Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine won't Start
I have a craftsman 17 hp model 917.271653 lawn tractor. The problem is the engine won't "turn over". When I try to start the engine it just "clicks". I replaced the battery, and it did the same thing. Then I removed and tested the starter - it seemed fine. Further investigatin showed oil pooling in and around the airfilter (my father told me the week prior he added 1+ quarts of oil). I then drained all the oil and filled with required 3 qts. I turned the flywheel counterclockwise until it was extremely difficult to move. At the same time i lowered the gear on the starter. I tried starting the tractor. It seemed to crank the engine up to the point the flywheel became difficult to turn. Any suggestions would be greatly appreciated.
  • dselheimer May 24, 2009
    Correction, once I drained the oil I added 3 pints. Took your advice removed and cleaned plug. The engine cranked and then started. Once started it blew out quite alot of white smoke. I then shut it off and had difficulty some difficulty starting. Once started, I once again had quite a lot of white smoke. Is this normal until the engine/oil problem rights itself?
  • dselheimer May 25, 2009
    Worked perfectly - Thanks
  • 376 Answers
If you have 3 qts. of oil in your mower, drain it immediately. It only holds 3 PINTS or 48 ozs or 1 1/2 qts. Next, remove your spark plug and put the end away from the hole (to prevent possible arching and fire) and crank the engine over. Probably, a lot of oil/gas will blow out, clearing your cylinder. Clean the plug and try to restart. If it still reaches a point where the engine will not turn past while trying to crank, the valves need to be readjusted. Also check by smelling the dipstick that there is no gas mixed in the oil. That would mean your carb needle and seat are leaking.
Posted on May 24, 2009
  • Dwain Pippen May 25, 2009
    Again, very important, be sure there isn't any gas mixed in your oil. If it had too much oil in it before, some could have been sucked into the oil breather and flooded out the cylinder which would have put it in the muffler too. It may take a few minutes to burn it all out. If it doesn't burn off, you might have a lesking head gasket. Let me know. Dwain
Huskee madel 13af673h131, won't crank
I guess you were sitting on the seat while trying to start the unit, so Try to apply power direct to the starter, if it turns over buy a solinoid. If it doesn't the starter may be bad. To check the engine: take out the spark plugs and try to turn over the engine from underneath by hand, using the pulley. This will tell if the engine is siezed up
Apr 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman Intek Plus 18 HP engine won't crank
Adjust the valves. I had the same problem.
Jun 15, 2013 | Craftsman Garden
Does Craftsman Model 917.272461 have a low oil shut down sensor?
Sounds you added oil for late. Can you turn engine by turning engine
on the screen, top of engine?
Aug 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I was engaging the blade on my 17 hp craftsman lawn tractor and the engine died. Now the engine won't turn over. ???
the motor wount turn over if in fact the belt is tight around the motor pully. remove the deck belt then also make sure there are no switches not working.
Nov 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Electrical schematic
i need a diagram for the ignition switch on my craftsman mower
....7 prongs all labeled with letters sure what 3 are for not other 4
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Missing oil dipstick
Hello:
You can Purchase a New Dipstick from your Local Small Engine Service Center or Online.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
495 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
