Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Adding outside access
Would like to add outside access panel ,currently have a Liftmaster #1265, it this possible and the part number,thanks
  • 44 Answers
Absolutely doable. I always go the hard-wire approach, but this mode will also accommodate a wireless unit available here:
http://www.safesetc.com/1951.html?feed=GbaseLive&gsource=119
Take care!
Posted on May 24, 2009
Lift-master 1265 Garage Door opener clicks but nothing happens
CHECK ON THE OPENER FOR A RESET BUTTON, IT MAY HAVE JUST POPPED.
Apr 10, 2013 | Sears Craftsman LiftMaster Chamberlain...
I am locked out of garage. Liftmaster 1265 will not open.
Sounds like what you need acces too is inside the garage. If you don't have a pedestrian access door to your garage, or a window, or these are both locked, you are going to have to break something. Sorry to tell you that. Just pick the thing to break which is easiest to repair. Once inside, there is a mechanical release (usually a pull rope hanging from the opener main unit) that allows you to open the door manually. Then you can use the garage until you can address the problem. Good luck.
Oct 23, 2012 | liftmaster Chamberlain Garage Door Opener...
All my door openers r craftsmans with the orange smart buttons at the sears store they sold me one that on the package will work with green or gray does not say orange i wanted to find out before i open...
Compatible with Chamberlain LiftMaster Security+ 390MHz garage door openers with redish orange learn button manufactured from 1997-2005.
Temporary password option to let you give friends, relatives or maintenance people limited access. Program code directly from keypad.
Compatible with garage door opener operator model numbers 1240R, 1245R, 1246R, 1255R, 1256R, 1265, 1280R, 1000SDR, 2000SDR, 1245 GMR, 1255GMR
The 977LM is new version of 976LM.
Taken from Garage repair information
Jul 17, 2011 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener (liftmaster 1265) buzzes when attempting to open or close the door but the chain doesn't move
Remove the cover from the motor unit and check the drive gear. It is white nylon and is just in front of the motor. Most likely stripped.
Apr 05, 2010 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1265 won't motor more than a foot in the down
Check, The black interruptor cup. See if it has powder from gear on it , Remove particles, And run a Q-Tip between the two little towers on the RPM sensor, Which the interruptor cup rotates into to count rpm cycles.
Dec 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Replace liftmaster 1245R drive/worm gear
I have a 1265 and took the cover off (unplug first).
There are screws securing the cover: 2 on each side at top, 2 at either end bottom.
Then I disconnected the chain.
There are 3 hex head screws securing the drive gear assembly (of course they thread from the inside out which makes taking them out a bit time consuming). Take care not to damage the circuit board or other electronic connections.
Then at the bottom of the shaft is the "limit switch assembly" that is clipped into the metal housing. Squeeze the 2 on the outside and it should swing free.
Then at the very end of the shaft there is another plastic gear. It is secured by a 3 prong plastic clip. Pull the outside clips away from the shaft while pushing the center piece back through the shaft. The gear should come off and you can now remove the gear and sprocket assembly up through the assembly.
call 800 528 2817 and order the "Gear and Sprocket Assembly".
I am waiting for the part and assume we reverse the order above to reinstall.
Oct 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
146 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
