Question about Evenflo CitiTour Twin Seat Stroller
Keypad not working properly
Keypad for immobaliser when put code in stays on red and green. this is for a citroen xantia td temptation.
  • 600 Answers
Try leaving the ingnition switched on for 30 mins to reset the cut out (it thinks you have tried the wrong code 3 times) check the buttons and see if one is stuck or not clicking, If you get it started and the switchpad seems unreliable unplug the keyboard when the engine is running(this disables the cutout)
Posted on Aug 20, 2009
  • 1 more comment
  • Chris Edwards
    Chris Edwards Aug 24, 2009
    check for a button stuck down, with age they get sticky and weak, if you get it to work change the code to leave out the bad button, or if you unplug the keypad when running it will disable the system and will start from the key. If you still get the both lights on leave it switched on for 30 mins, this resets the lock out if more than 3 wrong codes have been attempted (the lockout lights green and red to tell you)
  • Chris Edwards
    Chris Edwards Oct 04, 2009
    I seems to think you have entered the wrong code 3 times, leave the ignition on for 1/2 an hour and the green should go out, if so check for a stuck button (they wear) if one is sticky lift it with your nail or a pin and enter the code, if it works you will need to change the code to loose the sticky key (this varies, check in handbook)
  • Chris Edwards
    Chris Edwards Jan 03, 2010
    It thinks it has been tampered with and is locked out, leave the ignition on for half an hour or so and it should go back to normal, before you do this check the keypad, see if any are soft as you allways use the same 4 and they can stick making any code wrong.If you get it working if you unplug the keypad from the harness when the engine is running it will allways restart.
Where's hood release lever on 1998 Citroen xantia 3 litre
left hand side .if this is a RHD vehicle they still fit the lever for a LHD model
Jan 16, 2015 | 1998 Citroen Xantia
Citroen xantia forum
Find the central locking box and remove wire connected to Remote alarm box.
Aug 06, 2014 | 1998 Citroen Xantia
Citroen xantia electrics are shorting out
If it's an automatic, check if the lever is at P or N. Check if your car has immobilizer that needs you to enter codes before it will start. Gauges moving full scale usually indicates that the instruments cluster is 'missing' an additional IGN supply. When you turn your key to the ON position, all lights in the cluster will light up. This position will make the ignition switch supply 2 IGN power to most electrical systems. If one is missing, the car may not start. Check all fuses under the fascia and in the engine bay. Be on the look out for fuses that have melted 'seats'. They may give intermittent power. Xantia's fuse slots gets melted with age, so the fuse becomes loose and supply gets disconnected.
Mar 23, 2014 | 1998 Citroen Xantia Break
Citroen Xantia AUTO 2.0 alert lights cold (sport and snow lights)
The S light is also used like a 'check engine' light for auto transmission. There maybe some error in the transmission control system. You transmission has a computer that controls a lot of valves and solenoids in it. Check your transmission fluid level and it's integrity. If you have not changed the fluid for the last 50000kms then it's due for a change. Use only Peugeot recommended fluid. Other fluids will damage it. Mention your transmission type when buying. It's either AL4 or 4HP20. Best to buy it from authorized dealer. Garages that have a Lexia 3 scanner can scan for error codes for the transmission.
Aug 20, 2012 | 1998 Citroen Xantia
Citroen Xantia fog and reversing lights not working
Check Fuse F3. It supplies 12v to the reverse switch located on the transmission. If auto transmission (4HP14) the switch will have 4 pins, 2 for reverse light, 2 for starting circuit. If manual, it has two pins. When gear is in other position, only one pin will have 12v. When gear is in R, both pins will have 12v. The 2nd pin supplies directly to the reversing light. Fog light has connectors behind the bumper. It tends to get corroded. Disconnect and clean both side of the connectors and retry. Some may get the wires snapped. Check there first. Fuse F18,F7 and F6 supplies 12v to the foglight circuit. F6 supplies to the foglight relay. Check the relay too.
Apr 05, 2012 | Citroen Xantia Cars & Trucks
Security code panel Citroen ZX
I have a problem with my security code panel for the ignition on my Citroen ZX.Having put in the number the red and green lights BOTH stay on and it won't start.Can anyone help please to help me reset it? Or could some kind person email me a copy of the pages in the driver's manual as I've lost mine? Thank you very much.
Jan 16, 2010 | Vehicle Parts & Accessories
Citroen audio manual
botton 1 is the first digit, button 2 is the 2nd and so on after all 4 done press 6
Oct 12, 2009 | Car Audio & Video
Citroen xantia car radio
I have a problem with a citroen xantia radio I can not enter the 4 digit code
system radio Audio 3030RDS
Feb 16, 2008 | Car Audio & Video
Evenflo CitiTour Twin Seat Stroller Logo
111 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
