Question about Mitsubishi VL-2000 TV
Dash lights not working on 54 plate l200 animal?
The dash lights dont work on either the main dash panel or the small one with the angle ball,outside temp and voltage meter on it.
Although they do work along with every thing on the main dash.
i dont think its a dash bulb as both these units should be lit up (i THINK? as just bought the vehicle and dont know what lights up and what doesn't.)
  • 63 Answers
Hi, Check if you have a dash adjustment.
I have a 2010 L200 and the light level adjustment for my dash, is the same button to reset the trip odometer.
Gently twist the knob you would use to reset the trip and see if that helps.
If not, you may need that repaired.
Ryan - Worldhosted
Posted on Aug 23, 2010
My rear wiper, defroster and licence plate lights stopped working on my 2007 suzuki swift but when I open the rear hatch the licence plate lights come on . Any ideas what's wrong?bad ground?
[PDF]Wiring Diagram.pdf - Ken Gilbert
ken-gilbert.com/wrx/mans/99.../Wiring%20Diagram.pdf
Each connector number shown in the wiring dia- ... Rear defogger cord (Ground). Fuel tank cord,. Roof cord, ... circuit. Then check the switch, relay, fuse, ground, etc. 4. .....Rear wiper motor. Rear wiper ... License plate light RH. Tail light LH.
#? license plate light - Circuit Wiring Diagrams
circuitswiring.com/tag/license-plate-light/
2008 Volkswagen Newbeetle Main Fuse Box Diagram 2008 Volkswagen Newbeetle ...Parts: rear window defogger, shift lock, battery positive voltage, interior light, A/C clutch, ... brake light, daytime driving light, wiper and washer system, vacan, fuel pump, central ... 1997 Suzuki Geo Tracker Left Dash Fuse Box Diagram.
#? license plate light - Circuit Wiring Diagrams - Page 3
circuitswiring.com/tag/license-plate-light/page/3/
Audi A4 Engine Fuse Box Diagram Audi A4 Engine Fuse Box Map Fuse Panel ... mirror control, wiper, washer, horn, brake light, cruise control, heated rear window, ... 2003Suzuki Aerio Dash Fuse Box Diagram 2003 Suzuki Aerio Dash Fuse Box ... rear defroster, fuel injection controller, radio, A/T controller, hazard light, ...
Jan 05, 2016 | Suzuki Cars & Trucks
No ac no heat no power to the to or maybe from the dash control panel
There are 6 bolts that hold the rear trunk panel on the trunk itself: 4 behind the license plate on the outside of the trunk and two inside the trunk panel trim.
1. Remove the license place from the DeVille rear trunk panel.
2. Remove the 4 bolts located below the license plate.
3. Remove the trunk panel (felt) trim inside the trunk.
4. There is a small bolt on each side of inside trunk panel (4mm I believe). Remove them. Each will have a rubber washer on them so you'll know you are removing the correct bolt.
5. From the outside of the trunk, lift out the rear trunk panel. The license plate light (and reverse lights) are removed by turning the light assemblies counter clockwise.
Aug 27, 2013 | 1997 Cadillac DeVille
Rover 25 dash lights not working
Have you checked your fuses? This is the first place I look when probs with dash/lights come up. Daddy taught me well. Another excellent source of troubleshooting and repair is a Chiltons/Haynes repair manual for your make/model/year vehicle.
Dec 21, 2011 | Cars & Trucks
Dash lights dont work on my 97 blazer
All lights, or just your illumination lights? Illumination: bulbs need replacing. All lights; SERIOUS problem. There is a dash panel fuse on car. check that. Has anyone done any work recently under dash( like installing a radio)? May be they accidentally pulled a connector loose behind dash. Need to pull your instrument cluster to check that. Usually two big connectors with lots of wires going to back of instrument cluster. If no power at all with key on: check under hood at power distribution center for a main big fuse out.
Oct 12, 2011 | 1997 Chevrolet Blazer
I don't have any running lights and a few dash lights are out also. Where is the fuae panel for these ?
The majority of fuses are down by your left knee, up under the dash. Don't expect to tell good from bad by looking, use a meter. What do you mean by Running lights? The bulbs outside of the headlights? The tail lights (not brake lights)? License plate light? Those are all three on the 10a Tail fuse. But they often blow out, as they flash with the alarm system too.
dash lights are almost all on the same fuse, think it is labelled illumination. The small lights that light up the heater control knobs have been a pain for me, and they are expensive. I put in LED bulbs (triple bright), and they are finally lasting.
Aug 04, 2011 | 2006 Toyota Tacoma
Cant get main beam on only sidelights or full beam.i have a 54 plate vw polo
renew the stalk control ,the switch is on the dash i know on this car but the dip/beam control is on the steering column and this is my main suspect as being faulty unless both bulbs have blown at the same time ,dont laugh have had it happen before now
Dec 12, 2010 | Volkswagen Polo Cars & Trucks
Dashboard lights dont work fuses appear ok but dont know which fuse controls dash lights
The parking and tail lights are usually on the same fuse as the dash lights so if the outside lights are working it sounds like the instrument dimmer control has failed. The electronic bits inside the control for these lights sometimes go faulty. A temporary fix is to remove the wiring plug that attaches to the back of the dimmer control and put a jumper wire across the terminals. If dash lights then work then replace dimmer control.
Oct 21, 2010 | 2000 Toyota Corolla
2000 honda accord coupe when i turn on the running lights they dont work, but when i click it to the headlights those are fine, where would the fuse be? under the dash? not sure where it is at all...
Your park light fuse is blown. It is in the fuse panel that's accessible with the passenger side door open (side of dashboard), labeled something like "license plate and small lights".
Oct 19, 2010 | 2000 Honda Accord
Televison & Video Logo
340 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
