Question about Creative Labs ZEN Vision:M Digital Media Player
Screen problem brand new from the store- installed the software: hooked the device to the computer to charge. led light flashes but even when i pull the on switch nothing appears on the screen
Flashing normally means it has no power.  Leave for a couple of hours and it should have enough power to boot.
This is a constant pain if u let the power level go to low. to
Try and use the primary USB port
Laptops dont seem to give out enough energy to charge a Zen.
Posted on Oct 23, 2007
When yuo turn tv on it just keeps flashing seiki on screen
Sounds like corrupted firmware. A firmware update migh make it right. If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Aug 15, 2016 | Seiki 32" LED TV - SE321FB
Flashing yellow light
attery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery c02983514.gif When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer.
Dec 20, 2013 | HP Pavilion ze4300 Notebook
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
My drive is almost fill a 4g now when i plug it in it is not reading any of the stored files.
Hello there!
USB flash drives in general, are wonderful little tools that allow people to store a relatively a large amount of data in a compact and portable interface that is extremely easy to use at all. The downside of storing lots of critical data on a USB flash drive, however, is that they're fairly susceptible to damage and that you can lose all of your information immediately if something goes wrong. When troubleshooting a USB flash drive, there are several key things to check and to remember that will help you to determine whether your flash drive is destroyed or not.
1. Look and see whether or not your USB flash drive's indicator lights are activated when it is plugged in to your computer's USB port. The vast majority of USB flash drives have small LED lights located somewhere on them that flash intermittently when they're hooked up to a computer. If your light does not turn on, then it's either not plugged in properly or is damaged and likely not repairable.
2. Make sure to download and install the right driver software for your USB flash drive.
3. Try your USB flash drive on more than one computer before giving up on it altogether. If it works on another computer, then the problem is likely with your computer hardware or software, not with the USB flash drive.
4. If you cannot restore your files, you may use a third party software to recover them.
Regards,
fossildude
Mar 01, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
The screen is black and green LED lights up - what
the battery is probably to low. very common problem with these and many other models...hook it up to your computer via the usb cable for a few hours to get a good charge on it. then press and hold the power button for up to ten seconds.
if that fails, let me know and we can try something else, but this usually works 99% of the time
bill
Nov 10, 2009 | Tomtom GO 920 GPS Receiver
BLACKBERRY BOLD HAS NO POWER,WILL NOT TURN ON. THE ONLY SIGN OF POWER IS THE RED INDICATOR LIGHT TOP RIGHT....ON SOLID. CARRRIED OUT REBOOT TAKING OUT SIM AND BATTERY. ANY ADVICE WOULD BE APRECIATED.
I have the same problem with my Blackberry 8120, died this morning, will not switch on, no red light, no charging light, completely dead... my computer does not recognise the blackberry at all so cant install any new software.. plus I need to recover all the information that is on the handheld... please help if you can....
Oct 15, 2009 | RIM BlackBerry Bold 9000 Smartphone
No boot up
i'd see if you could take the disk to a computer store and have them recover the data if it is important to you, and then reinstall a new operating system.  The first rule of computers is that the software is not allowed to damage the hardware, so it's unlikely that your hardware is damaged.  A new hard drive shouldn't cost more than 50$ and should take care of everything after a fresh install if you are too worried about losing your data
Apr 23, 2009 | HP Pavilion zd8000 Notebook
My device couldn't turne on
I had this problem but I let it charge on ac overnight and then it worked again, however the battery is shot and will only hold a short charge.
Two solutions for these devices if they wont turn on.
Solution one would be to open it up and replace the battery.
Solution two is to remove the hard drive from inside and hook it up to a computer to remove the data. Or you could also take the device to a drive recovery company and have them do it.
The drive inside is an ordinary Toshiba Laptop drive. You can buy an adapter to hook these to a usb port from many online stores. Cables to go has one here http://www.cablestogo.com/product.asp?cat_id=1541&sku=39994 There may be cheaper ones on the market or you may call a local computer repair shop and they may be able to do this for you. As they are using standard drives the data should be safe and on the drive.
Jul 24, 2008 | SmartDisk PhotoBank PB40 40 GB USB 2.0...
Creative Labs ZEN Vision:M Digital Media Player Logo
35 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
