Question about Microwave Ovens
Emerson microwave oven
Hi where can I find the emerson microwave door spring. The spring is broken.
  • Microwave Ovens Master
  • 9,047 Answers
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Emerson parts are distributed by Fox International and their number is 800-321-6993. Or you might try e-mailing researchdept@fox-international.com
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Posted on May 26, 2009
I have an Emerson Microwave Model #MW7300W, it appears that a small hook on the Latch is broken off of. This hook holds the spring that allows the hook to hold the door closed. I have tried looking
If this is a .5-.7 cubic foot cheapy, your only source will likely be an appliance boneyard. Otherwise, check with searspartsdirect web site using the model # for replacement parts. You can also check with Emerson web site {I beieve it is part of the Funai electrical empire}
Jul 22, 2014 | Emerson Microwave Ovens
Emerson microwave door latch
I have an Emerson MW8999RD that all of a sudden yesterday wouldn't latch. I don't think you have to, but I took the door off (three screws hold the case on which needs to be removed to get at the top hinge). Then I took off the inner plastic picture frame - pretty easy with a thin blade to move the fragile tabs. Then I removed the metal frame that has the little microwave blocking holes. This was the hardest part because the plastic retaining tabs are even more fragile and I broke one. Then I found the loose spring due to broken plastic hook as described above. I was able to make a new hook by simply looping a small zip tie where the old plastic hook tip broke off. Now works great!
Aug 22, 2013 | Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
My boyfiend slammed the door shut and it has not worked since then
The door latch (on the door) or the door catch (on the oven) have most likely broken. The oven will not operate if the door is open or if it is not correctly closed.
Check the door latch. On most microwave ovens there will be one or two prongs. Make sure that they're not broken and that if neither of them is loose. Often one or both are designed to move upwards against spring pressure so if they move loosely with no spring pressure then the door must be dismantled to find out why. Often it's a broken spring anchor and sometimes it can be repaired, but the official fix is to replace the entire door assembly.
If the latch seems fine then it's almost certainly the door catch unit which must be repaired or replaced. They're not officially repairable, but sometimes all that has actually broken is a cheap and easily obtainable microswitch. If the catch has actually broken then there is no point in gluing it together as it won't hold. If the door catch assembly looks fine and the microswitch appears to be operable then use a continuity meter on the switch to confirm correct electrical function as the switch is pressed and released.
If that fails, then look for any fuses on the circuit board, the filament inside can break if they're subjected to too much physical impact. Test and replace any failed ones, but it's vital to use the correct type, the casing will indicate whether they're slow blow or fast blow fuses. These properties are independent of the voltage and current rating and simply regulate how quickly or slowly a fuse will fail if the limits are exceeeded. using a slow blow in the place of a fast blow is dangerous, but using a fast blow or a regular fuse where a slow blow goes will just mean that the fuse blows more often or even immediately in normal use, often when the door is opened.
If you need any spare parts then you'll have to find suppliers yourself, sorry. I don't know which country/state you're in and I'm based in London, England, where Emerson is not a known brand.
I hope that my answer helps you to either repair your oven or to decide whether to replace it. Please take a moment to rate my reply.
Sep 23, 2010 | Emerson Black Microwave Oven
Microwave will not cook/start when start button is pressed.
You can get the latch itself from either partstore .com or repairclinic .com
Apr 19, 2010 | Emerson MW8168B Microwave Oven
900E Microwave Oven Door Won't Open even after
Your latch has come apart inside the door or inside the oven. Probably a spring separated or broke.
Remove the cover --WATCH OUT FOR THE SILVER CAN - LETHAL -- and try to release the lock that way. I think you will be able to open it from inside but I also think your trouble is inside the door, though I dont have experience on this model. If the trouble is in the door, you will have to disassemble it. Look for hidden screws or a plastic strip which must be removed to separate the door halves.
Good luck in your project.
Oct 19, 2009 | Emerson Black Microwave Oven
My emerson microwave has stopped heating up but appears fine
Hi
If your microwave oven doesn't seem to work at all, check these:
Fuses Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Mar 31, 2009 | Emerson Microwave Ovens
Broken door hook
The plastic cover on the inside of the door is purely push fit.
To force it off I used 2 strong stainless steel dinner knives.
By easing one knife between the internal glass and the plastic cover I managed to spring one corner by using the other knife on the external bottom edge of the plastic cover.
Try concentrating on one end and once this springs out it is easy to free the rest without having to take it off completely.
The hook is simple to do but be careful with the spring.
All in all it took 3 minutes!
Jan 13, 2008 | Neff B7740N0GB Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
