Question about Starbucks Saeco Italia Digital Barista Coffee Machine
After descaling the two coffe cup lights keep flashing .
Also the red water light stays on. My instructions are in spanish so I can't understand what to do!
  • 1,089 Answers
Hi
You have finished the descale process and your descale light should be gone. Put a fresh tank of water on the machine and then open the steam knob. This should clear the water light and your machine will start heating again.
Posted on May 30, 2009
How to open the saeco odea
After descaling and rinsing, you need to hold the hot water button for 6 seconds to reset the descaling indicator.
Mar 26, 2013 | Saeco Odea Giro Plus Coffee Maker
The 7d(fill tank light) & 7e(descale light) are flashing simultaneously, what to do?
According to the manual, when both lights 7d and 7e are on at the same time, you need to contact Tassimo.
Sep 30, 2012 | Bosch Tassimo TAS1000UC 1-Cup Coffee Maker
Delonghi EC850 coffe mashine red light are flashing
I have a Delonghi Figaro and the red led flashing means:
The unit has run enough times to likely be scaled, this is a reminder to run weak acid (vinegar or citric acid) through to descale. Then rinse twice with clean water.
Scale will slow the brewing process so if it's brewing slowly you should do this regardless of the LED.
The LED can be reset by pushing <Prog.> and <On.> at the same time.
Of course, none of this is in the manual.
Sep 14, 2012 | Coffee Makers & Espresso Machines
Does anybody know how to get rid of flashing red exclamation light on my gaggia platinum vogue?
It does not need to be descaled as this is not the descaling indicator...The water circuit needs to be primed. Turn the knob to the water drop and drain water into a bowl. Hold the water drop button down while this is happening until the red light turns green. Presto.
Oct 07, 2011 | Gaggia Platinum Vogue 90800 Espresso...
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Red de scaling light won't shut off
Removing the red descaling light is simple.
1. Fill reservoir with half vinegar and half water (no need for the special descaling product from Tassimo).
2. Turn on machine.
3. Insert yellow cleaning disc found in back of machine.
4. This is where most people have the their problem...You must hold the start button for 3 to 5 seconds for the descaling program to start. Both green and red light will flash.
5. Once started, use a large cup to catch the output of water.
6. The machine will cycle through the descaling program in about 30 to 45 minutes. Be paitent!!!
7. Once completed, run many cups of plain water through the system to remove the vinegar taste.
8. Red light problem is solved.
Hope this works for you.
Apr 11, 2010 | Braun Tassimo Espresso Machine/Coffee...
My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
Mar 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Solis Palazzo Descaling (?) Problem? Please Help!
Hi
He has the first part correct, but when you rinse the machine with fresh water the machine needs to quit on its own and you will know this when the descale light is off, but you will have a flashing green light and a steady red light over the water drop. Refill the water tank, the close the steam knob and then open it again. This will clear the red light and then the machine will start heating. IMPORTANT on any automatic machine is when the water tank is off the machine don't do anything with the beans. A chip of bean in the water receptacle can be a big problem for the machine.
Jan 28, 2009 | Solis Palazzo Espresso Machine
Bosch tassimo
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
Sep 03, 2008 | Braun Tassimo Espresso Machine/Coffee...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
573 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
