Question about iRiver iFP-395T MP3 Player
Iriver-395T cannot load any files, indicates bad sectors
My computer just did a diagnostic on my Iriver395T and says it has bad sectors, with 0 bytes available and 0 allocation units available on disk.  I am unable to load any files onto it - get a message there is no space available. I unloaded all files that were on it, reformatted it, and still have same problem.  The software user interface still works, and it can still play FM radio.  I had not been using Music Manager, but was using it like a portable drive to transfer my MP3 files (my own recordings) on and off of it via Windows File Explorer.  I am currently using Windows VISTA operating system.
Is this repairable, and if so, how much $?
When you opt to Format , please select type as"FAT". Donot use FAT32 or NTFS types. they are not mean for Iriver MP3 players.
Posted on Feb 04, 2008
Hi
I see your problem but you have not descirbed the way you formated it can u try format it again in fat don try ntfs it may help and check through format means complete format
thanks
Posted on Feb 02, 2008
HP v218g PEN DRIVE 16 GB SHOWING 0 BYTES MEMORY
Click start control panel administrative tools computer management disk management right click on your drive select properties
click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
Hope it helps.
Dec 02, 2012 | Electronics - Others
Error code 0142 message error code 2000-0142
My computer did boot up to the desktop, but was completely unresponsive from there when trying to open anything. I ran a system diagnostics and got this error with the status byte of 70. I rebooted into Safe Mode and was then able to open files. I backed up my stuff to a flash drive and then ran Error-Checking in the HD Properties which runs the CHKDSK function the next time the computer is rebooted. That found 2 bad file clusters and repaired them. One was a file called Windows.edb, which does the hard drive search indexing for Windows and was most likely my problem with the lockups. The other was a Napinsp.dll file. After these were fixed and the computer was rebooted, everything worked normally.
This HD is only 9 months old, but if this happens again, I'll replace it again.
Apr 21, 2012 | Dell Inspiron 6400 Notebook
I need a diagnostic tool for RAID falure code 0. Initial boot indicates degraded condition. DISK scan does not seem to remedy the issue. Did the drive actuually fail? Is there a fix? Primary disk still...
It looks like you have two arrays here. The first one being a mirrored RAID array and has only one disk. This means that the other disk has failed in some sort. This does not mean that the drive is bad, just the RAID failed for some reason. You will need to rebuild the RAID if you want to maintain the same level of redundancy.
You can just attempt a rebuild the RAID to the same drives but if this fails you will want to replace the bad drive. In order to do this you will need to make sure you can tell which drive is which. You do not want to mirror the bad drive to the good one.
If attempting a rebuild to the existing drive does not work or is not an option (because the failed drive could really be bad), you will need to determine which physical drive needs to be replaced. You may be able to hot-swap the drive but if you can power things down, that is always safest. Once the new drive is installed, you can rebuild to it and all should be well after that.
Jan 04, 2011 | Dell Dimension 9100 PC Desktop
My IBM T41 developed a problem with the wireless radio on network connection with my O2 router. It is OK when hardwired and when the radio is off, but when the radio is enabled, within 2 or 3 mins aftwr...
The disk-drive on your computer is having problems reading data, i.e., it's about to "die".
Sometimes, i.e., when your wireless is enabled, it's trying to read that part of the Windows software that controls the wireless device from the disk-drive,
When Windows writes a block of data to the disk-drive, it calculates a "check-sum" code, using 'ECC', and writes those bytes as well. When Windows reads a block of data from the disk-drive, it recalculates that "check-sum", and compares it with the ECC bytes that also were read from the disk.
A "mismatch" between the "old" and the "new" ECC indicates that the data has _not_ been correctly read from the "sector" (#6310750) of your disk-drive.
Backup your files, contacts, and E-mails, and replace the disk-drive, as soon as possible.
Apr 05, 2010 | IBM ThinkPad T41 Notebook
Long periods of hard drive activity
Most likely, it could be the amount of ram you have in your computer. If your running low on ram and it is using the virtual memory your computer can be running all the time causing a slow down in whatever you do. Check to see how much ram you have :)
Mar 24, 2009 | Computers & Internet
Lost software
bradders,
question: from your iriver mp3 have you already format it or the files are still inside?
if your reffering old files as files you've accidentally delete from your player. the only way to retrieve the said files is by using a software "filescav" or filescavenger. this software can only retreive files from any removable device if the said device haven't been formated.
but if you only want to get the present files installed in your iriver, i do think that once you connect your iriver to a PC. the PC will search for a newly installed drive which is your player. and once detected you can open the folder of the newly found device and simply copy and paste all the documents and files you want to copy from your mp3 to PC.
note: you can download filescavenger from web free. just type in google bar " filescavenger" and it will show all the possible download site for the said software
cheers,
mark
Jan 16, 2009 | iRiver iFP-395T MP3 Player
Where can I service my iriver mp3 player that is out of warranty
Forget it Pal you'll be happier with a new IPod. I looked for a repair shop and they wanted close to what an IPod cost.
Feb 02, 2008 | iRiver iFP-395T MP3 Player
DRIVERS FOR AIGO A210 MP3 PLAYER
i have a friend iriver ifp-395t mp3 plaver looking for driver, fund one does not work, show me the money
Dec 26, 2007 | iRiver iFP-395T MP3 Player
IFP-395T (AA Batteries)
Probably a hardware issue, but the issue could also be with your USB port - make sure that there are no yellow exclamations next to the usb port in the PC device manager.
The battery indicator might not be stable during the following activities because they use large amounts of power:
1. The backlight of the LCD
2. Volume change
3. Pressing function keys and buttons
4. Reading the CD or files (Loading data to the memory)
The battery indicator shows the life expectancy of the battery based on current power usage. During these high power usage activities, that may only last a few seconds, the indicator will obviously show a lower level on the battery indicator. Once the high power activity has ended it will show a more accurate battery level.
Sep 26, 2007 | iRiver iFP-380T MP3 Player
iRiver iFP-395T MP3 Player Logo
194 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
