Question about Hitachi 61UWX10B 61" Rear Projection Television
Has a shadow on picture. Red, Green is not alligned
Color just change then has a double image on everything. Please help
  • Daniel Hutchinson Dec 29, 2007
    magic focus on prod. 61uwx10ba doesn't work, and users manual states that green projection lamp is not adjustable but red and blue are. I'm not sure if I should attempt to manually adjust my the red. If I cover the red lamp blue and green match perfectly, it only shadows with on 1/3 of my screen.
    Problem Solver:
  • 5 Answers
Thanks, I checked manual still blurry on left 1/3 of screen
Posted on Jan 16, 2008
    Problem Solver:
  • 8 Answers
You need to set your convergence. Check your owner's manual on how to do it. I'm not sure the exact procedure on that model, but usually you can find it in the setup menu of the tv. What you're trying to do is line the red and the blue up perfectly with the green so that they all blend together to give you one picture.
Posted on Oct 21, 2007
Red images with green projected to the right with a green halo on upper and lower left corners
This set needs a fluid change. Between the face of the picture tubes and projection lens there is a layer of coolant fluid. The fluid has turned a milky brown color and is degrading the picture. The tubes have to be removed in order to do this properly. I would suggest you contact a repair shop and have them check it out for you as this can be very complicated. Thanks for using fixya and I hope this helps you out.
Nov 04, 2009 | Philips 43P8341 43" Rear Projection...
I am getting a double image on my 48 inch television how can i get rid of it? it is showing colors green and red on double image
Assuming that your TV is a rear-projection TV, then it sounds like the separate red, green & blue tubes aren't set correctly.
Each tube needs to be alligned exactly to produce the image on the screen. If any of the 3 are mis-alligned then the effect you describe is caused.
Somewhere in the menu settings, will be an option to set the Convergence. This option will allow you to set the allignment of all three tubes.
Older sets do not have this option, and need to be adjusted via controls on the main PCB.
Apr 22, 2009 | Televison & Video
Problem with RGB color...registering as green and image distorted
did u fix your tv cuz thats the same thing thats happening to me
Apr 15, 2009 | Philips 60PP9202 60" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Double picture & color problem
see if the mirror in side is broke or cracked
Jan 22, 2009 | Sony KP-53XBR45 53" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
RCA 56 inch hdwidescreen
Did you use the Automatica Convergence to try and straighten it out? If that does not help, you can manually adjust the convergence.
Jul 12, 2008 | RCA HD56W58 56" TV
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
TV PROBLEMS
If the images are different colors (red,green,blue) then the convergence has diverged. Some TV allow re-convergence through the menu screen, older sets my need to be physically adjusted (aimed) to clear this up. a strong knock to the TV may have cause this.
Apr 21, 2008 | JVC AV-56WP74 56" Rear Projection...
HDTV 1080i studio series
hi there, its a color allignment problem, the adjusting ring is in the neck of the picture tube, the unit is on while adjusting it to the correct image. ty
Dec 23, 2007 | Orion STV2763 27" TV
Hitachi 61UWX10B 61" Rear Projection Television Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
