Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
No able to lite pilot
Pilot was working fine (only thing that was) eventually got the main burner working, worked for three minutes then shut down including pilot. now pilot will not lite. any ideas this item i only 1 month old, speaking to the warranty engineer is like talking to the dead.
  • 24 Answers
Make sure gas supply is there also clean the thermocouple, if it is fowled or dirty the pilot wont stay lit nor will the main gas valve open
Posted on Jan 24, 2010
Not light
check to make sure that the poilet lite flame is touching the tip or top of the thermocouple.
the pilot lite needs to heat up the thermocouple so that the thermocouple opens the gas to the main gas log. a cold thermocouple shuts off the gas to the main gas log or gas burner and a hot thermocouple opens the gas to the main burner.
the pilot lite flame must be touching the thermocouple to heat it up.
pilot lite orface needs to be clear to let the pilot flame gas through with enough pressure so that the little flame can reach & touch the thermocouple. Pilot lite gas feed tube must be clear to let gas through. Use compressed air or a fine sewing needle, or even carb cleaner to clear out orface hole and gas feed line to pilot lite.
important!! WARNING:
if you use carb cleaner,make sure all the carb cleaner is dry,soaked up with paper towell or kleanex tissue and blowed out with compressed air , because carb cleaner can burn just like gasoline; so any carb cleaner must be compleatly gone before you attempt to lite the pilot lite.
May 20, 2013 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Lennox G20 gas valve switches off then on Intermittently?
This could be a dirty flane sencor of the pressure switch check hoses are tight and not spilt , try jumping out the pressure switch see if that makes it work also check air fliter is clean .
Feb 11, 2013 | Heating & Cooling
Janitrol GUPS075-3 Furnace burners will not stay lit
The first thing I would do is make sure the flame sensor is clean, this is a metal rod immersed in the burner flame on the opposite side of the igniter. If too much oxidation builds up on it, it will not allow the burner to stay lit. To clean, just turn off furnace and remove flame sensor and clean with steel wool and then reinstall. If this does not solve the problem there may be a problem with the gas valve.
Nov 08, 2012 | Heating & Cooling
At 300F after half hour, pilot and main gas burner was going off. When re-lit would stay on only 5 minutes thereafter. Had the thermopile changed(bought locally- not original from Imperial but identical),...
Hi there.
The thermostat will only shut down burner flame but not pilot flame.
Try tightening all wiring connections.
By using an ohm meter, check the continuity across the hi limit terminals when the pilot goes off, your hi limit may be tripping prematurely causing pilot flame to shut down.
Regards.
Jul 29, 2011 | Kitchen Appliances - Others
Unit randomly shuts down
you could re locate your therocouple away from flame
Dec 22, 2009 | Desa International CBN30T Central Heating...
Gsw heater pilot stays lit, but when the main
It sounds like your main valve. The diaphram may be loose fitting or it has a small leak.
Oct 03, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
Laars Lite 2 Gas-Pilot stays on, but main burner shuts off 10 min
A polit generator produces about 750 MV without a load. Under load it will drop to about 200-250 MV. If the system is working don't worry about it. If the system is not working replace the pilot generator and retest. Pilot generators usually go bad slowly.
Jun 22, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Unit will try three times to start then shut down
Make sure the exhaust fan is running.You say it fires up and then cut off.Does the main burner come on just the pilot?If it's just the pilot then I would say you need to replace sense that senser the pilot lite.Because onces that senser the flame the main gas vavle should open.for give me for my mis spelling.
Mar 26, 2009 | Heating & Cooling
Heating & Cooling Logo
295 people viewed this question
Top Lite On Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
