Question about Bose Lifestyle 48 System
BOSE REMOTE RC38T1-27
THE REMOTE WORKS ONLY ABOUT 3 TO 6 INCHES AWAY FROM THE MEDIA CENTER.
Ran into the same problem as most people with this system.
THE TRICK... UNPLUG FOR 30-60 SECONDS.......
works like a charm, baby!!
Posted on May 05, 2010
  • Michael Mason
    Michael Mason May 20, 2014
    I unpluged my system for a couple of minutes and the system came right up after a reconnection. Thanks so much..
    Sniper:
  • 71 Answers
The first solution is wrong. (no offense to the Guru) This can not be caused by any settings, so save yourself the hassle.
The LS38 does use RF and IR, but if the remote works at all, RF is already active. 'IR control' is only for using other universal remotes on this system.
If shaking the remote does not cause a rattle, then there's probably nothing wrong with the remote. Also nothing wrong with any dip switches. (I'm assuming you've tried new batteries)
The power supply cable (DC power) at the back of the media center also doubles as the receiving antenna for the RF remote. Straighten this cable out as much as possible. Make sure it's not wrapped around any other cables, power cables especially. This should solve your problem.
Posted on May 28, 2009
    President:
  • Bose Master
  • 1,114 Answers
Fastest way to check would be to hook up your Video output to a TV if you haven't already done so. Then, pull up the Bose Menu go to "remote settings" and see if it's set to "IR" if so switch to "RF" it has much better range and is useable anywhere in the house. Now I'm not sure on the lifestyle 48 but I do believe there are dipswitches in the remote under the battery cover. You need the manual to decifer what they are for however, that may be your problem as well. If you don't have your manual, go to www.bose.com/controller?url=/shop_online/hometheater/lifestyle_systems/dvd_systems/lifestyle_48/index.jsp#manuals You can download both the user manual and the install guide for free as well as get updates for your unit. the most recent disc update was May 15th and you again can request a disc for free!
My hunch is that the batteries in your remote were replaced and a dipswitch was bumped and moved. It happens. Hope this helps. If not post a reply and we can try other fun stuff too.
Posted on May 24, 2009
Bose lifestyle one room doesn't connect and the remote says it won't connect to media center
Look in the instruction manual and make sure that you have set the codes correctly, the house code for the remote, as well as the room code for the second room. Also check the batteries in the remote control, especially when the room as far away from the main room, the batteries need to be full in order to reach the center. I assume we talk about a wired system? When this is a wireless connection to the second room, it may need a reset, unplug and re-plug the wireless adapter, there should be a pilot light in the back of the wireless adapter, which should be green. If that does not help, call Bose.
Jun 07, 2014 | Bose Lifestyle 48 System
Bose rc48s2 remote not receiving signal
make sure the lens on the remote and the one on the Bose are clean. If that does not work, replace the remote. Buy a used on on ebay.
Dec 21, 2013 | Bose RC-48S Remote
My bose remote for my lifestyle48 only works from really close up? I was lead to believe they work from any room in the house... what's wrong?
The Bose Lifestyle 48 remote is RF device and is rated to work up to 65 feet (20m) away from the system (brick, steel, etc. construction will reduce this distance significantly however). The remote is discussed in two places of the installation manual.
The first speaks to the receiving antenna on page 16 in the form of a "Note" below section 4G. It states that both of the power cords (one between the VS2 and Media Center the second that supplies power to the VS2) need to be fully extended. Wrapping up excess cable will reduce the receiving range of the system to the remote transmitter.
The second location is at the bottom of page 29. Here, it offers the solution to poor remote performance to be an optional "remote extender" that looks like it connects to the rear of the system (RC connector?). The extender is available for an additional cost and you must contact Bose to obtain it. I can't find an image of it and Bose doesn't produce any information about it when searching their website.
I hope this helps and good luck! Please rat emy reply - thanks.
Apr 21, 2011 | Bose RC-48S Remote
I have the bose av28 media center, life style 28, remote broke, i have a time warner clikr 5 universal remote can this control the bose 28 ?
No, only the Bose remotes will work with it! Bose doesn't let any other remote to work on their systems.
Dec 26, 2010 | Bose Lifestyle 28 System
How do you pry apart a Bose RC-9 Remote control without breaking it, to give it an internal cleaning.
There are 3 tabs on each side, and 1 on each end. Pry with a thin flat head screwdriver, but be gentle as you can break these easily. The first tabs are 2 and 5/8 inches from the top end of the remote, with the others 2 inches away from this. The ones on the ends are dead center.
Apr 30, 2010 | Bose Lifestyle 28 System
Bose av28 access menu using control buttons
when this happened to me,,,I found out it meant that the video decoding ASIC was out....I could not get any DVD's to play to the TV, and finally, the "settings" menu would not go on the television screen....this means you need to have the mainboard replaced, and after twice doing this,,,,the Tech on the phone told me that the Video Decoding ASIC is very susceptible to power spikes,,,so I put a big APC filter in front of it....
Jul 06, 2009 | Bose Lifestyle 28 System
Bose 321
3 audio inputs (3 analog, 3 coaxial digital, 1 optical digital)
2 video pass-through inputs (composite and S-video)
Video output for TV (composite, S-video, and component)
Media center • 3 1/4"H x 13 3/4"W x 10"D • (8.3 x 34.9 x 25.4 cm) • 6.7 lbs. (3 kg)
Remote control • 1 1/8"H x 2 1/2"W x 9"D • (3 x 6.5 x 22.9 cm)
Gemstone speakers • 2 1/2"H x 5 1/2"W x 4 1/8"D • (6.4 x 14 x 10.5 cm) • 1 lb. (.45 kg) each
Acoustimass module • 14 1/2"H x 8 3/4"W x 19 1/8"D • (36.7 x 22.2 x 48.5 cm) • 23.3 lbs. (10.6 kg)
Total shipping weight • 44 lbs. (20 kg)
gray_hr.gif What's In the Box • Acoustimass® module • Media center • 2 speakers • 3·2·1 universal remote control • Setup DVD • Antenna stand • Stereo cable • Video cable • Speaker cable • Module cable • Rubber feet for Acoustimass® module • Rubber feet for speakers • Batteries • AM antenna • FM antenna • 120V power cord • Quick setup guidepls rate !!!!!!
May 29, 2008 | Bose 321GS Series II System
Frozen bose lifestyle 48 IV
turn off the accoustimas, unplug the power code from the accoustimas and the media center and leave it for 15 sec. Then, plug the power code onto the accoustimas and turn it on. then plug the power code of the media center on. Turn media center on.
hope this helps
Apr 15, 2008 | Bose Lifestyle 48 System
Bose Lifestyle 48 System Logo
2,284 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
