Question about Dell Inspiron B130 Notebook
Dell B-130 way to long to boot up
I've read this problem over and over again with most suggestions leading to defrag, or just plain ol clean up. Any suggestions if one has already done all that? My B-130 takes about 10-12 min to complete its boot. No virus, no spyware, nothing added on this machine, ever, Once booted, all works as expected. I've had it checked out several times, most agree that its a motherboard issue, perhaps grounding leads or mounting flaw from Dell at time of mfgr.
  • gearjammer21 May 24, 2009
    Thanks robnoc. Note: that we did better than your suggestions by replacing the hardrive with a fresh one, to no avail. This is what lead us to think it was a MB issue. I'm wondering if this particular model just had issues from the start. I've read so much about the B-130 all having the same issue. Its not a high end unit by any means, but it does still look brand new. I hate to toss it just because.
    Sergeant:
    Champion:
  • 212 Answers
Do a system restore. Take it back to where You were running good. If that doesn't help then You might have to wipe the hard drive and put windows back on it. Defragging and cleaning it up won't help this issue. hope that helps You out.
Posted on May 24, 2009
  • Robert Lekfield May 24, 2009
    If You replaced the Hard drive I would suggest getting ahold of them. Then it is deffinately a Mother board issue.
Dell studio 1737 laptop takes about fifteen minutes or more to boot up
Shelisha, may be you have too many programs to start with. That slows you down. Also extensions take time too. Try cleaning up and keep most used. Rest can go into a folder. Clean registry and clutter. I use advanced uninstaller pro. Have you defragmented the hard drive(s).
Mar 22, 2014 | Computers & Internet
Dell 4300 wont boot up
Try it with another keyboard. Would've thought a read/write failure would have more to do with the hard or optical drive.
Oct 11, 2012 | Dell Computers & Internet
Ol 3000 user manual
Here is a plain text version of the manual
http://archive.org/stream/OlympiaInfoGlobeOl3000.2Manual/OlympiaInfoGlobeOl3000.2Manual_djvu.txt
It's a bit tricky to read due to it being in plain text, but the necessary words of instruction are all there.
May 31, 2012 | Olympia InfoGlobe Caller ID
Dell Studio 15 runs slow... My Dell studio 1558 takes long time to boot & processing is also slow,i have tried disk cleanup and defragment hard disk but nothing worked,it has the following...
sound like your core is geting hot is your fan working is so try cleaning it with small birst of air plus check your bios settings..if not overheating try factory settings...
Apr 14, 2011 | Dell Studio 1558 Notebook
Ge microwave mod. #JVM1851BH06. i ohmed the capicitor 2 meg ohm and increased to 11 meg ohm. I also measured the diode which i believe branches off one leg of capacitor it shows open resistance O.L. both...
I'd say your diode is bad but your capacitor may be good. You need to test it further - as described below.
In order to get reliable measurements to make a determination about the condition of the components, each should have at least one lead removed from the circuit. If not, your meter will read the through the rest of the circuit - and not be limited to the diode or capacitor under test.
To check a diode: Set the meter to to the lowest scale (Rx1) and touch black (-) probe to the cathode of the diode (the end with a band around the diode body) and the red (+) to the anode lead to reverse bias the diode. The meter should indicate "OL" or high resistance. Reverse the meter probes so that RED (+) is on the cathode lead and black (-) is on the anode to forward bias the diode. The meter should read a very low resistance - approaching 0 ohms. Diodes should conduct in one direction only - and the other is should look "open" If it conducts or is open in both directions, it is defective. Zener diodes can be checked with an ohm meter, but need a variable voltage supply and are required to be in a circuit (instead of out of circuit like a standard diode) for accurate testing. A link to zener diode testing here.
To check a capacitor: Set the meter to the lowest scale (Rx1) and touch probes to capacitor leads. The meter should indicate "OL" or high resistance and show steadily decreasing resistance before increasing to OL or high resistance again. Swap probes from the meter on the capacitor leads and "OL or high resistance indication should change to an even lower amount of resistance thas before before returning to "OL" or high resistance indication. These are test result characteristics of a good capacitor under test.
I hope this helps & good luck! Please rate my reply - thanks!
Jan 27, 2011 | GE Profile Spacemaker Over-the-Range...
Powermate pm0545212.02 wont generate
The exciter coil can be checked with an ohm meter. It will read fairly low ohms (probably under 100). There are diodes also. You can check them with an ohm meter too. They should read in one direction only. The red lead on the meter is + and that will conduct through the diode when your on the anode. When you reverse the leads of the meter, it should read infinite or OL.
Jun 27, 2009 | Coleman Powermate Powermate 5000W...
If you dont have a lot of programs running at start up, then it sounds like you've answered your own question. If youve gone through all the processes to clean up, then thats about it. How about Boot Defrag? How about go to windows folder find Prefetch folder Open it and select all. Then Delete all. Restart your computer. It may take 2 times to start showing improvement.
Char S.
May 27, 2009 | Dell Inspiron B130 Notebook
My desktop is failed to intermittent boot up?
Run you antivirus .Clean and defrag the hard drive. If the defrag get stuck at the same percentage for a long time ,either run checkdisk to confirm or replace the drive.
Jan 21, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Inspiron 8100 won't boot
Send it in to a repair facility, usually runs 80-130 online through ebay. Inspirons are known for blowing fuses/resistors. This may have happened, but either way if you pull the new battery and it dont work still with charger or vice versa you have a power issue on the motherboard.
Good Luck!
Ruben
Nov 08, 2008 | Dell Inspiron 8100 Notebook
Power on/boot-up problem
Have I got a story for you? Dell inadvertently used some defective capacitors in their Optiplex motherboards and some power supplies. From what I?ve experienced and read this affects the Optiplex 270 and early 280 lines. In my case my systems had video display problems and eventually ended up not booting. The giveaway is looking at the large 150 uf capacitors; they are the larger ones usually with an ?X? inscribed on the top. If the tops of the capacitors are flat you?re out of luck but if any of them are bulging (even slightly) at the top, leaking electrolyte or split Dell will replace the motherboard for free. This program is in effect till 2008. I wouldn?t recommend pulling the power supply apart but the flashing yellow power light for me has been a failed power supply. I would check out the motherboard for bad capacitors then call Dell. It?s likely they will replace the power supply if it?s in warranty, perhaps even if its out in light of the capacitor issue. If you?ve got some rounded caps on the motherboard I would also ask them to replace that as well. Let us know if you have any other questions and please don?t forget to rate this posting.
Mar 30, 2007 | Dell OptiPlex GX270 PC Desktop
Dell Inspiron B130 Notebook Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
