Question about Hotpoint FFA90 Bottom Freezer Refrigerator
Bottom vent in fridge not expelling cold air
Hi, on my FFA90 the vent at the bottom of the fridge is not expelling cold air and the one at the top is working, but not at full strength. Is this the fan icing up? and if so what is the quickest and easiest solution?
The frreezer seems OK, last time it froze up all the fans stopped working and the freezer food started to defrost!
Many thanks in advance,
Adam
  • 833 Answers
Adam, I had this happen to me! There is no easy solution, unfortunately. Let's go through the possibilities:
You're not defrosting completely and the ice is blocking the coils. Shut the unit down by unplugging it. You will actually have to take this apart to defrost them. Messy, I know. Other alternative: wait for at least two days!! And your food will spoil. If you don't start with a 'clean box', you'll never be able to clear the ice and keep it working.
Unplug the unit. Remove the rear interior freezer panel and unplug the ice maker and other stuff that's there. If there's an icemaker, don't forget to shut off the water! Use a hair dryer to assist in the defrost. Avoid getting it wet!!! Do not use a knife near the coils. Stab one and it's over! Get it clean and dry! There are two wires that go to a long heater that runs the width of the cabinet below the coils. They help defrost the coils If you have an ohm meter, measure from one wire clip to the other and get a reading. Should be close to continuity (not over 100 ohms). If not, the defroster wires are corroded or the heater is defective. Determine which. Ohm meters are available for under $10. Not interested in all that? At least cycle the connectors or wiggle the wires enough to make the connection better. There is a timer which controls this called the defrost timer. They don't usually cause trouble in GE/Hotpoints. If they stick, they may not cause that heater to start defrosting.
Very important thing: on many GE/Hotpoint units, the condenser is located under the unit and they get dirty. Get a brush made for this purpose...about 18 inches long and about 1 1/2 inches in diameter. Remove the front kick panel and clean all the gunk out of there. Repeat every six months!!!
Now: Remove the rear paperboard to expose the compressor. You'll see that it has either 2 or 3 tubes coming out of it. The largest is what you'll clean off. Start the unit. In the next 5 minutes, the tube should become cold enough to first frost over and then either have it turn to water or dry up. It should be pretty cold. If the tube is still frosty-low gas is a strong possibility. Up top, in the freezer compartment you should note the same thing with the coils. If they are not frosting evenly...you're low on gas. Get this handled professionally. Remember...this process takes at least 5 minutes after compressor start!!!
Oh, and one other thing: moisture is the enemy. Don't 'window shop'. If the door is left open or the gasket is damaged, this will cause excess moisture to condense.
Posted on Nov 25, 2007
SOURCE:
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hi We have a whirlpool side by side no ice maker in the past week the freezer is cold and frosty fridge is warm up to 15degrees at the top bottom of fridge is 5 degrees. Top vent from freezer is not in...
3 things
If you have ice on the freezer side.
1. defrost timer not working
2. blower fan failed, if it has one
3. defrost limit switch failed..
i dont think it is #2 but 1 or 3
last but not least your defrost heat coil has failed
Dec 18, 2010 | Refrigerators
Hotpoint ffa90 bottom freezer only cools down to minus 4
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 28, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint FFA90 fridge freezer, fridge not cooling but freezer OK, was told vent proabaly blocked and to de-ice. Turned appliance off for two days, turned back on worked fine for 1 week but now fridge is...
i have the same problem. took apart the vent in the fridge at the top and thought maybe it needed replacing as that controls the amount of cold coming up from the freezer, but there doesn't seem to be any cold coming through. does anyone know if this is 'blown' through by a fan of some sort?
Jun 14, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
The top is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Apr 01, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
Fridge of my Hotpoint FFA90 fridge-freezer freezes
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 11, 2010 | Hotpoint FFA90 Bottom Freezer Refrigerator
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
Freezer fan not working
Peace Friend,
ngfam1 At your service!
Ready?
If the freezer is cold and not the fridge, you need to make sure the freezer is filled to the top and covering the cod air vents and passages usually found in the rear or bottom rear of the freezer!
If they are blocked or covered whit packages the unit will not be able to transfer cold air to and from the fridge!
Yes, they share the air in most refrigerators!
What type fridge,model and age?
If not only a trained tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
Sep 02, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Hotpoint FFA90 Bottom Freezer Refrigerator Logo
217 people viewed this question
Top Hotpoint Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
