is not the case. Sometimes the HD will lose contact for one reason or another. This can usually be cured by removing the HD and reinstalling it, which will remove any crud from the contacts.
http://www.fixya.com/support/t1639067-reseat_hard_drive
If the machine is still under warranty, call Dell support. They will walk you through diagnostics to determine the actual problem.
If you're not sure of the warranty status, go here:
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/details?c=us&l=en&s=gen
HTH
Posted on May 24, 2009
I have reseated the hard drive in my inspiron 1525 laptop and it still says internal hard disk drive not found. what can i do?
You might need to borrow another hard disk drive from your friend or relatives and try it on your laptop. If it still does not work, then we can assume that the laptop needs repair with the hard disk drive port.
Hope this helps in resolving the issue...
Sep 12, 2011 | Dell Inspiron 1525 Notebook
How to remove the unmountable boot volume 1525 dell inspirion be cuz i have the blue screen, try go to the safe mode but freeze after it shows all the hard drive data its a stand still
if you can boot normally i suggest going to filehippo.com or cnet and download a free disk partioner and it will remove the boot volume for you. under run, msconfig, there is a boot option select the boot mount you want that may fix it let me know
Mar 15, 2011 | Dell Inspiron 1525 Notebook
I have a two-year old Dell Inspiron 1525 laptop. for no apparent reason, it will now not boot up. When I turn it on, I get the following message......"Internal hard disk not found. To resolve this...
The hard drive may have failed or a virus has corrupted the Cmos data.
Try entering the BIOS and checking that the Cmos recognises that the hard drive is there. If it doesn't, remove the hard drive and re fit it, booting up again.
Dec 27, 2010 | Dell Inspiron 1525 Notebook
Dell sold me on a partition for my hard drive, but now the C-drive is full and D-drive is virtually empty. How can I increase the size of C at the expense of D?
The only way to adjust the size of a partition is to reformat the hard drive. You might be able to move some files and programs from C to D to free up some space on C, but that's pretty much your only choice.
Dec 15, 2010 | Computers & Internet
As soon as I turn on my laptop a message says that the internal hard disk drive was not found and that I should reseat the drive.
Yes that is the first thing your should try.
When the computer cannot detect the hard disk or a boot disk then you get this error message. Please click on this link to determine the fault and solution to this problem :-
http://www.fixya.com/support/r6244569-no_bootable_device
Oct 18, 2010 | Dell Inspiron 1525 Notebook
Have a Dell Inspiron 1525 laptop and every now and then it is shut down for no reason with this message on the screen: internal hard disk drive not found To resolve this issue, try to reseat the...
The link below is supplied by Dell, for checking Hard drives on Dell machines, try this.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=126A722713F6D0D0E0401E0A55174AE6
Aug 04, 2010 | Dell Inspiron 1525 Notebook
How do i wipe my laptop
get your operating system cd go into the setup make shure the computer is set to boot from the cd drive..insert the cd..reboot the computer follow the on screen directions..make shure you delete the partion and recreat before you format and reinstall..
Oct 11, 2009 | Dell Inspiron 1525 Laptop
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Formating the hard disk partition
Hi
install ur o/s cd
then select or allocate
partion
Thanks
Mar 27, 2009 | Dell Inspiron 1525 Notebook
Reseat the hard drive
shut down the laptop.
then, disconnect the laptop power, and battery.
remove the harddrive, then connect the harddrive firmly back into place.
reconnect power/battery and boot.
Mar 25, 2009 | Dell Computers & Internet
Dell Inspiron 1525 Notebook Logo
313 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
