Question about Sony VAIO VGN-T1XP/L Notebook
Hi I'm llokig for a new hard drive for my vaio vgn t1xp but having difficulty as it is very small nad has a funny connector!
  • davidorenste May 24, 2009
    Hey,
    Is it possible that it could be IDE as the ard drive in my viao has male pins on the outside?
  • Sony Master
  • 4,806 Answers
Hi there.
There are normally 2 kinds of hard drives in laptops at the moment apart from solid state HDD's which are mainly in Acer Onebooks etc.
2.5ins IDE HDD which looks like this >>>>>>
2.5ins SATA HDD which looks like this >>>>>
It will be one of these type of hard drive which goes into the Viao probably the SATA HDD.
Good luck and thanks for using FixYa!!
Posted on May 24, 2009
  • Lee Hodgson
    Lee Hodgson May 24, 2009
    Hi there.
    If all the male pins stretch right across one end of the hard drive then it will be a 2.5ins IDE/ATA hard drive.
    Kind regards
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Hi, Im trying to re-install windows xp pro sp2 on to my sony vaio vgn-t1xp. i booted from the cd, deleted the partitions that were currently on the harddrive, and then went on to format it (NTFS). once...
Once the setup files are copied don't let it boot from the cd-drive anymore, at the prompt "Press any key to boot from cd...", please do not press any of the keys. However you do require the cd in cd-rom for the rest of the setup.
Jul 18, 2011 | Sony VAIO VGN-T1XP/L Notebook
My Sony VAIO VGN-T1 has a 40G hard drive which I want to upgrade to around 320G or as high as possible. I am told 80G is the biggest available in SSD HDD & that to go any higher will be a lesser...
Not the case at all. Capacities range from 8GB all the way to 2TB. You won't get as much storage space per dollar from an SSD but the performance gains will be substantial.
Feb 26, 2011 | Sony VAIO VGN-T1XP/L Notebook
Dear Sirs Please advise 1) how to upgrade memory and hard drive on the VGN-T1XP/l notebook and 2) the cost of these two items/ Best regards Frank Beedie
The VGN-T1XP can use a maximum of 1gb of RAM! It has two slots, one already filled with 512mb, so you need a second of the same size.
Unfortunately, there are no simple covers to remove to access the memory or HDD - so I would assume you need to take the machine apart! So check with a REAL expert first....
Dec 22, 2009 | Sony VAIO VGN-T1XP/L Notebook
I need Replacement Sony Viao laptop screen
Ebay mate...that is the place to get them whether there or here. Prices are good and the job is not a tough one if you have the manual
Oct 10, 2009 | Sony VAIO VGN-T1XP/L Notebook
The notebook does not start
It could be yes, but not always. It can be RAM failure, battery failure, Add-on card failure. first thing to check is its power source, then RAM, Add-on card, checking also it power button. Sometimes non booting unit is only due to dirty contact.
I usually check its power source, then clean the RAM with soft eraser, if that doesn't help I try to check other add on card. Next is it drive I disconnect them then try to power up without the drive if it can able to POST.
Apr 16, 2009 | Sony VAIO VGN-T1XP/L Notebook
Port replicator/docking station
I have a docking station for sale for this exact machine - reason for sale is that the machine has developed an intermittent fault so I have replaced it. It is a great docker with 3 USB, 1 printer, 1 monitor,1 network and DC in (takes computer power in). It got me up and running in home office very fast. The model number written on the back is VGP-PRT1. It is about 11 inches in length by 4 inches widt and at max 1 inch in height
Jan 25, 2009 | Sony VAIO VGN-T1XP/L Notebook
Ethernet drivers for sony vgn-fs115m
Hey MIDO Try This Tool
VAIO Launcher 1.4.11 Update Program
This program will update VAIO Launcher pre-installed on the VAIO model listed below.
VGN-S4HP/B
VGN-S4HRP/B
VGN-S4M/S
VGN-S4XRP/B
VGN-S4Z/S
VGC-V3S
VGC-V3M
VGN-FS285H
VGN-A497XP
VGN-A417M
VGN-A417S
VGN-FS295XP
VGN-FS215Z
VGN-FS215M
VGN-FS295VP
VGN-FS215B
VGN-FS215E
VGN-FS215SR
VGN-FS215MR
VGN-FS285M
VGN-FS285B
VGN-FS285E
VGN-FS215S
VGN-B3XP
VGN-B3VP
VGN-S4XP/B
VGN-S4VP/B
PCG-K415S
PCG-K415B
VGN-FS195XP
VGN-FS195VP
VGN-FS115S
VGN-FS115Z
VGN-FS115M
VGN-FS115E
VGN-FS115B
VGN-FS115ZR
VGN-FS115M -- ( Thats Ur MODEL)
VGN-A397XP
VGN-A317S
VGN-A317M
VGN-S3XP
VGN-T2XP/L
VGN-T2XP/S
VGN-T2XRP/S
VGN-S3VP
VGN-S3HP
VGC-RA304
VGC-RA204
PCV-RS704
PCV-RS702
VGC-M1
VGC-V2S
VGC-V2M
VGN-T1XP/L
VGN-T1XP/T
VGN-B1XP
VGN-B1VP
VGN-S2XP
VGN-S2VP
VGN-S2HP
VGN-S2XRP
VGN-S2HRP
VGN-A297XP
VGN-A295HP
VGN-A217S
VGN-A217M
VGN-A215M
VGN-A215Z
PCG-K315Z
PCG-K315S
PCG-K315B
PCG-K315M
This update resolves the problem of registered applications not launching from the VAIO Launcher toolbar.
Note: This program requires VAIO Zone 1.2.05 or later. If your VAIO model comes with VAIO Zone 1.2.02, you must first update VAIO Zone before running this program.
Download and installation
1. Download the file SOAVZN-01028300-UN.exe and save it to a download directory
2. Close all running applications
3. Go to the download directory and double-click SOAVZN-01028300-UN.exe
4. The InstallShield wizard starts
5. Click Next and wait while setup is installing the new software
6. Click Finish when the installation is complete
HERE
Apr 15, 2008 | Sony VAIO FR130 Notebook
Sony VAIO VGN-T1XP/L Notebook Logo
265 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
