Question about Bell Sports BICYCLE CHAIN LICENSE PLATE AUTO
I replaced a broken chain now my bike wants to skip like the chai
N is skipping or the gears are stripped
  • 484 Answers
In my humble opinion, i believe you would have noticed if your cassette was worn out. i believe the problem is derailleur adjustment and alignment. If you are comfortable with this adjustment, here's how you do it:
The first step in all bike maintenance is always cleaning what you are working on first. Wash your drivetrain frequently, because dirt+grease=poorly functioning equipment. Use Simple Green and a brush to thoroughly clear your derailleurs before adjustment and, contrary to popular belief, the derailleurs DO NOT REQUIRE LUBRICATION. Only the chain and cables get regular lubrication.
Start by flipping the bike over and setting on the saddle and handlebars.
Shift into your middle front chainring and the highest gear on the cassette, rotating the crank while you shift.
Now release the rear cable at the derailleur.
Eyeball the alignment of the derailleur to make sure it is perfectly plumb with the bike, straight up and down. Then make sure that it is also longitudinally straight and follows the same front to back line as your frame. Bend the hanger as necessary by firmly holding the derailleur body and tweaking until it's all straight.
Once you are confident it's all aligned, adjust the derailleur by setting the "H" and "L" stops ans follows:
"H" (or High) is set by adjusting the screw until the jockey wheel floats perfectly over your smallest cassette cog. "L" is set by manually moving the derailleur until you are ever-so-slightly past the last cog (i like it to be precisely parallel with the last cog on my bikes) and set the stop at that point.
Now that the limits are set, set the barrel adjuster on the derailleur to its centermost point and pull the cable taut and re-tighten the screw.
Now shift into your middle gear, cranking as you go, and use the barrel adjuster to set the jockey wheel so it is aligned and centered over the correct cog.
Shift up and down the cassette, cranking as you do it, and in every gear, back-spin the crank to make sure the bike doesn't jump out of gear. Adjust the barrel nut if necessary until all gears work smoothly.
If this made no change, then your cassette or derailleur may be the problem.
Posted on Sep 13, 2009
  • 18 Answers
What has happened here is that the original chain and the teeth on the cassette wore out together. When the cassette wears out and you install a new chain, you will feel a rough feeling in your feet, and the rear gears will not shift properly because the teeth on the cassette are too worn.
You probably also have worn chainrings in the front, which will require replacement.
It is usually a good idea to replace your chain every 1500 miles or so. This prevents the chain becoming too stretched out and causing undue wear on the teeth of the drivetrain.
It is also very important to clean your drivetrain frequently. I recommend Finish Line Metro as a single-step cleaner and lubricant. Apply it liberally to the chain by holding the sprayer on the lower half of the chain while spinning the cranks backwards. Let it sit for a minute, then run the chain through a rag or towel until it is clean. It may be necessary to use several clean parts of the towel, as it will become filthy very quickly.
Once it is clean, it is good for a ride or two before the process is repeated. This will help reduce wear on your drivetrain as well as frequent replacement of the chain.
Posted on Aug 21, 2009
Over tim and use, the chain and the rear cogs stretch and shape to form. Replacing the chain usually means replacing the rear cog cassette. If the rear cogs are expensive, then replace the chain more often before it breaks and then you don't have to replace the rear cog cassette
Posted on May 25, 2009
How do you measure your bicycle chain?
There should be a removable link, take it off and lay the chain out straight to measure it.
Jan 24, 2017 | Cycling
3rd gear slightly skipping what should I do?
Tighten the clutch line, check for wear on the third gear and chain, tighten your chain to proper specs for the bike.
Jun 07, 2015 | Motorcycles
The chain moves but skip gears,how do I fix this
Has the chain been replaces recently? Have you had a wreck recently or laid the bike down on the drive side that might have bent the derailleur hanger?
Feb 16, 2015 | Cycling
Skipping
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Chain skipping on idle What the heck
Bike skipping gears motorcycles
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Mar 19, 2014 | 2007 Yamaha V Star Classic
Bujaj Pulsar 150 chain set problem
Hi, Yes, If it is worn out. do so. Chain and gears do wear in time and will slip or skip over. So both gears and chain will have to be replaced with new...
Jan 14, 2014 | 2007 Bajaj Pulsar 150
Just purchased bike and chain skipped under load
very likely that chain links not "fitting" cog teeth . if both chain and cogs are brand new, then skipping should never happen. more often than not, a repair would require both new chain and new rear cogs, and possible new fron t chain wheel. all depends which item are worn. I would probably get a new chain firstly, then see if this fixed the problem. nigel
Jul 06, 2012 | Specialized Hardrock Pro Disc
From 4 gear to 7 gear every 6 to 7 pedal it skips like changing gear mountain bike
Hi michaelcook1....
Sounds like you need to adjust your derailer on the back of the bike, it may be out of adjustment and causing the chain to slip.
Please take time to rate me
Aug 18, 2011 | Cycling
I've got a 21 speed bike and I get a skipping ,
It is the derailer (the part on the back that the chain runs through). Take it to a bike shop or bike enthusiast. The repair should only take about 5 min. Some bike shops won't even charge you.
Jul 22, 2011 | Cycling
Hi, I have recently installed a new X9 derailleur in accordance with the manufactures' instructions. I have also relpaced the rear hanger. The gears shift ok, however, when in gear, especially the...
Did you also replace the chain or any of the cogs? Skipping is a common condition when you replace one and not the other. Or if the cogs and chain are well worn, it may simply be time to replace them. You can usually do fine without replacing the gear-rings (that is, the cogs by the pedals)
Nov 10, 2010 | Sram X9 Mountain Bike Rear Derailleur
Popping skipping chain
how long have you had the chain on your bike? it may be worn (or your rear cassette may be) if skipping is occurring. have you attempted to adjust your shifters as well?
May 01, 2009 | Cycling
Bell Sports BICYCLE CHAIN LICENSE PLATE AUTO Logo
219 people viewed this question
Top Bell Sports Cycling Experts
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
