Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
I dropped my camera and now it won't take a picture if the flash is turned on
I dropped my Canon PowerShot SD500 from about 4 feet and now the flash won't work. Is this a part that can be repaired/replaced? HELP! Thanks!
  • joemontanafa May 24, 2009
    have you dealt with darntoothsammy.com
    President:
  • 423 Answers
Typically yes, it should be repairable, but not by most individuals or even camera shops. It should go to Canon, or their authorized service facility in your area. Camera manufacturers won't sell "parts" (as opposed to accessories) because many people try to install them themselves, damage the part and the camera, then blame the part and want a refund. Send it to Canon, get an estimate, then decide if it's worth the cost.
Posted on May 24, 2009
Canon powershot sx10 cannot download
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as iPhoto.
Jun 21, 2012 | Canon PowerShot SX10 IS Digital Camera
I dropped my canon powershot SD 4500 IS and now it won't turn on! It's survived countless other falls just fine, and would turn on immediately then. All times, including this time, have been when...
Really!....you've dropped your camera "countless" other times and now you're concerned because this time, it won't turn on!!! You're not sure what else to do?!!! How about not dropping your camera. How about using the wrist strap. Your dropping luck has run out...your camera does not have nine lives.
Aug 23, 2011 | Canon PowerShot SD4500 IS/IXUS 1000 HS...
Ixus 430 will take photos when flash is turned off, but will not take photos when flash or redeye is selected
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try. (Hint, make sure that all the screws around the perimeter of the case are present and firmly seated.)
Jun 01, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
Bad indoor pictures. When I take indoor pictures and it says to use the flash I do but then my pictures turn out dark/grey. Then I try it without the flash and they are brighter but then blury. I even...
The flash has a range of up to around 10 feet at the wide end of the zoom, down to 6.5 feet at the tele end. Maybe you are using it on to big a distance or at to low ISO? Try setting the ISO to 800 and see if it helps. images get a bit more grainy at 800 ISO but are also less prone to camera shake, if you use it without the flash. The camera goes as high as 1600 ISO, but images get very grainy at that setting.
Jul 01, 2010 | Canon PowerShot SX100 IS Digital Camera
Problem with flash on Canon Powershot SD870 Digital Elf
There is a problem with the flash or flash charge circuit. It will need to be repaired and may cost about $ 100 if not under warranty,
Apr 05, 2010 | Canon PowerShot SD870 IS Digital Camera
How do I take clear action pictures?
You can turn the dial to TV and set the shutter speed faster but you will need a bright sunny day to set it faster than 1/500. Make sure the ISO is set to auto or one of the higher settings. ISO settings are accessed by the FUNC.SET button on the back of the camera. Indoors you can turn on the flash with this setting but I doubt the flash is effective more than 15 or 20 feet. You can also try setting the dial to "kids and pets" which is a more automatic setting.
Mar 04, 2010 | Canon PowerShot A720 IS Digital Camera
The flash and picture are out of sync.
If your flash has worked properly in the past, the camera may need to be serviced. If your subject is within 6 - 8 feet and is not being properly illuminated, something needs to be adjusted or replaced.
By specification, your flash will only adequately illuminate subjects out to 14 feet (wide angle) or 10 feet (telephoto). If you're trying to shoot subjects further away than that, the flash is not bright enough.
Dec 28, 2009 | Canon PowerShot A630 Digital Camera
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
My canon A530 will not turn on
Damaged Lens Block.
Needs to be replaced.
Mar 20, 2009 | Canon PowerShot A530 Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
215 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
