Question about Hunter 23827 Classic Original White 42" Ceiling Fan
Where does while lead from ceiling connect? capacitor has five leads, 2 gry, 1rd, 1 grn 1br, (grn gry br to switch) switch has black lead to ceiling lead.
On a hunter ceiling fan, capacitor has five leads, three (br, gr, gray) go to switch, red is to red on fan, black to ceiling black lead. My question is where does the white wire from ceiling connect?
    Problem Solver:
  • 14 Answers
White is the common, or neutral. There should be a white wire to connect it to.
Posted on May 24, 2009
Ceiling fan speed chain broke off while fan was off. Replaced the 3-speed 4-wire switch with same type and rewired as before. Now fan only has 1 low speed. Could capacitor have gotten damaged?
capacitor tis toast. Have done what you did once. Just remember if/when replacing it...
The capacitor leads are color coded but the motor leads may not be! Tag the motor leads with colored tape before disconnecting the old capacitor, if necessary. Been there too! Differ by brands whether they are color coded.
Feb 25, 2018 | Hunter (25417) Ceiling Fan
2001 Mitsubishi eclipse spyder gs lights blink starts up runs five secs then cuts off
I have a tip for that too :>)
Tip & How-To about Cars & Trucks
Resetting a Vehicle Anti-Theft System This is how you reset an anti theft system if you have the anti-theft light on, or your car is cranking, but you have no spark.
Doing a full reset of the anti-theft system.
Disconnect both battery leads for at least two hours.
Hold the negative and positive leads together for 5 minutes to fully discharge any power.
Put the key in the ignition, but not turned on. VERY IMPORTANT!
Connect the positive lead.
Connect the negative lead in one swift movement.
Wait 15 minutes for the system to fully reset.
Posted by Andrew... on Jan 14, 2018
Feb 18, 2018 | Mitsubishi Eclipse Spyder Cars & Trucks
I need the color code for speakers in a 1994 Linclon Continental.
LF: + ORG/LT GRN, - LT BLU/WHT
RF: + WHT/LT GRN, - DK GRN/ORG
LR: + GRY/LT BLU, - PNK/LT BLU
RR: + ORG/RED, - DK GRN/ORG
Mar 06, 2017 | Lincoln Continental Cars & Trucks
Looking for a wiring diagram for a range selector sensor plug for a 2004 chevy silverado 1500,4x4,4.8L with a 4KCD transmission
Connector Part Information • 15416722 BLK
• ASM Conn 12 F GT
Pin Wire Color Circuit No. Function
1 DK GRN 1433 Clutch Start Switch Signal
2-3 -- -- Not Used
4 YEL 772 Transmission Range Switch Signal B
5 BLK/WHT 771 Transmission Range Switch Signal A
6 GRY 773 Transmission Range Switch Signal C
7 BLK/WHT 451 Ground
8 WHT 776 Transmission Range Switch Signal P
9 LT GRN 275 Park Neutral Position Switch Signal
10 GRY 1524 Back-Up Lamp Supply Voltage
11 PNK 839 Ignition 1 Voltage
12 PPL 639 Ignition 1 Voltage
This all I could find, hope it is the correct one.
Apr 08, 2016 | Cars & Trucks
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
I am trying to install an aftermarket radio in my 02' dodge grand caravan and im having trouble with the connections and getting the interior speakers to work what do i do?
RADIO 12V|gray/red |+ |radio |
| RADIO GROUND| | | |
| RADIO SWITCH|blue/pink |+ |radio |
| RADIO ILLUMINATE|orange/tan |+ |radio |
| LF SPEAKER|green - grn/brn | |radio |
| RF SPEAKER|gray - gray/brn | |radio |
| LR SPEAKER|grn/blu - grn/org | |radio |
| RR SPEAKER|gry/blu - gry/org | |radio
Mar 26, 2010 | Car Audio & Video
My ceiling fan has no reverse switch, how do i change the direction
My fan does not have a reverse switch for sure so I scoured the net and got no real answer. I did come accross a comment that said that it worked internally at the remote box in ceiling. Here is how I finally figured it out after about 6 months of searching. Put the fan on high, Turn wall switch OFF, Hold the HI button on remote, Turn switch back on. IT WORKS!!!!!!!!!!!!! Sparq
Jul 18, 2009 | Hampton Bay 24002 Ceiling Fan
WIRING OF 3-WAY SPEED SWITCH FOR HAMPTON FAN
1 - Red/Pink
2 - Purple
3 - Yellow
L - Black
Mar 11, 2008 | Oasis Hunter 54' Ceiling Fan
Wire diagram
guynoir..with alpine your other set of speakers would most likely run through an amp ,which may connect up by the rca leads or a din plug , this is where your fader comes in to play.i was an agent for alpine
Feb 07, 2008 | Car Audio & Video
Hunter 23827 Classic Original White 42" Ceiling Fan Logo
411 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
