Question about Gateway Computers & Internet
(GRA) code on monitor. tower just beeps
Monitor only shows a code for just a few seconds (GRB) then it goes sleeps mode. the tower just beeps.
  • 2 more comments
  • rcampbell197 May 24, 2009
    5 beeps a short pause, then just continously beeping. all are short beeps
    the fan works. maybe not up to par
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    How many beeps are there and are they long or short?
    Regads
  • fougzki May 11, 2010
    Is it like the monitor is not receiving signal from the CPU? Does CPU fan works?
  • 700 Answers
I also would say clean your memory card and the video card if it is a plug in type its edge connector both side with a clean soft eraser. Do this when you unplugged the CPU unit in wall socket or UPS(no power absolutely). This is the first step before going to anything.
So leave a comment if it doesn't help.
Posted on May 25, 2009
  • Gateway Master
  • 4,806 Answers
Hi there.
GRB means the 3 primary colours and just means the monitor is working and able to receive a signal.
I think in your case it could be related to memory. Remove any new hardware if any and any external devices like printers etc.
Now remove the power cord from the back and remove or open the side panel from the tower so you can get to the motherboard, remove the ram (memory) from the slots and clean the dust from both the memory modules and the memory slots, when they are free of dust just put one module back at a time and restart the PC (if you have more than one)
If it boots up the problem would have been dust, if it doesn't start up at all it well be faulty memory.
Please post back if you need more help or advice.
Good luck and thanks for using FixYa!!
Posted on May 24, 2009
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
My monitor goes in sleep mode after few seconds. how to swich off sleep mode on monitor?
Just go to Power Option of your computer under the >CONTROL PANEL
> click the power option and you will see the
>balanced
click change plan settings
>turn off the display to "NEVER"
and
> Put the computer to Sleep to "NEVER"
hope it helps...
Sep 08, 2010 | Computers & Internet
My hp2009m monitor goes into sleep mode
Monitors are programmed to go to sleep when there is no input. If you shut it down on the other "tower" also it will do the same. You need to physically hit the power button on the monitor to actually shut it off.
Feb 15, 2010 | HP Computers & Internet
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
Monitor goes into Sleep Mode immediatly upon turning on computer
Ok. I think "sleep mode" means that your monitor might not have a tight connection. Tighten all connections. Also, push the power button on your tower. When you gegt back, go to screensaver- power settings- and from there you can adjust.
May 24, 2009 | Dell Dimension 3000 PC Desktop
Monitor only shows a code for just a few seconds (GRB) then it goes sleeps mode. the tower just beeps. this is 8 bip
check the memory of your pc and try remove it to the memory slot put it back again switch your computer make sure the pc is turn off before your remove the memory
May 24, 2009 | Shuttle MV43VN Motherboard
Sharp light turns green thern turns yellow screen goes black
it is going into sleep mode, good luck with this.... i am currently asking how to get my hard drive to quite putting my monitor into sleep mode.
although it hasn't worked for me because my screen stays black, one of the options given to me is to try to start in safe mode and then adjust your settings to "never" on the energy/sleep/hibernate mode
some one else suggested that i remove and reseat the video card
hopefully one of those will work for you
Feb 14, 2009 | Sharp LL 172A-B 17" LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Computers & Internet Logo
139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
