Question about Wolverine (2100) 100 GB Hard Drive
Not enougn power
After using the dual USB cable the drive does not have enough power.  How do i get more power into the drive so it will run properly? when i plug both usb cables in....it is not enough power to run the drive. What do i need to do to get more power?
    Brigadier General:
  • 6,966 Answers
The limitation is actually imposed by the circuitry of the PC as supplied to the individual USB ports.  What you probably need is an externally powered USB HUB.  You will have to determine how much current your drive draws. An example of a max 1 Amp @ 2X500ma/Port is "7-port USB 2.0 hub" [AP-HUB207]. You can check out the specs here > http://www.mittoni.com.au/usb-20-powered-7port-hub-p-1920.html
Hope this be of some help/idea. Post back should you need additional information.
Good luck and kind regards.
Posted on Oct 20, 2007
When i connect my portable hard disk to my pc...its simply not getting detected....
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. If you received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 07, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I followed the instructions on the quick start sheet but do not see the simpletech external drive icon on my computer.
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the USB. If you received a cable with a split dual USB plug for extra power make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 05, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Hi.. i need help.. my external hdd transcend store jet 320gb have problem... when I conect HDD to pc blue led blink just one time and hdd stop working..
Check that the USB cable can provide enough power to the hdd. Check that the USB port is powered. Older USB slots may not have enough power to run larger external HDDs, there you may require separate power to be plugged into the hdd. Are you using the original USB cable provided with the external HDD?
Feb 28, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
My Lacie Rugged 500 US/400/800 drive ejects automaticaly. It show connected in system profiler, but not in disk utility. when i disconnect and reconnect, it shows on desktop only after doing so 3-4 times...
It may be the cable that you are using to connect it to your computer. Are you using a USB or Firewire cable to connect? To me it seems like the cable may be damaged, and that it why it disconnects after a few seconds, like it is not getting enough power to run the drive.
If you have one to hand, try another cable. or if you can try a different type of cable (if you are using USB at the moment, try a firewire)
Also, (I have the same drive) if you are using it with an USB cable you will need the power usb adapter plugged in as well as this drive does not get enough power from a single USB cable.
Hope this helps.
Feb 08, 2011 | LaCie Rugged All-Terrain (301017) Hard...
I lost mi cable
http://www.grabcart.com/product/comp/harddrives/cbbstore7292/USB-Cable-Dual-Power-2-x-Type-A-to-mini-B-USB-2-0-1m
USB Cable Dual Power 2 x Type A to mini B USB 2.0
Jul 26, 2009 | Maxtor OneTouch III Mini Edition 120GB...
I have lost my power cord to my LaCie DVD+RW Dual Layer....
Here is the PDF Users Manual for the LaCie DVD+RW 301230U
external optical drive,
http://www.lacie.com/download/manual/portable_dvd_sh_en.pdf
(Give it at least 10 seconds to download)
Should the direct link above not work for you, you can download the Users Manual from here,
http://www.generalmanual.com/Disc-Burners/LaCie-301230U-Portable-DVD-RW.htm
Go down to the bottom of the page, and under the green -> Download Now <- heading, click on -> User Manual
The reason I posted the link to the User Manual, is that you can use a USB to USB cable for power. You plug one end of the USB cable, into an available USB port on your computer, and the other end, into the LaCie DVD+RW external optical drive. (You need two available USB ports on your computer. One for power, and one to connect the LaCie external optical drive. This USB cable, is called an Interface cable)
The USB end, that goes into your computer, (Laptop or Desktop computer), is the USB A style end. (Male) This is what it looks like,
http://en.wikipedia.org/wiki/File:USB_TypeA_Plug.JPG
The USB end, that plugs into the Lacie optical burner drive, is a USB Mini-B style end. (Male) It looks like this,
http://en.wikipedia.org/wiki/File:USB_types_2.jpg
It is the second one from the left side.
Where I'm at, we have Walmart stores. At Walmart they sell a USB adapter kit, made by Philips. This kit has a USB A to USB A cable, that both ends are Male. This cable is on a little retractable reel. The reel is about the size of a USA fifty cent piece. In the kit are five different styles of USB adapter ends. They just plug on that USB A to USB A style cable. (On the small reel) One of those adapter ends is a Mini-B USB male end. It has a Female USB A socket on one side, and a Male USB MIni-B end, on the other side. The kit sells for about $12 dollars.
Should you find that somehow, this USB power cable does not give enough power to your LaCie external optical burner drive, then here is LaCie.com, Products, Support & Downloads, and the Power Supply, for your LaCie DVD+RW 301230U external optical drive,
http://www.lacie.com/us/products/product.htm?pid=10715
May 15, 2009 | LaCie (300776EK) DVD±RW Dual Layer...
Lacie Silverscreen 80Gb Drive not recognised by My Dual Processor PC
Sorry for the late reply, but it may help someone else with the same problem.
Are you using a USB2 port, perhaps it's may not be getting enough power. In the orginal Lacie box was a double USB dongle - it allows you to take the power from two USB ports and send them to the Silverscreen, if the SScreen was getting quite enough power.
Or buy a double USB power cable (like: http://www.n-c.fr/webshopncrevendeurs/catalog/images/Double_Cable_USB.jpg)
Otherwise remove the 2.5" disk (remove two screws, & gently pull out) and use a caddy to check the HD disk is still working.
Aug 10, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
Failure to read USB connected storage drives
What I have seen with some computer models, is that the USB port cannot deliver enough current to run some devices.
If possible, use an external drive with its own power supply and see if it will work. Most likely it will.
Also, try a powered USB hub. I found that most of the time, a powered USB hub solved many problems with having enough power for some external USB devices.
Jerry G.
Jul 26, 2008 | Apple iBook G3 Mac Notebook
WD Passport Portable Hard drive 250GB
It could be that your computers do not put out enough power in the USB ports. (Apple laptops are notorious for this). You can call up Western Digital and tell them that it is not working and they will send you a free dual USB cable. This cable has one plug for usb power and one for data so the drive should work with it (although it will use up 2 of your USB ports!!).
Mar 05, 2008 | Western Digital Passport WDXML800UE...
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Wolverine (2100) 100 GB Hard Drive Logo
120 people viewed this question
Top Wolverine Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wolverine Computer and Internet Expert? Answer questions, earn points and help others
