Question about GE Refrigerators
Water pools on floor
Both sides of the fridge on the floor are wet in the morning is the drain easy to unplug
  • 1,543 Answers
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
Posted on May 24, 2009
Water pooling under right front of refrigerator
is there any ice on freezer floor or is the bottom rack iced in?if so you have a blocked drain in the freezer,or if that's ok you could have a crack in one of the plastic water lines,also check the catch pan where the water drains into when the fridge defrosts,you can pour water down the drain in the freezer to check that,roll the fridge forward and take the bottom panel off the back,should be easier to check for leaks and take off the front kick panel,while you're in there vac out all the dust in there,front and back,you should do this every 6 months
Jan 23, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water on floor under front of fridge
CHECK AT THE BACK OF YOUR FRIDGE IF THE DRAIN PIPE IS STILL ON THE COMPRESSOR. ON TOP OF THE COMPRESSOR THERE IS A BUCKET WHERE THE WATER FROM THE DRAIN PIPE RUNS IN. THE HEAT OF THE COMPRESSOR CAUSES THE WATER TO EVAPORATE.
Sep 07, 2009 | Refrigerators
Water and ice pool in bottom of fridge
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jun 30, 2009 | Refrigerators
Water collecting below veggie compartments water inside
Take you bastor and find the drain hole and blow air into the line to open it up. The drain from inside to the pan is clogged.
Jun 11, 2009 | Whirlpool ET1FTKXK Top Freezer...
Water on floor
is possible that the plastic tube that leeds in the pan is obstructed or in a wrong position, check if water goes in the pan just put some water trought from the inside hole in the fridge and check if it reach the pan, maybe the inclination of the fridge is not sufficient, ( it has to be inclined to the wall direction so the water slides on the back inside wall of the fridge. can also be poor insulation of the fridge, so the outside surfaces come wet because of the hight air temperature outside and the cold surfaces of the fridge, then the water slides down the floor...make sure about air ventilation around the fridge!...I hope it was useful!
Jan 08, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water on base of the refigerator
find the drain hole and unblock it faily easy on a fridge on the side by side more difficult need to unplug defrost it remuve the bottom panel inside in the freezeer side of the appliance to access the drain tray do nort attemt to remuve the panel while iced up dfrost is must or coud cause serious damage
Nov 13, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fridgidaire Gallery Series Side by Side Refridgerator
"jennycub" sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine. very common problem( easy to detect. water on the floor of freezer compartment) as far as the other posting by" humblerumble", ive seen where the drain tube under the refig has pushed a hole into the drain pan under the refrig, in which case it will only leak after a defrost cycle, with the kickplate removed grab a flashlight and look under the unit for the drain pan as you pur water into the back of the freezer sect to trace water flow
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
WATER pooling in bottom of fridge
did you try to remove the 2 ***** in freezer floor???. if not remove the floor and check for ice build up underthere, if so:
you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Mar 12, 2008 | Whirlpool ET8RHMXKQ Top Freezer...
Refrigerators Logo
96 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
