Question about Canon FAXPHONE L80 Laser
Toner Smearing I have a Canon Faxphone L80 and the toner is not drying on the paper. Can you help me?
  • butlerswebuy May 24, 2009
    Thank you for your answer!
It's actually heat and pressure, that 'melts" the toner to the page, and what is happening in your case, is that the pressure roller is worn out, so you're not getting the contact between the heat and pressure rollers necessary to properly adhere the toner. This will require a service tech should you want to spend the money to repair it.
Posted on May 24, 2009
How to retrieve faxes in memory
take out the paper or toner and the faxes will recieve in memory!Its the only time it will go to memory!
Feb 08, 2010 | Canon FAXPHONE L80 Laser
Where do you get refill ink for canon fax phoneL80
The Canon Faxphone L80 takes a Canon FX3 cartridge. To get the highest quality refill I would first see if there is a Cartridge World store in your area. Cartridge World stores refill most cartridges in house with American made parts. Then try Office Depot. Office Depot is the only big box store that actually "remanufactures" toner cartridges. I would not recommend cheap refills or refill kits from the internet. Many use very low quality toner that wears on parts leading to print defects or they reuse parts that already generate print defects. DO NOT buy a "compatible" cartridge, these are not refills. They are new cartridge replicas and have no recycled components.
Dec 16, 2009 | Canon FAXPHONE L80 Laser
Canon faxphone L80 parts available? paper feed shaft broke in half
The L80 printer guts are very similar to the HP 5L and HP 6L printer (Not well known, but the printing engines on many HP printers are made by Canon). In fact it is almost possible to use a 5L/6L toner cartridge in the L80, but as I recall there was a plastic nub that prevented it from fitting properly. This is probably meant to force the user to buy more expensive Canon toner carts instead of using cheaper generics for the 5L/6L. Try HP PartSurfer and you may be able to locate the part that you need.
http://www.partsurfer.hp.com/cgi-bin/spi/main
Jul 29, 2009 | Canon FAXPHONE L80 Laser
Paper jam
When this happens it is because the pick up tire has either worn out or has alot of paper lint on it. Remove the toner and I think on this one you can see a rubber wheel in the back middle. You can clean this with a little windex or all purpose cleaner. If it will not pick up the paper after that the tire needs replaced.
Oct 13, 2008 | Canon FAXPHONE L80 Laser
My L80 keeps reading "Change Cartridge" even when a new one! Can anyone help!!!
If you pull the cartridge out and look inside the are to Metal pins to the right hand side make sure niether are stuck. Also if you are using refilled or refurbished cartridge they may not have been filled with the proper type of toner and the magnets in the cartrisge may not be regonizing the toner.
Apr 19, 2008 | Canon FAXPHONE L80 Laser
Fax says Paper Jam but there isn't one!
After what operation does the machine report the jam. If it is trying to print something and the paper doesn't pull, then it will report a paper jam, even though the paper didn't move. If this is the case then the paper feed tire behind the toner is dirty. Cleaned with rag and rubbing alcohol.
Apr 08, 2008 | Canon FAXPHONE L80 Laser
Canon faxphone l75
what does it say on the display
Thank You,
Mikey
Mar 20, 2008 | Canon FaxPhone L75 Plain Paper Laser
PAPER FEED
the drum of toner crtridge has expired chande the drum if available,otherwise change complete toner cartridge
Sep 17, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
82 people viewed this question
old marine
old marine
