Question about Sony VAIO Digital Studio VGN-AR320E Notebook
Horizontal colored strip just to the left of the middle of the screen
I have a Sony Vaio and all of a sudden a horizontal colored strip appeared down the middle of the screen
  • mimgallagher May 24, 2009
    Thank you for your help... unfortunately I am unable to check the screen by hooking up to a TV... for some reason the s-video cable is not making connection.... anyway I am in Mexico so will have to wait until I return to the USA on June 3. I do not think it is still covered under warranty... it is probably 2 years old. Thank you.
  • Sony Master
  • 13,433 Answers
Those issues can be caused by either loose connector cable between the display and the motherboard. Or a fault in the video adapter / card. Last possibility is faulty display panel.
To find out if the video adapter is the cause you could connect the laptop to a external display a crt or lcd (the display that is used by your desktop pc, you should have a connector on the laptop for somekind of external display)
if the horizontal strip appears on the external display then the fault is internal on the video card, and there is no home fix.
Is the laptop covered by warranty?
Most of these causes can't be home repaired, the loose cable can be easyly repaired at home, but a faulty motherboard / video adapter is very difficult to repair. The lcd panel also would most likely have to be replaced if it was the cause.
If the lines appear after some time of using the computer, they could be a sign of overheating or damage from overheating.
Posted on May 24, 2009
  • Ekse May 24, 2009
    Okay,
    if the problem only happens when you have been using the computer for a while it could be overheating and you might be able to help the problem by cleaning the fan with canned air and make sure theres no dust on the fan / its heat sink.
    you might also want to try a laptop cooling pad that goes under the laptop, those two things might help it enought so it doesn't do it constantly.
Sony FD Trinitron WEGA KV27FS100 horizontal lines across top part of screen
Check and replace all electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them to replace. Replace all at one time. The fault you describes here is technically known as 'vertical retrace lines'. Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 990 posts to different brand TVs now. Sometimes, you might get some more details from there.
Oct 13, 2012 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have purchased Sony Bravia LCD BX 42, which has a very thin horizontal line across the screen, how to fix the problem
my sony bravia BX42 has a color green horizontal line and it makes bigger and bigger until some color pink was appeared then I am worried if it will not turn to normal as it goes :(
Aug 29, 2011 | Sony BRAVIA KDL52XBR2 Television
Hello, I bought an LG 47LH50 HDTV exactly 1 1/2 years ago. Black horizontal lines suddenly appeared one night after getting home from work. Over the past two weeks I've seen it go from 3 lines, to 4...
Hi, I purchased the same model in November 2009. About 2 weeks ago a single horizontal line appeared. Each day another appeared until today when the video went out. Now it displays bands of vertical colored lines like a pastel colored rainbow. Did you find a solution to the problem?
Jun 04, 2011 | LG 47LH50 47 in. HDTV LCD
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
I have a horizontal color line across the screen...have sound .This is on Video 1
If you are comfortable working inside the set and can solder, try resoldering both the vertical IC and the input jack connections. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It will be marked LA7837 or something similar.
Let me know the results.
Dan
Apr 15, 2009 | Televison & Video
Hitachi 51SWX20B Convergence problem
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2008 | Hitachi 51SWX20B 51" Rear Projection...
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Sony VAIO Digital Studio VGN-AR320E Notebook Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
