Question about Canon Office Equipment & Supplies
Need to set up network home printing
Trying to set up home network. Need IP address for PIXMA MP 190 series to complete? Where do i find it?
  • 85 Answers
Ok I looked up your printer and in the specs I don't see that it has a network interface. So this means the printer has to be attached to a pc that is on the whole time so it can be shared like a folder to be useable in the network. This will not require you to have an IP address for it.
Posted on May 24, 2009
How do I find ip address for canon pixma mp 495 printer?
Two links for you
Pixma MP495 Printer not detected - Canon Community
community.usa.canon.com/t5/Printer-Multifunction.../Pixma-MP495-Printer.../25583
  1. Cached
  2. Similar
May 26, 2013 - So I have a Canon Pixma 495 printer that worked great wirelessly ... Hi I have the Canon Pixma MP495 and I can't seem to find the IP address.
PIXMA MP495 Wireless Connection Setup Guide - Canon Europe
www.canon-europe.com/.../pixma_printer.../mp495_printer_wireless_connection_set...
  1. Cached
  2. Similar
This method is by far the easiest way of connecting your PIXMA MP495, so if your ... Press and hold the [Maintenance] button (A) on the printer for approximately 5 ... regarding pressing the WPS button, please refer to the access point manual.
ip address for canon pixma mp 495 printer Google Search
Oct 04, 2016 | Canon PIXMA MP495 InkJet Printer
Set up wireless
Wireless Method:
  • Make sure your printer has wireless network adapters or a wireless router.
  • Power on the printer and wireless router.
  • Configure the printer to connect the wireless router.
--Enable the DHCP option on the printer. Obtain the IP address automatically.
--Configure the DHCP server of wireless router. Again, assign the IP address automatically.
  • Verify connectivity. Try doing some test prints. If it doesn't work, check the IP addresses.
Network Method:
  • Assign the printer to a wireless network. Go to "Start" and click on "Devices and Printers."
  • Click on "Add a printer".
  • Click on "Add a network, wireless or Bluetooth printer."
  • Select the wireless printer from the list. Click "Next."
  • Allow Windows to successfully connect the printer. Again, click "Next."
  • Click "Finish" to complete the process. If you have multiple printers on your network, set this one as the default. Verify the connection by clicking "Print a test page."
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 14, 2013 | Canon PIXMA MG4220 Wireless InkJet MFC /...
I have just purchased a Dell laptop with Windows 7 home premium installed. I have a Cannon PIXMA MP495 printer, what do I need to do to operate thist printer wirelessly?
If you have a wireless router with a wireless network then -
Configure the IP address your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but at a higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the your printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 28, 2012 | Dell Computers & Internet
DEAR SIR, I CANNOT ABLE TO PRINT THROUGH PRINT SIR PLUS 10/100 PRINT SERVER (PS1203) THROUGH NET WORK. I CONFIGURED EVERYTHING BUT I CANNOT ABLE TO PRINT. REGARDS BASHEER
If you have configured every thing correctly , the problem may be with the network cable. There are (2) types of network cables are available.They are 1). cross net work cable ,2). Parallel network cable. I think you have used the parallel network cable. Now try to purchase the cross network cable or you may prepare it if you are awre about it. Hurray ! your problem will be solved automatically.
Even though if your problem is not solved , kindly follow the instructions as follows;
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ). According to above addresses, you have to complete the networksettings of your printer by mentioning the different IP address .
To find out the above mentionedaddresses first open the control panel -> network connections -> local areaconnction -> properties -> Internet Protocol Version 4(TCP/IPV4) ORInternet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection asmentioned above you will get the IP address, subnet mask and Gateway addresses.
Suppose your IP address is 192.168.0.10 , thegateway may be 192.168.0.1 Or any number. And the subnet mask may beXYY.XYY.XYY.0.
Accordingto your ISP addresses you have to complete the network settings of yourprinter. First press the additional functions -> system settings ->network settings -> TCP/IP settings -> fill up the addresses as follows.
IP address : 192.168.0.16 OR any number .
subnet mask : XYY.XYY.XYY.0.
Gateway : 192.168.0.1
Hurray ! the problem about your networkconnction with the printer to your computer will be automatically solved.
Sep 28, 2010 | Edimax PS-1203 Print Server
How do I set up network printing?
The PIXMA MP240 doesn't have the Ethernet port so it doesn't have the network printing, but there is a way to use it in your network, it's by sharing your printer in your network with other computers. here is the link to learn how to do it:
http://www.home-network-help.com/share-printer.html
The most important thing is that the printer and the computer connected to should be always on.
Best Regards,
Oct 30, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
Jun 06, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Reset Dell 1720dn network address to get back access to it?
Please have a look if you have Dell 1700 series laser printer. Please follow the instruction bellow to reset printer to factory default: 1. Power Off the Printer from the back switch from the back 2. Open Front cover 3. Hold Down “Continue” & “Cancel” button while turning printer on
se http://digg.com/hardware/How_to_Reset_Dell_1700_1700dn_1710_1710dn_1720_1720
Regards Anders.Thornberg.Qnetcom.se
Dec 28, 2008 | Dell 1720dn Laser Printer
DP-190 Network Printer
I succeeded in printing via network to the Panasonic Workio DP-190.  Here is a brief summary of what needed to be done...
* HP laptop w/ Windows XP SP2 installed * requires LPR support via "Print Services for Unix" to be installed from Windows Components (http://technet.microsoft.com/en-us/library/bb457002.aspx) * Installed using GDI printer driver (http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/list.html)
During the GDI installation I choose a 'Network printer' and the printer was already setup for proper IP addressing, etc...
I created a new printer port of type LPR, doing so required me to input the printer's IP address and a queue name -- the queue name was left blank.
Hope this helps, John
Feb 28, 2008 | Panasonic DP190 All-In-One Laser Printer
76 people viewed this question
old marine
old marine
