Question about Plantronics Hama Voyager 520 Bluetooth Headset
I cannot get my Plantronics voyager520 to pair with my tmobile g1
I've done everything from turning on bluetooth for connection, and going into the bluetooth settings in my phone.I already had it paired to another phone b4(motorola razr v3t). I am no longer using that phone.
  • browntanya76 May 24, 2009
    Just hold the button down until it starts to flash red&blue.make sure you are in your g1 bluetooth setting.touch device name (520) after it finishes searching,light flashes then input code(0000).at this time after pairing it will automatically turn its self off so turn your blutooth on.
I just did this... first make sure your old phone is off... second go to bluetooth and make sure that discovery is on and then put your plantronics in learn mode or what ever its called by turning it on and holding it until it flashes red and blue... Your phone will request a pin code.. the pin code for plantronics is 0000 then it should connect. Hope this helps
Posted on Jun 04, 2009
    Problem Solver:
  • 4 Answers
U have to uninstal tha from that phone and than instal it in ur new phone otherwise it will not work!!!!
Posted on May 24, 2009
Reset G700 bluetooth with tmobile G1
Hello...
I think you are trying to pair this bluetooth with your tmobile phone... Is this correct?
If so, here is a link to how to pair this bluetooth device... > http://wiki.answers.com/Q/How_do_you_troubleshoot_the_motorola_H700_bluetooth_headset
Hopefully that helps...
Aug 08, 2011 | Motorola Mobility H700 Wireless Headset
My plantronics Bluetooth will not go into pairing mode no matter what I do. I held down the call button and it does work. Are there any other alternatives?
When you hold down the call button do you get a red then blue flashing light? This is pairing mode. (also the only way to get this headset into pairing mode) Make sure the phone is close to the Bluetooth headset. For most phones pairing a headset is done by
  1. Settings/Tools > connections > Bluetooth > On (your phone manual will have all the specifics but this is usually the buttons)
  2. Turn your headset on (on/on switch) and wait till the indicator flashes red then blue.
  3. Set your phone to "discover" or "add a device" which steps are usually - setup > connect > Bluetooth.
  4. Once available headsets are available select your headset. If it asks for a code the generic code is 0000
  5. A successful pair is indicated by a blue light and also a confirmation on your phone.
Regards, Tony
Apr 20, 2011 | Plantronics Explorer 240 Bluetooth Headset
My new sony ericsson doesn`t see a new plantrosonic voyager. The blue topth is not paired with any other phones. Please help.
Please bear in mind that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Once you've done that, follow the simple instructions on the link below for the Plantronics Voyager Pro. Once you have your phone prepared for pairing, the process is pretty standard.
Plantronics Bluetooth Pairing Instructions
Good luck from Headsets Direct!
Dec 07, 2010 | Plantronics Voyager PRO Bluetooth Headset
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
Bluetooth problems!!!
you need to pair the devices in order to connect and use the bluetooth. Its for security reasons.
once the pairing is done you can use it
to pair go to bluetooth menu then options or configuration >devices>add new
now search everything will be fine
Jul 02, 2009 | HTC G1 Smartphone
I can't sync my Bluetooth Plantronics 220 to my Tmobile Dash...
I had the same problem which led me to this forum. The default passcode is indeed "0000". It could be paired to another device, or incorrectly. Shut down your phone completely, then turn off the plantronics by holding the power for at least 5 seconds, until you see a red light blink on the power. Then, turn the phone back on, turn the bluetooth back on by holding power for a second or two until you see a blue light blink. Then go into your phone and scan for bluetooth. While it is scanning, hold down power on the plantronics for a second until you hear a 'BEEP', then you will see it pop up on your phone. Connect to the plantronics, type in "0000" and hit enter, and it should work, did for me, at least. Age old problem with electronics, when they get confused, disconnect all power to them, and start over, works a lot of the time ;)
Jun 23, 2008 | Nokia 6030 Cellular Phone
Getting it to work
Pairing This was the second Bluetooth device I?ve used, and I had the headset paired in under 60 seconds once I had deciphered the instructions in the manual. When you press the call control and multifunction control buttons on the headset simultaneously, the M2500 goes into pairing mode. The standard way to get the Treo to pair is to click on the Bluetooth icon and basically follow the prompts: Turn Bluetooth on, make the device ?discoverable,? click on ?set up devices? and then ?Handsfree setup,? and the Treo will find the Plantronics headset. Once you?ve set up one Bluetooth device, you?re a pro. The only thing you need to know is the combination of buttons that puts a device into pairing mode. However, with the Plantronics M2500, I discovered an even easier method. Simply power up the Bluetooth headset while the Treo is on and you will be immediately prompted for the passcode, four zeros, if the devices are not paired. How cool is that? It saves many steps.
Mar 12, 2007 | Plantronics M2500 Consumer Headset
MOBILE PHONE NOKIA
Jan 28, 2007 | Plantronics M2500 Consumer Headset
Plantronics Hama Voyager 520 Bluetooth Headset Logo
1,353 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
