Question about Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater
Maytag MAH3000AEW The programme gets as far as "Rinse level fill and bleach dispense" where it stops and goes dead. Clicking on one position and the programme completes ok. I changed the main board and it solved the problem. However I would like to know where to look on the board for a failed component which would cause the problem, in order to repair the board for next time. Many thanks.
    Scholar:
  • 146 Answers
Sorry, I can't help you with that. The faulty component could be the main memory chip that stores all the programs.
Posted on Nov 05, 2007
SOURCE:
What do the dispenser symbols mean?
bleach if you don't have a bleach dispenser on your washing machine. ... That means that if you add your chlorine bleach as stated above you will not get bleach...
Sep 04, 2015 | Washing Machines
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
The next wash, after a wash load using bleach, gets a few bleach spots. After washing a load using bleach, I've tried washing a load which would not matter if bleach contaminated it. Even the 2nd load,...
I would just put the bleach into the tub while it's filling and wait till it's about half full of water before adding the clothes.
It may help to pour the bleach into the dispenser then pour water in after it to rinse it out. Some washers say to do this in the manual.
Dec 07, 2010 | Washing Machines
Adding bleach to front load washing machine
Put you bleach into the machine whist it is filling using the left part of the drawer.
Jul 03, 2017 | Maytag EPIC MFW9700S Front Load Washer
Neptune Washer dispensers
Replace the wax motors for both the bleech and softener
Sep 01, 2008 | Maytag Neptune MAH5500B Front Load Washer
Detergent goes where?
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag MAH6500 Neptune Front Loading Washer w/Built in Water Heater Logo
47 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
