Question about Cameras
I have the canon 5d together with the latest speedlight flash ,best settings for fil in flash ,colin.
    Sergeant:
  • 296 Answers
Hi Colin
these r some fantastic article which gives an indepth knowledge about best flash settings,kindly go thru the links below:-
http://www.gumtree.ie/dublin/26/37496226.html
http://www.amazon.com/Canon-430EX-Speedlite-Flash-Cameras/dp/B000AO3L84
http://www.wonderhowto.com/how-to-tutorial-for-canon-speedlite-580ex-ii-flash/
hope u will b helpfull
all the best
regards
Posted on May 24, 2009
Does the ste2 transmitter work on a canon 5d with a 58011s speedlight?
This is an IR transmitter and as long as your EX 580 II works with IR you'll be OK
Jul 13, 2014 | Canon Eos Cameras
Canon 550 ex speedlight - flashes okay. Won't sink with 60d (tried different cameras at dealer - same problem) Camera is okay .
Bruce,
Try these steps:
1. Set camera to manual2. Set shutter to 1/60
3. Set aperture to F5.6
4. ASA/ISO 200
5. 550EX on hotshoe
6. Do not set on slave or master
7. Turn on flash
Display must shows, ETTL.
If that doesn't work, you have to use the flash on manual.
Some of this model will not work fully on ATG Canon EOS-1D C, ATG Canon EOS-1D X IR, Canon EOS-1D X/60D/T4i because this flash is over 20 years old.
Unless you would want it to be modified by me.
But that can be costly when you can get the 580EX II for less than $425.00 USD.
atdlee@netzero.com
Jan 01, 2013 | Canon Speedlite 550EX TTL Flash
Canon 580exii speedlight, I want to only use the slaves, but they won't fire when I turn off the master
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
atdlee@netzero.com
Nov 17, 2012 | Canon Speedlite 580EX II TTL Flash
Can I use Speedlight SB-50DX with Canon EOS Rebel Xti
It is not possible to use the Nikon SB-50DX directly on a Canon EOS Rebel camera. The Nikon flash gun hot shoe contacts do not match the Canon hot shoe contacts.
You can use the Nikon as a slave flash gun with a PC flash cord that matches the Nikon's flash contacts then connect the end of this flash cord to a flash trigger. The Canon's flash can then trigger the Nikon flash gun via the flash trigger.
Dec 27, 2011 | Nikon Speedlight SB-50DX TTL Flash
Hi, I am going to use this flash with Canon 5D mark II. And I have Canon 5D. What I need to by..adapter, or update old adapter? Please help me out. Sincerely Oleg Ratner
Just the PC Sync Cable that came with the flash.
Open the left side (rubber flap) of the camera, insert the the cable into the silver round circle with a center dot (camera's PC Sync Socket.
Set camera to "M", ASA/ISO to 400 on both, set 125 on camera, set camera/flash to F5.6.
atdleeatnetzerodotcom for more help.
Oct 05, 2010 | Metz Mecablitz 60CT4 TTL Flash
How to add EX 580 flash external
You need the wireless adapter for this, you cannot do this with the camera.
Oct 19, 2009 | Canon EOS 5D Mark II Digital Camera
Canon 5d
Make sure you have your flash & timing set where it is supposed to be, usually between 120 & 180. This is the shutter timing and flash duration. It is the syncronizing speed setting. If possible, turn off the automatic review, this slows things up. Also, if possible, use a power cord for the flash instead of batteries. Not all have this feature but, the flash is ready for the next shot in about 1 second.
Jan 27, 2009 | Canon EOS-5D Digital Camera
My Canon EOS 5D consistengly overexposes images by approximately 2/3 stops..both in natural light and flash situations. The problem is particularly bad outdoors. Can this be fixed?
try updating firmware from canon website latest version 1.1.1 check your camera to see which version firmware you are runing can cure lots of weird problems.
Oct 02, 2008 | Canon Cameras
Cameras Logo
129 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
