Question about Nintendo Wii Console
Black screen on boot
My wii boots and loads discs..and there is sound ..the wiimote does sync as well...but there is no video at all..I changed the bluetooth for a new one and changed the dvd drive motherboard...is there a bad cap or resistor??...or is this software related...I don't know the history of the console...I got it this way...there is no chip installed and no sd card...I have taken it all apart...what should I be looking for??
  • 34 Answers
This might be a bit too simple, but if you swapped out all the hardware, have you tried swapping out or purchasing a new cable?Cables can periodically go bad, or be faulty from the start, so I'd reccomend trying a new one. The HD component cable can be purchased pretty cheaply online. I personally got the NYKO component cable from amazon for pretty cheap and it works great.
Posted on May 24, 2009
Wii remote four lights solid
Sounds like it needs to be re synced with the system, Easy place batteries in Wiimote and turn on console press the red sync button in the back of the Wiimote and press the red sync button on the console it is now synced. If this fails it could be that the Wiimote has failed, if Wiimote had failed within warranty period of 90days from date of purchase return for repair or replacement if it is after warranty period discard and replace with a new Wiimote.
Jan 12, 2013 | Nintendo Wii Console
We tried to reset the sync buttons and the blue lights on the remote blink repeatedly but it still does not communicate with the game
Try removing and reinstalling the batteries from the wiimote and the unplug the wii power cord at the outlet end for a couple minutes. I had that problem once and this seemed to fix it.
Mar 07, 2011 | Nintendo Wii Console
The sensor is not recognising the remote and i have tried syncing and changing the batteries but its not working
Make sure that everything is plugged in correctly. If the problem persists, then try and see if you can get parts that work.
Wii wont turn on
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that dosent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
May 20, 2010 | Nintendo Wii Console
Now reparing
This is an April fools joke as preloader has been installed on your wii, just press A on your wiimote to boot as normal
Apr 02, 2010 | Nintendo Wii Console
The wii remotes will not hook up to our game console how can i connect it?
To setup your Wii Controllers. Open the back of your Wiimote and insert the two AA batteries as indicated in the battery panel. Leave the cover off after you've inserted the batteries.
Turn on your Wii from the front of the console. Allow the Wii to cycle to the main menu.
Open the front door on the front of the console to reveal the SD card input and the "Sync" button.
Press the "Sync" button on your Wiimote, located just underneath the batteries. When it is in Sync mode the LED light will flash.
Press the "Sync" button on your Wii console to connect the signals and allow the controller and console to sync. This may take a few seconds, so be patient while it continues to connect.
Watch to see if the LED has stopped blinking. Once it has, your Wiimote is now connected to your Wii. Put the battery cover back on.
Use One-Time Synchronization to change the way the Wiimotes are synced to the console. You can do this by pressing the "Home" button on your controller and choosing "Reconnect." This is useful when you wish to change the player/controller layout without passing different Wiimotes around and losing track of which is which. One-time mode is reset to Standard once the Wii is restarted.
Feb 15, 2010 | Nintendo Wii Console
I cannot get a cursor on the menu screen of my wii. i can access the menu screen, but I can't select the game.
Sounds like you haven't syncronized you wiimote to your console. - Turn on Wii - Press the red sync button behind hatch on wii front. - Press red sync button behing batterry hatch on wiimote. That should be the hard part. Possibly you can be required to access. To do the pressing of button 1 & 2 at the same time to reconnect. But red buttons are for initial sync.
Jan 08, 2010 | Nintendo Wii Console
Wii controller wont pick up guitar controller. The guitar has the wii remote, and have plugged the vocals into USB - it picks up the mic for vocals but not the guitar
Make sure that you've synced the Wimote with the Wii. you can do this by pressing the red button on the wii by the SD Card slot and press the red button on the Wiimote under the battery cover. You can also sync the Wiimote's by pressing the home button, clicking on the Wiimote on the screen, and then clicking Reconnect the Wiimotes I believe. When doing this, just hold down the 1 and 2 button. If your Wiimotes don't need to be sync then theres most likey something wrong with your Guitar Hero Guitar. that's the only other possible outcome I think. Unless then Nunchuck hookup is somehow broken. Doubtful though. Those Wiimotes are FEIRCELY strong. My dog, who can chew though a hard plastic chair, could only leave dents in the Wiimote he chewed on. (Bad Dog!) Hope you get it working!
Jul 07, 2009 | Activision Guitar Hero World Tour Guitar...
Connect wii my controller
1 Open the back of your Wiimote and insert the two AA batteries as indicated in the battery panel. Leave the cover off after you've inserted the batteries. Step2 Turn on your Wii from the front of the console. Allow the Wii to cycle to the main menu. Step3 Open the front door on the front of the console to reveal the SD card input and the "Sync" button. Step4 Press the "Sync" button on your Wiimote, located just underneath the batteries. When it is in Sync mode the LED light will flash. Step5 Press the "Sync" button on your Wii console to connect the signals and allow the controller and console to sync. This may take a few seconds, so be patient while it continues to connect. Step6 Watch to see if the LED has stopped blinking. Once it has, your Wiimote is now connected to your Wii. Put the battery cover back on. Step7 Use One-Time Synchronization to change the way the Wiimotes are synced to the console. You can do this by pressing the "Home" button on your controller and choosing "Reconnect." This is useful when you wish to change the player/controller layout without passing different Wiimotes around and losing track of which is which. One-time mode is reset to Standard once the Wii is restarted.
Jul 22, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
224 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
