Question about Goldstar LG LUCKY WG1800R Room Air Conditioner
Why will a room air conditioner ice up and can I fix the problem?
The room air conditioner ices up.
  • clown106 May 24, 2009
    It is older and in second story window. It cools real well, but ices up after a couple of hours. Can I cleam it from inside the house?
    President:
  • 1,902 Answers
Freon leak, How new is it. If you still have a warranty take it back and have them replace it. If it is not under warranty you can try a few tricks. Clean the outside coils with a strong blast of water with the unit off and make sure the filter is cleaned
Posted on May 24, 2009
Evervarator ices up
Posted on Jun 02, 2009
My air conditioner runs but it is not blowing cold air anymore. it is a Friedrich room air conditioner QStar. Help
1. check the filter and clean it while your at it. 2. check to see if it iced up and if so thaw it out and set the temp a bit higher. close all rooms not in use. my guess is it is iced up because of a dirty filter.
Jul 19, 2011 | Heating & Cooling
My air conditioner line is freezing and no air is coming out of the vents
Shut it down for a few hours and let it De-ice the evap coil is iced up/ check your filters and change them.. Oh to speed things up a bit. Just shut the cooling off and leave the fan on that will speed it up. You should see ice or condensate on the line. But set your stat to 74 and close doors to rooms not in use..
Jul 14, 2011 | Carrier 38CKC042 Air Conditioner
12000 btu air conditioner is brand new but ices up when turned on. Presently it is used in an attic room that is 15x15 sq.ft. Any suggestions/solutions?
thins that can cause an a/c to ice up
1 something blocking the return air to the system (dirty filter, something in front of the unit blocking the incoming air )
2 defective thermostat keeps the unit running past the desire temperature system does not cycle off and ice begins to form.
3 low refrigerant charge this causes the unit to run constantly and the room never cools off ice also begins to form.
4 defective blower fan this is will prevent the air from circulating pas coil and ice will form.
I HOPE YOUR SOLUTION IS SIMPLE.. IF THE UNIT IS NEW IT SHOULD BE UNDER WARRANTY GET IT REPLACED THERE IS NO POINT IN GETTING IT REPAIRED IF YOU JUST PURCHASE IT.
BEST OF LUCK
Jun 01, 2011 | Sharp AF-R100BX Air Conditioner
Continuing running, Ice on outside unit
Every unit has to take rest to re boost. That's why thermostat for heat or cold fixed, If your unit is not cutting off @ setting temp check room sensor. If defective replace it.
If unit continuously running but no cool inside room means gas leak. Find leak and do gas charging.
Dec 30, 2010 | Weather King 10PJA4301AH Air Conditioner
Water coming into residence, front of ac icing up and doesn't appear to be blowing cold air..
The icing up can come from a dirty air filter or from the unit leaking freon and being low on charge...
The other way to freeze it is to try and make the room too cold...
check the filter... don't try to get the room colder then say 70 and if it still freezes then you have a problem...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 01, 2010 | Whirlpool ACQ294XJ Air Conditioner
Ice on the evaporator
Make sure the coils are not dirty,if they are not dirty,add freon to the system,not much,feel the evaporator,when the evaporator is cool all over,and the condenser is warm all over,there is enough freon,add very little at a time,this system does not hold much freon,if this was helpful,at all,please rate,thank you.
Jul 06, 2010 | Fedders A6Y12F2D Thru-Wall/Window Air...
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Evervarator make ice up
Temp setting too low for high humidity. Turn up temp. this allows the unit to stop cooling intermitently so the ice doesn't build up unless it is runs constantly. Good luck
Jun 02, 2009 | Goldstar LG LUCKY WG1800R Room Air...
Instead of cooling the room, the back of the AC forms ice
Change the filter. It doesn't have the proper air flow across the coil. Hope this helps. Good luck
Apr 27, 2009 | Danby DPAC8020 Air Conditioner
Ac ices over
First you need to make sure the filter is clean to allow good air flow through the evaporator. If the filter is clean make sure the evaporator is not plugged up with dust and lint. If all that is ok your problem is the a/c BTU's is to big for the size room you have the a/c in and it is getting the room too cold. If that happens the evaporator will ice up and will not cool the room.
Jul 08, 2007 | Haier HWR06XC5 Wall/Window Air Conditioner
Heating & Cooling Logo
226 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
