Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
The computer detect at the moment if connect the cable but not appear in my computer and is not possible serch the files in a hard drive i have information vary important
  • 53 Answers
Have you checked to see if it shows up in disk management? Go to control panel, Administrative Tools then computer Management, go to Disk Management under Storage.
It should show all your drives and free space etc.
A raw drive may need to be formatted, but you are saying this has info already on it? Was it connected to another computer then when info put on it? Try it again with the other computer to see if it shows. Its possibly damaged. Do you remove using safely remove hardware tab? They can be damaged from just disconnecting physically. Also try all USB ports. Let me know what you find.
Posted on May 24, 2009
    Scholar:
  • 57 Answers
Check in your device manager to see if it is showing up there.
You can try the software (free) at this link
http://download.cnet.com/Data-Recovery/3000-2094_4-10664893.html?tag=mncol
This software will attempt to repair MBR, And FAT (Master boot record, and File allocation table)
5kpl-vm asus mother board not detected new sata segate HDD how to resolve
The BIOS does not detect or recognize the ATA / SATA hard drive Tips and tricks for troubleshooting a Serial ATA or ATA/IDE internal drive that is not detected in the BIOS.
There are six main reasons why a system BIOS will not detect the presence of an internal hard drive. Here is a list of them. They are not in any particular order, but you can follow these steps one by one to troubleshoot this problem:
  1. Drive not enabled in the BIOS
  2. Serial ATA drivers are not properly installed
  3. Faulty or unplugged data cable
  4. Drive is not spinning up
  5. Incorrect jumper settings on the drive
  6. Faulty hard drive
Note: Sections 3, 4, 5, and 6 pertain to PC or Mac systems. Sections 1 and 2 pertain only to PC systems.
For more detailed step-by-step troubleshooting on this topic, please see the Seagate Serial ATA troubleshooter "Drive Not Detected" section.
After verifying that your ATA or SATA port is set to Auto-Detect or is enabled, if you find that your disk drive is not being detected (auto-detected) by the system BIOS, try the following steps to try and isolate/troubleshoot the problem.
  1. this link can be useful.
    System setup is where the date and time are stored and where startup preferences like NumLock or Passwords are defined. In addition, many hardware settings are defined in System Setup.
    In particular, hard disk drives are often controlled here. At the simplest level, hard drives are numbered in Setup as Drive 0, Drive 1, etc or sometimes as Primary Master, Primary Slave. Which ever way these are named, they have a basic ON / OFF setting (sometimes AUTOMATIC or something similar). If your drive is not detected it may be because it is turned OFF in System Setup.
    In most cases, the boot drive is Drive 0 or Primary Master. When you add a second drive to the system, it may be need to be enabled by turning it ON in System Setup.
    Sample screen shot showing a Dell System Setup section for disk drives:
  3. To be able to hit the F6 button, you must restart the Setup process, and watch the bottom of the screen after pressing Enter on the "Welcome to Setup" screen. There will be some moments of files being loaded, and then you should see a message appear that says "Press F6 if you need to install a 3rd party SCSI or RAID driver". This message will only stay on the screen for a couple of seconds, so press F6 as soon as you see it appear.
    (Click to expand)
  4. After this is done, you will see other messages appear, and it will act as though nothing is happening, but eventually a screen will appear that will allow you to install the drivers for the add-in SATA controller. The screen will look like the sample below:
    (Click to expand)
  5. After you press S, the driver install process will continue and the floppy diskettes will be needed. Further instructions will be furnished after the driver install process has ended.
    (Click to expand)
  6. Insert the floppy diskette containing the drivers for the add-in Serial ATA controller.
  7. Once the drivers are loaded, proceed with the normal Windows XP/2000 installation.
A few further notes on the driver diskette:
For the hard drive to be detected in a new installation, the drivers for the add-in SATA controller/motherboard must be loaded at the beginning of installation.
The drivers for the controller/motherboard can probably be found either on the CD that came with it or on the manufacturer's website. These drivers do not come from Seagate; they come from the motherboard manufacturer. Simply load the required drivers on the diskette and have it ready.
  • Document ID: 182453.
    Here are some images of Serial ATA cables. Click to expand.
  • The BIOS will not detect a hard disk if the data cable is damaged or the connection is incorrect.
    Serial ATA cables, in particular, can sometimes fall out of their connection. Be sure to check your SATA cables are tightly connected to the SATA port connection.
  • The easiest way to test a cable is to replace it with another cable. If the problem persists, then the cable was not the cause of the problem.
  • For ATA drives, Seagate recommends using UDMA cabling with a maximum length of 18 inches. UDMA cables have color coded connections which require proper orientation when connecting.
    • Blue connector - always connects to the motherboard.
    • Grey (middle) connector - is used for slave devices on the cable.
    • Black connector - is used for master device connection.
    See this image:
    (Click to expand)
  • to determine whether it is providing sufficient electrical power to operate the drives and devices you have in your computer.
  • If the drive is still not spinning, connect it in another computer if possible.
  • Connect the drive in a SATA-USB enclosure or something similar if possible.
  • If the drive does not spin up after all of these steps, please visit the Warranty page to begin a warranty replacement order.
  • 48-8s.jpg -- (Click to expand) Jumper settings for Seagate SATA drives
    -48-9s.jpg -- (Click to expand) Jumper settings for Maxtor-brand SATA drives
    ATA: It is recommended that all Seagate ATA hard disks supporting the Cable Select jumper option be configured as Cable Select. If your computer system was built prior to October 1998 and does not support UDMA 66 or greater you will be required to use the Master/Slave jumper settings.
    -48-10s.jpg -- (Click to expand) Jumper settings for Seagate ATA drives
    -48-11s.jpg -- (Click to expand) Jumper settings for Maxtor-brand ATA drives
    When using Cable Select jumper settings on your ATA drive, all devices connected to the UDMA cable must also use the Cable Select setting. The cable decides master/slave device detection when the cable select jumper settings are used.
  • SeaTools for DOS (see the tutorial here) to test the drive. If SeaTools does not detect the drive after the steps followed above, or an error code that signifies drive failure displays, please proceed to the our Warranty Services page to begin a warranty replacement order.
  • The BIOS does not detect or recognize the ATA SATA hard drive
    May 08, 2014 | ASUS K8V-MX Motherboard
    Imation 1TB USB external Hard Drive .....unrecognized in Windows Both in windows7 and XP.
    External hard drives are plug-and-play devices used to store music, video and data files. Once the drive is connected, the computer checks its systems for the appropriate drivers, loads them, and the external drive is ready to use. If the computer does not recognize the external drive, plug it into another computer to ensure the drive is not corrupted. If the drive is good, a few simple steps should help re-enable the drive for use.
    Switch the power button to "off." Disconnect the power cord from any extension cords or power strip, then re-seat the power cord into the hard drive. Connect the cord directly into an outlet and power up the drive. If the drive is powered and still not working, check the data cable. Power down the hard drive and disconnect the data cable from the computer. Wait 30 seconds to one minute. Reconnect the data cable and power up the drive. If the drive is not detected, power down the hard drive and connect the cable to a different port. Power up the drive. If the drive is detected but not working, check for a missing driver. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Disk Drives." Right-click the yellow exclamation point and install the missing driver. Close the Device Manager. If the drive is detected but not working check to ensure it has an assigned drive letter. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click on the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Click on "Disk Management," right-click the external hard drive, click "change drive letter and path," and click "Add." Assign a drive letter. Avoid using A, B or C (C is usually assigned to the computer's internal hard drive). Click "OK" close the window. If the drive is detected but not working, check whether the drive is in sleep mode. Disconnect all devices connected by USB cables from the computer. Reconnect the drive's data and USB power cables directly into the computer. Click the "Start" button, right-click "Computer" and select "Manage." Enter your administrator password if requested. Select "Device Manager" and double-click "Universal Serial Bus Controllers." Double-click the first instance of "USB Root Hub" or "Root Hub." Check for the hard drive. If the drive is not visible, move to the next instance of "USB Root Hub." Continue checking each instance until the hard drive is located. Once located, click the "Power Management" tab and uncheck the "Allow computer to turn off this device to save power" box, click "OK," then close the Device Manager. Power the computer down, wait 30 seconds to one minute, and power the computer back up to ensure the drive is detected. Hope this helps.
    Jan 07, 2013 | Imation 1TB Cartridge (IMN27957) Hard...
    External drive not picked up on computer
    External hard drives not only provide additional storage space on a computer system but also allow data to be conveniently transported from one computer to another.
    These drives typically plug right in to a port on the computer and function without any additional setup; however, if you are running into trouble where your external hard drive is not being detected, you must troubleshoot the situation to determine why the drive appears to be missing.
    Check the USB connection running from the hard drive to your computer.
    If the USB cable is not seated securely in the port, the computer will not detect the external drive.
    Disconnect the USB cable from the computer and plug it into a different USB port. Occasionally, a USB port will fail to function with some hardware and changing the USB connection may correct this issue.
    Switch from a USB to a Firewire cable connection, if possible.
    The USB port on the hard drive may have died; if so, changing to a Firewire connection will resolve this issue.
    Install the driver for the external device from the installation disc provided with the product. Older computer systems may require you to manually install this driver.
    After inserting the installation CD, follow the prompts from the installation wizard to install the driver on your computer.
    Restart the computer.
    If you connected the external drive while the computer is powered down, it may not recognize the device when you turn on the computer.
    After restarting the computer, connect the external drive to the system.
    The drive should now be detected by your operating system.
    Connect the external hard drive to a power source and then plug it into your PC computer using a USB or Firewire cable.
    Log on to your PC computer using an account with administrative privileges.
    Open the Start menu and click on the "Control Panel" icon.
    Open the "Administrative Tools" folder and then double-click on the "Computer Management" icon.
    Select "Disk Management" from the list of options on left side of the window.
    Right-click on the drive you want your computer to recognize and select "Change Drive Letter and Paths."
    Select a drive letter for the external hard drive to be recognized as and click "OK."
    The drive will now appear in My Computer.
    Hope this helps.
    Nov 22, 2012 | Samsung G3 Station Desktop External Drive...
    A blue and red flashing light and won't connect to computer
    Hope this helps.
    Nov 22, 2012 | NexxTech new 3.5-inch hard drive enclosure...
    Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
    This is my suggestion for you to possibly recover the back up file in your external hard disk.
    Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
    Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
    Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
    Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
    How do i update my Archos 504?
    How to install firmware ..?(update)
    Step 1. Download the firmware to your computer-->click HERE to download the update file When you download the update file, your browser may warn you that the file 'could be harmful'. This is normal because browsers are not familiar with files that have a .AOS extension and suspect that they could be malicious. These files are not harmful to your computer.
    Step 2. Turn on your ARCHOS device and connect it to your computer with the USB cable
    Step 3. On the ARCHOS, choose to connect and wait a few seconds for your device to be detected by the computer
    Step 4. Copy and paste the downloaded firmware (.AOS file) to the ARCHOS device.
    • Case 1: logo_firm_hdd.jpg Your ARCHOS is detected by your computer as a Hard Drive (E: for example) in Windows® Explorer. Paste the update file directly onto the ARCHOS hard drive icon.
    • Case 2: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see just two folders Data and Media when you open it. Paste the update file into the folder called Data.
    • Case 3: logo_firm_g4.jpg Your ARCHOS device is detected as a 'Mobile Device' in Windows® Explorer (not as a hard drive) and you see Internal Hard Drive when you open it. Open this Internal Hard Drive icon and you will see the various ARCHOS folders inside (Video, Music, etc.). Paste the update file into this area but be careful not to paste it into any of the folders there.
    Step 5. Disconnect the Device
    Unplug the USB cable (for 'Mobile Device' connections) or use the "safe disconnect" green arrow icon (for Hard drive connection) in the system tray before unplugging the USB cable.
    Step 6. On your ARCHOS device, click on "Update Firmware"
    Click on the "tab" button to show the settings screen. Select the "System" icon and then click on the "Update Firmware" button. For the ARCHOS 104, 202, & 204, go to the settings and open the icon "System" where you can find the Update Firmware button.
    Dec 31, 2010 | Archos 504 500870 Digital Media Player
    Hard drive not detected what can i do
    If your hard drive is not being detected the moment you startup the computer, then try to turn it off and open the computer's casing. Pull the two cables connecting to your hard disk and wait for like 5 minutes before plugging the cables back to it. Then power it back and see if it gets detected. If not, then your harddisk might have failed. You might want to check it though thru the CMOS setup if the Seagate disk drive is still on the list of the Boot devices. If not, then you can do a data recovery by unmounting the harddisk from your computer and put it as a slave drive to another computer or to an external harddisk usb enclosure.
    Should you need further assitance, please let me know. Thank you for using FixYa.
    Dec 16, 2010 | Seagate Computers & Internet
    Olympus stylus 770 cable has problem transferring photos to computer. This only started month ago. Once connected to computer, camera screens reads 'one moment' but never actually connects to computer....
    Consider NOT connecting your camera to your computer.
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
    Oct 24, 2010 | Olympus Stylus 770 SW Digital Camera
    My maxtor D740X-6l 40GB drive will not boot up. I can hook the drive up to another computer and read the files but it will not even show as a drive on the original computer. The first computer recognizes...
    all you have to do is to simply set the jumper at the back of he hard disk, beside where the IDE cable and power enter into the hard disk.
    Just keep setting till you put at the right position where the system recognizes it.
    There is nothing wrong with your PC and hard drive, just set the jumper of the Hard disk and that should be all.
    Take care.
    Jan 04, 2010 | Maxtor Hard Drive
    My hard disk do not detects by the machine.
    Thanks for using fixya.
    If your computer doesn't detect the hard drive, its possible that:
    1. There is a problem with the data cable for the hard drive. Change the SATA cable or IDE cable.
    2. Power connection to the Hard drive might be loose. Make sure its connected properly.
    3. The hard drive may be bad already. The best way to find out is to try and connect it to a different computer.
    4. Its also possible that the port on the motherboard is already bad but this seldom happens.
    Jul 16, 2009 | Samsung (SP0822N) 80 GB Hard Drive
    SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
    159 people viewed this question
    Top SimpleTech Computers & Internet Experts
    Lyle Siemens
    Lyle Siemens
    Arora Singh
    Arora Singh
    Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
