Question about GE GSH22SGPSS Side by Side Refrigerator
Frost free failure on a GE fridge. Removed access panel to freezer section to find evaporator coils crusted in frost. Cannot locate defrost timer and cannot locate any repair manuals online. I'm not working so I just assume fix this myself (or at least try). Thanks for your help.
  • GE Master
  • 3,361 Answers
The defrost timer is electronic and built in to the main control board on the rear of the box.
The defrost heater and defrost thermostat are the most likely culprits on this brand.
They are in the freezer above and below the coil.
They usually come as a set.
Posted on May 24, 2009
My freezer (upper) works but my fridge (lower) doesn't. There's nothing clogging the vent. What could be the problem? Thank u!
My fridge is running but not cold enough: Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and are not torn or ripped. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the f
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some are behind the cold control cover. Once you locate the defrost timer, slowly turn the screw likeknob in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater (s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can continuity test the defrost heater for continuity or test for 120 volts to the heater(s). If you have no power to the defrost heater (s) you can also bypass the defrost thermostat to see if the defrost heater will come on, jumper the wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater (s) and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
bobicehouse_88.jpg Defrost timer
bobicehouse_89.jpg Defrost thermostat
bobicehouse_90.jpg Defrost heater
Sep 11, 2011 | Sharp Refrigerators
I have a GE Profile French door. Mod pfs22sisbss. It is not cooling enough to keep the programed temp for the fridge or the freezer. I tried using the turbo feature and I can hear a clicking sound and then...
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly.
* Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working.
* Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover.
Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer.
Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Hope this help in solving the problem....
Feb 03, 2011 | GE Refrigerators
Coils frezzing up refridgerator notworking
Refrigerator not working is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly.
Step 4 - Volt Test
Hope this helpout in solving the problem...
Oct 02, 2010 | GE Refrigerators
Ge tfx 22krdavw refrigerator not cooling
Step 1 – Find the Problem
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
Step 3 – Find the Timer
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
Hope this helpout.....
Aug 08, 2010 | GE Refrigerators
My LG side by side frig. is not cold enough
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it.
*One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Good luck
Aug 01, 2010 | LG Refrigerators
My fridg is not cold enough
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem. Example picture one, example picture two, example picture three. System problems may be a leak in the refrigeration tubing, an inefficient not 100% pumping compressor.
Hope this helps...
Aug 01, 2010 | Refrigerators
GE side by side unit. Freezer OK, fridge
Step 4 – Volt Test
Hope this work.....
Jul 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer works, but the bottom of the refridgerator does not keep food cold.
Step 4 – Volt Test
Hope this help
Jul 27, 2010 | GE 17.9 Cu. Ft. Frost-Free Top-Mount...
Does not get cold
I'm not sure if you mean it's not getting cold enough or dot at all.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. If there is a lot of build up then the defrost timer may need to be replaced.
Most of the time the evaporator coils and fan are located behind panels in the freezer section. These are usually easy to remove. The defrost timer is a different story and may require the help of a service person.
Hope this helps.
Sep 14, 2009 | Frigidaire FRS26R4A Side by Side...
Not getting cold
Would also appreciate if you could provide us the model number of your fridge so that if the above solution does not resolve your issue would look into the matter specific to your type of model.
I am sure this solution would help you to resolve the issue.
God Bless
Jul 13, 2009 | Whirlpool Refrigerators
GE GSH22SGPSS Side by Side Refrigerator Logo
489 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
