Question about Sharp R-1870 Convection/Microwave Oven
Ceiling plate cover has small hole; otherwise works fine.
Sharp Carousel II Over the Range Microwave R-1821 The ceiling has a 4x5 inch plate that has a small burn hole. Is this dangerous? Can I fix (easily)?
  • skatzman May 26, 2009
    Thank you for your quick and thorough response. I guess by your answer that you feel that the microwave will continue to be safe to use - any thoughts on why this may have happened in the first place?.
  • Sharp Master
  • 9,098 Answers
Since your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
It is part # PCOVPA180WRP0 (copy & paste) and you can
order it from Encompass here or you can call them toll-free at 866-779-5835.
In some cases the part is held in place with a rivet. Other times it just slides out of the slot.
Posted on May 26, 2009
  • William Miller
    William Miller May 28, 2009
    Quite
    often this is due to grease or food particles stuck somewhere in the
    cavity of the oven or stuck on or behind the waveguide cover.
    As long as the grease in and around the opening is cleaned, and the cover is replaced, it is safe to use.
    The metal edges of the oven behind the waveguide cover can be sharp, so be careful!
    The metal
    behind it should be cleaned with a mild, non-ammonia cleaner.
    If the cavity of
    the oven is chipped or charred, it will have to be sanded smooth and
    clean and dried thoroughly.
    Then you can apply some
    high-temperature appliance paint, available from places like Wal-Mart,
    Lowe's or Builder's Square.
    Happy to help.
My question does this model have in the ceiling mould these three small circle indents or are they defects?
The indents are probably there to make the ceiling stiffer, and are not likely defects. Sharp, historically at least, has had a tendency to use thinner metal parts than other manufacturers, but it hasn't seemed to reduce reliability significantly.
If you run the oven with food in it, a sizzling sound could be a sign of a problem, or it could be normal for this oven. Ask the dealer about the noise.
Sep 22, 2016 | Sharp Microwave Ovens
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Sharp carousel R 430 EK 1200 watts
This is not good, the magnetron is arcing because metal is exposed, this will eventually destroy the magnetron making the oven useless. I strongly suggest it get looked at for safety and potential fire hazard.
Mar 05, 2012 | Sharp Carousel R530EST Microwave Oven
A plastic container with hidden piece of metal caught fire in my Sharp r1490 and burned with a big flame. Several small holes were burned in the ceiling panel. Are we in danger of radiation exposure/ is...
The microwave oven is not safe to use, the fire has compromised the interior of the oven, if you run the microwave it will start to arc and eventually short out the magnetron, because the white enamel paint has been burned away. If you have holes in the ceiling there is danger of radiation leakage, for safety reasons the oven should be replaced.
Feb 23, 2011 | Sharp R-1490 Microwave Oven
Sharp Carousel II Convection Microvave R-3850
My sharp microwave convection oven (R-1870) runs for 59 seconds and stops. If I push start it runs for another 59 seconds and stops. How can this be fixedd?
Aug 29, 2009 | Sharp R-1870 Convection/Microwave Oven
I have a Sharp Carousel microwave model R438DV 1200 watts. There is a small 5x7 screen on the right side wall. It now has a small hole and has char marks on it. When I use the unit a fire starts o
You have to replace that small screen which is called wave guide. If there is a sharp authorised service centre near to your place you can buy the part from them. Do not work the oven without replacing that part.
May 29, 2009 | Microwave Ovens
Microwave installation under cabinet, no rear wall
Your model weighs 41 pounds empty.
That - plus maybe adding another 8-10 pounds for safety - us what your installation needs to be able to handle.
I would think the average cabinet could handle that, but it may be better to add a small steel plate or large washer surrounding the mounting screws to help disperse the weight load.
The owner's manual describes the installation kit you can use to mount it in a cabinet or in the wall, etc. That may be helpful.
If you don't still have your manual you can download it here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Sharp R-408HS Microwave Oven
Burnt ceiling
Well microwave probably was too close to the ceiling and it wasn't getting enough air through and it got hot then bam you have a hole in your ceiling... if your microwave is completely ruined then don't bother with it just get a new one but if it works try moving it farther away from the ceiling.. good luck =]]
Feb 03, 2008 | Whirlpool MH1150XMQ Microwave Oven
Sharp R-1870 Convection/Microwave Oven Logo
758 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
