Question about Kenmore Heating & Cooling
Kenmore window air conditioner blows a fuse.
It is a 220 volt model and blows one of the two fuses as soon as it is plugged in.
  • 700 Answers
You got short circuit in the system. Then check the line where the fuse is blown that's where the fault is. Or if it is just the fuse for the two line, you have to check the entire unit.
Posted on May 24, 2009
Air conditioner will not restart
if that is all that was changed 240 volts is either not there. does it have reset on poer cord.
Sep 04, 2014 | Kenmore Model 253.70181 Window Air...
Where is fuse for ecoquest freshaire
Mine is on the back, just above the pluggin for the cord .
The fuse may be accessed by unplugging the cord from the back of the unit and gently pulling the fuse holder stright out. 100 & 110 volt models use 1.6 Amp slow blow fuse.
220/240 volt models use 1.0 Amp slow blow fuse. Got this info from my owners manual. I would also check to see if the on/off switch in on, this is just above the fuse. I hope this helped.
Feb 02, 2013 | Ecoquest Fresh Air Air Purifier
While running in a screw to install a new electrical outlet cover, the outlet made a small pop and the lights flickered but immediately came back on. I plugged in the unit to see if it worked and nothing...
You say the unit is 220 volt, but the plug you installed has a white wire which is normally on a 120 volt outlet. A 220 volt outlet would have 2 black wires and ground. If you do have 220 there, and the reset does no good, I've seen those resets(they are basically built in GFI) blow out and had to bypass/put different chord on. there are fuses on the control board but I would check that last
Jun 24, 2011 | Frigidaire FAS257S2A WallWindow Air...
Does the 15100 Kenmore BTU need a dedicated line in order to not blow a fuse?
Is this a 120 volt unit? If so, you might try to find the amp rating on the unit itself. A 120 volt unit that big will have to have a circuit all by itself. Probably a 20 amp breaker, no less than 15 amp just for the air conditioner.
If it is 240 volt, it will definitely have to have its own circuit.
Jun 21, 2011 | Kenmore Multi-Room Air Conditioner
Does the Kenmore model 75180 run on 220 volt or 110 ??
Chuck, your particular model (which has been discontinued) had two different models with 115 volt (110 is no longer around) and 250 volt.The rating should be on the manufacturer's serial data plate. Also, you may be able to tell by the power cord that was furnished with the unit.
I have included a link to you Owners/Installation Manual, which will provide more information on how to determine what voltage rating your specific unit has.
http://www.managemylife.com/mmh/owner_manuals/23524/KENMORE-Air-Conditioner-Room-%2842%29-LR707330?brand_name_search=58075180700+KENMORE
Hope this helped you. Please let me know. Thanks.
May 18, 2011 | Kenmore 75180 Wall/Window Air Conditioner
Does the breeze at have one or 2 fuses
It has one fuse. A 1.0 Amp slow blow for 110 volt models and 0.5 Am slow blow for 220 volt models.
Nov 30, 2009 | Ecoquest Breeze AT Living Air Purifier
Will not turn on Have checked switch under filter Have checked continuity of the fuse plates are making contact Ecoquest Breeze AQ
Have you checked the fuse? It is located in back of the Breeze in the fuse holder next to where the plug connects to the purifier. It uses a 1.0 Amp slow blow for 110 volt models and 0.5 Amp slow blow for 220 volt models.
Oct 28, 2009 | Ecoquest Breeze AT Living Air Purifier
Have a kenmore dryer model 110.96586400 it has a brand new heating element and will not blow hot air. what else could it be and were can i get a manual for this unit?
do you have 220 volts to receptical? if so check the thermal fuses in the back going to the element. the tub will turn on 110 volts maybe the breaker is only letting 110 volts to the dryer. i have seen it happen before.
Apr 18, 2009 | Kenmore Dryers
Purifier doesn't go on and keeps blowing fuses when turned on
If the machine keeps blowing fuses there is a short in the electrical circuit and it needs to be looked at by a certified repair center.
Make sure the fuses you replace are the same as the original
100,110 volt models use the 1.0 amp slow blow fuse
220 volt models use the 0.5 amp slow blow fuse.
I hope this helps
Eric
Jan 10, 2009 | Ecoquest Breeze AT Living Air Purifier
Working with 220 v
If you are looking for a "window" type of unit yes there are some 220 volt units on the market. Most are large like 18,000 btu or larger. Check Lowes, Home Depot or larger appliance retailers for availability. Also know when buying if you need a heat strip, or heat pump if indeed you want heat.
Nov 15, 2007 | Kenmore 75085 Air Conditioner
Heating & Cooling Logo
211 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
