Question about Whirlpool SF378LEP Gas Kitchen Range
Whirlpool SF330PEWW5 Completely Dead
I checked fuses on the house and the outlet is live. I have checked power at the outlet and it is also live.
One day the stove and oven worked and the next it did not. I can manually ignite the burners. I've not tried to manually ignite the stove. The clock also is also off and has been cutting off a few times over the past week.
If anyone can share a wire schematic that would be helpful as well.
Added info: I replaced the igniter on the stove 6 months ago.
I have unplugged and plugged in the stove and get no response from the timer.
  • Whirlpool Master
  • 3,361 Answers
Open the backguard on the range to access the electronic control. If you read 120 volts into the control and nothing works,...replace the control.
Posted on May 24, 2009
In146 dead
First check wall outlet is bad or a house fuse has blown. Try another outlet. Test / replace if bad: power cord, fuse and on/off switch on projector. If these do not solve the problem, consult a professional service person.
May 27, 2014 | InFocus IN146 3D Ready DLP Projector
Suddenly microwave stopped working
(would really like more info- digital number dead as well?)
(assuming completely dead) Could be a couple of things:
- blown fuses (inside, relatively easy to replace, std size avail at Raioshack) <-- most likely
- cut/loose power cord connection inside.
- (unlikely but worse case scenario) Door was closed crooked- one tong hit one door switch before the other- causing a short circuit internally that "self destructs" the microwave to prevent it ever operating with an open (or even crookedly ajar) door, irradiating any users. Typically it just blows the fuses, but if fuses blow immediately upon replacing and turning power on, then possibly one of the switches fused or melted internally, and needs to be replaced.
Jan 28, 2014 | Whirlpool MT4155SP Microwave Oven
RCA Model RMW700 micorwave 1 yr old stopped working. No power, yet the outlet is live. No power to the display, no light inside, just dead. Stopped working when heating cold cup of coffee.
There is a fuse inside the cover of the microwave. You will need to remove the outer shell and follow the power cord you will see an inline fuse. This fuse can be purchased at any appliance parts house.
Hope this helped
Dave
Jan 19, 2010 | RCA Microwave Ovens
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Completely dead. breaker is fine. have live power at dishwasher. ???? Replaced heater, pump and check valve last year. No obvious burnt or disconnected wires.
There is a thermal fuse located behind the operator console on nearly all Kenmore or Whirlpool manufactured dishwashers. There were some noted problems with certain model dishwashers where the wire gauge on the thermal fuse was too small and would heat up causing the thermal fuse to blow prematurely. There is a replacement kit available that includes a wire harness with a larger gauge wire that you simply splice in place. It handles current better and prevents the fuse from blowing prematurely. To ease your mind, there were no reports of fire hazard.
If you need to view a diagram of your dishwasher, enter your model number at the website mentioned for some excellent exploded view illustrations. The thermal fuse is usually listed under the "Control Panel Parts" heading.
If you have any questions, please let me know. I hope this helps you.
Oct 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dryer quit working. Completely dead
Hi, If this is a whirlpool model dryer, try this: Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. If this is another brand dryer, please let me know the model # so I can assist yyou further.
Thanks
Vic
May 30, 2009 | Dryers
JUST HAS NO POWER. OUTLET IS LIVE. DRYER IS COMPLETELY DEAD.
the wiring diagram for you dryer will be in one of two places either in the control panel up top or just inside the top of the dryer. and yes there is a thermal fuse if you pull it out from the wall and pull the back plate off you will see it. it is about 1/4" wide and about 1.5" long usually is white.
May 07, 2009 | Dryers
Jenn-air refrigerator
check the outlet power to see if there is power may be the outlet because the outlet conections are like fuses and some times they are burnd so check the outlet if no power check the wires attach to the outlet
Dec 29, 2007 | Jenn-Air JFC2087HRP Side by Side...
Whirlpool SF378LEP Gas Kitchen Range Logo
239 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
