Question about GE (PSS26MSRSS) Side by Side Refrigerator
Their is a ticking in the back coming from the mother board, never hooked up the ice maker could that be the problem?
My PDS20SFSLSS is ticking in the back. So the electrick company turned off the power for quick maintance and now its making a ticking sound in the back ground. I have never hooked up the ice maker so i dont know if its coming from their... any suggestions?
Replace the mother board this is a peice of junk buy whirlpool
Posted on May 25, 2009
I just replaced the two beater drive motors on my Taylor c713 ice Cream machine now when I power up communication failure comes up
Every time I have seen that, it is just the USB cable on the mother board in the back of the machine.
1. Shut off and disconnect the machine from power
2. Remove the rear panel
3. Remove the electrical panel cover
4. Find the USB cable on the bottom of the board all the way to your right.
Soft Serve Parts C713
Mar 26, 2017 | Taylor Ice Cream Makers
Everything is working but the electronics went out in it. Can't use ice maker although it's making ice, can't use any functions. Can't read tempetures
Newer refrigerators have a main mother board (computer board) that all parts and functions are channeled through. I have seen your problem happen with a defective mother board but it could be something else. Not even sure you have a mother board without a brand and model number.
Jun 28, 2015 | Refrigerators
Ice maker not working AND food in fridge is freezing
Seems that you have a problem with your controls. Check the timer sequencer and thermostat.
Mar 16, 2014 | Refrigerators
Ge refridgerator model gh405499
From what I know of ge, ice makers are independent. Mother board has no control over I'm. How old is this fridge. Some of the newer ge are made by Samsung and are control.
Nov 03, 2012 | Refrigerators
Hooked up water, which dispenses invariably, but ice won't dispen
Remove the ice bin , and behind it , on the rear wall ,use a screwdriver for leverage , between the dispensor " arms " , to see if the arms turn the motor fairly freely and not jammed . If it seems jammed , use a hair dryer aimed at the center of the arms to heat up the motor shaft to melt any ice possibly freezing it . No disassembly required .
If the arms turn fairly freely ( not jammed ) , then the main control board behind the refrig , is the problem .
Apr 13, 2010 | GE Monogram ZFSB26DRSS Stainless...
Ticking noise
HI, This is the result of a damaged Power control board. This board is not regulating the incoming current correctly. This board should be replaced, immediately. This will cause the in-house circuit breaker to blow. The board is located behind a access panel, on the rear of the unit. Have it replaced, soon.
It may be mounted on the compressor platform, as well.
Dec 22, 2009 | GE GDS20KBS Bottom Freezer Refrigerator
GE Eterna series Ess23xgsbb That the ice maker makes and but the despinser keepe freezing over. We have taken it out and defrosted it and with in 48 hours it frozen over again
I assume you're talking about the ice dispenser and the ice bin being frozen over.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and causing the water to spill into the ice bin. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker quit working
what happened you reset the computer (mother board) chances are you had a brief glitch in your power and it made the computer go hey wire
Dec 15, 2007 | Whirlpool ED5FHEXMQ Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
107 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
