Question about Refrigerators
Freezer has 4 levels of coils, one at ceiling, three under grid shelves; bottom two are virtually free of frost, upper two are constantly icing over with ice/frost up to 1/2 inch thick
Coils at ceiling and first level constantly ice up; lower two coils have minimim frost
  • 78 Answers
Switch off the fridge for 48 hrs u r problem solved
Posted on May 25, 2009
Fridge warm, freezer has frost on back panel & is defrosting, fans work, just changed defrost thermostat, no air is moving from freezer side to fridge side, drain pan under fridge is dry
this fan needs to run when the compressor runs,check fan blade for being jammed by ice if you have this much ice on back wall as ice will stall motor,if no fan there will be no cool air to refrige compartment also the defrost drain tray will fill with water then freeze over which in turn floods the freezer floor and refrige compartments cause it cannot drain to the pan in the bottom
May 11, 2012 | Kenmore Side by Side Refrigerator
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
We have Kenmore Model 7018 2000 and we have water inside the refrig on the shelves on top and on the very bottom. Don't know where to begin to look.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 01, 2011 | Kenmore Refrigerators
Meat on top two shelves unthawed while bottom two shelves is frozen and has stayed frozen for three days. Air does not appear that cold coming out of top of freezer.
hi... is the evap fan motor running in the freezer ? if it is then check the the evap coils if it is completely frosted then u need to check the defrost timer .if that is good then check the defrost limiter that is on the evap coils and if that is good then u got a bad defrost heater. now if there is frost only on the bottom or top of evap coils u may have sealed sys problem if u got an ? feel free to write me..
Apr 19, 2011 | Kenmore Freezers
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
The upper portion of the freezer turns off, causing the ice to melt. And the cooler side bottom drawer turns into a freezer. I can't figure out what's going on.
You have a frost blocked evaporator. Translation: The cooling coils, located behind the back wall inside the freezer section, have plugged up with frost (usually caused by a burnt out defrost heater, located at the bottom of these coils) which prevents the cold air from circulating inside the freezer, and into the top of the fresh foods section. At the same time, this blocked air flow allows very cold air at the bottom of the freezer section to migrate back into the bottom of the fresh foods section, and thus freeze item in the bottom bins of the refrigerator. Unload the freezer, take the shelves out and remove the back panel. Melt the frost with a hair blower, and change out the heater at the bottom.
Jul 08, 2010 | GE GSS25SGMBS Side by Side Refrigerator
I have the 10 year old freezer on bottom and i constantly get a layer of ice on the bottom of my freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 24, 2009 | Refrigerators
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
