Question about Dryers
Gas dryer won't start.
Dryer won't start when pushing start button ... but motor hums while start button is being pushed.
  • 18 Answers
If the motor hums when you push the start button but wont move you probably have a frozen motor. happens from too much lint packed around the motor and ruins the bearings. if you can access the motor from a front kick panel you can check this. possibly something is jammed in the blower wheel as well. unplug it and check it out
Posted on May 24, 2009
  • 58 Answers
SOURCE: My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th pre
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
Posted on May 05, 2009
braindead56
  • 5 Answers
SOURCE: Push start and motor hums, but nothing else works.
Hey, either the belt is broke or something has happened to the tensioner pulley so remove front or rear panel & visually inspect & if belt is broken look & see if part # is still visible on belt surface & order a new belt.
Posted on May 12, 2009
dmftrucker
  • 1922 Answers
SOURCE: dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Posted on Nov 01, 2009
  • 35 Answers
SOURCE: Push start button and motor hums.
thermal overload on motor tripping
Posted on Jan 26, 2010
SOURCE: Dryer hums when the start button is pushed but it
It's probably the belt that turns the drum. Remove the front panel to see if the belt is broken
Posted on Nov 14, 2010
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My dryer is makeing a loud humming sound , whats causing it
If The dryer is not turning then the motor is locked up or possibly dirty open the door and push the door switch in turn the drum and push the start button it should start to run if it does you should clean out the motor.If that does not solve the problem replace the motor
Aug 27, 2010 | Frigidaire GLGR331A Gas Dryer
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
When I push the start button, the unit just buzzes or hums.
You have a broken drum belt. The hum you hear is the motor spinning at high speed.
Apr 21, 2009 | Maytag MDG2706A Gas Dryer
Dryers Logo
169 people viewed this question
Top Dryers Experts
