Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
What does SMS on digital screen mean?
Ray Pak 2100 digital Pool heater screen says SMS. Wont ignite. Was working.
    Scholar:
  • 91 Answers
I believe the code is SNS which is sensor failure. It thinks your pool water is either above 110 degrees F or below 36 degrees F. Post the exact model/serial and will assist you further. The sensor is not expensive and somewhat easy to change if you are mechanically inclined. If not, I would strongly advise you to call your local mechanical contractor to service this boiler and it does not have to be a pool company, it can be your furnace contractor. Or let me know where you are located and I can recommend someone from that area.
Thanks
Richard
Posted on Jun 23, 2009
  • Steve K
    Steve K Dec 09, 2013
    so if the water is in fact below 36 degrees as is the case here it has been 20 degrees for the past 3 days when water warms back up the heater should be fine right?
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
The raypac 2100 pool heater turn on but when you go to fire it al
If you hear it sparking, verify the spark is happening INSIDE the combustion area and not shorting out at the ignition module. Also verify you actually have gas available and the gas valve is turned on...
Apr 08, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak commercial water heater requires reset to fire burners occ
DON'T KNOW WHY YOU HAVE A RAY PAK ON THE CAR WASH SINCE SO FAR I KNOW IS DESIGN FOR POOL AND SPA ONLY,THE HEATER NEED CONSTANT WATER FLOW BUT HERE WE GO, CHECK YOU BURNER FOR FIRE MARKS, CHECK THE HEAT EXCHANGER FOR SUIT BUILD UP (GREEN STUF) IF EVERYTHING OK THAN THE CONTROL BOARD NEED TO BE REPLACE.
Oct 30, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Sep 05, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Pool heater pilot lights, goes out when heat called for
No, that would just cause you to have huge flame. There is another high pressure switch located next to the flame sensor/ pilot genator that can cause this problem it is the size of a quarter and is screwed down with 2 phillip head screws
May 27, 2009 | Heating & Cooling
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
635 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
