Question about Canon PIXMA MP780 All-In-One InkJet Printer
Mp780 displays "wrong cartridge"
All of the ink cartidges were replaced before I realized that it is probably the printhead that needs service. Is that true? How do I remove and service or replace the printhead?
  • 1 more comment
  • bob5544 May 24, 2009
    NO - how do I do that?
    There is no "resume" button on this machine. There is reset, ok, and menu, but no resume.
  • JDTec
    JDTec May 11, 2010
    Have you tried a EEPROM reset?
  • Canon Master
  • 4,338 Answers
Service Mode: EEPROM initialization
This printer has a service mode for service-related settings and for performing test prints. The operator panel buttons are used to enter the desired service mode.
Service Mode Operations
1) With the printer powered off, hold down the resume button and press the power button.
2) While holding down the power button, release the resume button and press the resume button twice in succession. Now release the power button. The
indicator will blink in green and remain lit in green.
3) Select one of the following service mode functions by pressing the resume button the specified number of times.
Press Resume Indicator Functions
Zero times Green Power off the printer
1 time Orange Service test print
2 times Green EEPROM information print
3 times Orange EEPROM initialization
4 times Green Waste ink counter setting
5 times Orange Destination settings
6 times Green Print head deep cleaning
7 times Green CD-R test print
8 times Orange CD-R print position correction (horizontal)
9 times Green CD-R print position correction (vertical)
4) Execute the function you have selected (except for model setting) by pressing the power button. The printer will switch itself off after performing the function.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on May 24, 2009
Without realizing my mistake, I erroneously installed #3e Y-M-C ink cartridges instead of the correct #6 cartridges in my MP780. It worked fine for several days, then I got a message saying the printhead...
The fact is when you compare the cost to get a new printer to replacing your printhead and cartridges you find you may want to go for a new printer instead. The difference usually is not be worth it.
Good luck & God bless!
Nov 30, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Got "wrong cartridge" error while attempting to print. Removed & reset all ink cartridges, still same error. Removed inks & print head, immediately lost power. Unplugged, waited, put everything...
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
QY6-0049-000
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
You get that message when the printhead goes bad. It's not the ink cartridges. You need a new printhead
# QY6-0049-000 around $60.00
Nov 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannon ink jet quit printing black
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel. # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right). # Continue doing this until it looks clean. # Then dab the cartridge on the towel to make sure the ink is flowing. # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier. 2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 21, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wrong cartridge message always on
Wrong cartridge means you need a new printhead. qy6-0049-000. Around $59.00. Cartridge in this case refers to printhead, not ink cartridges.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I remove printhead?
same as when you change ink tanks...
1.follow the same procedure you use to change ink tanks/cartridges to remove the current ink tanks
2.remove all ink tanks/cartridges
3.the printhead is what the ink tanks/cartridges sit in, the furthest half of the part the ink tanks/cartridges sit on is the removable part/printhead, it is loose so you can simply reach in and carefully pull it out.
Easy as 123 ...
eSid
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
371 people viewed this question
old marine
old marine
