Question about Ovens
Electrical Failure - Nothing working
Checked Power supply & breakers OK
Checked Fuses- all ok.
Was working & just stopped.
Now need to open up. Where would be an obvious place for a cable failure?
  • aclarke511 May 24, 2009
    Will Try it out & feedback
  • steve
    steve May 11, 2010
    Brand and model number?
    President:
  • 1,185 Answers
Probably not a cable failure more likely to be a screw in a connector block which has not been tightened correctly.
Unless you are a competant person I would not advise going beyond what you have done so far.
I would start at the plug top and make sure that the screws are tight on all connections then use a multimeter on ohms across the Live & Neutral to see if there was any resistance showing.
If that was dead then (WITH THE POWER OFFI would go to the terminal block which connects the power cable to the cooker and check for continuity using a buzzer on both Live & Neutral cable
If there is continuity on both then it is a case of checking for internal fuses on the unit or a bad connection leading up to or on the connector strip which supplies the on/off switches for the various elements.
I recently lost the front two rings on a Halogen cooker which had worked fine until we took it out to put a new worktop down.
The problem was a metal link which for over two years had been laying across the contacts without beeing fastened down.
Posted on May 24, 2009
We want to buy a Neff bu-in double oven which needs a 20 amp supply (hard-wired).Our old existing oven is running on a 30 amp supply apparently. Will we have problems when the new Neff is fitted?
The breaker could be changed from 30a to 20a. A 30amp breaker will run the unit but you will have less/no protection since the oven will pull 10 extra amps before it trips which could totally fry your oven depending on the failure.
Re-check the wording to see if it says 'minimum' 20amp breaker or if it indicates 20amp breaker only. If it's minimum 20amp I'd run it.
If it says 20amp only, I'd change the breaker. The existing wiring and outlet will be OK, if the plug-in is the same.
Get an electrician to change the breaker. You should really know what you are doing before you try it yourself.
Sep 16, 2017 | Neff Ovens
Why has our oven stopped working whilst cooking - nothing electrical seems to be working?
Did you check your electrical breakers? Maybe it tripped. Reset it by first switching it fully to the off position, then switch it to on.
Feb 29, 2016 | Ovens
No power after self cleaning
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
5.
Dec 27, 2012 | Belling Ovens
I have a belling b160f cooker, which blows a fuse after an hour of operation, I suspect the cooling fan? This is assuming the cooling fan kicks in when it gets too hot? I have checked the elements for the...
Put an AC Amp meter (preferably a logging type) on to the unit for when using it. See if it exceeds that of the circuit breaker or fuse. Most of these appliances pull about the maximum allowable load from the mains supply. If the Amps never exceeded the rating of the breaker or fuse, this means the problem is with the electrical panel.
I have seen a defective heating element in appliances cause the tripping of a circuit breaker in the electrical panel. With age the element becomes a little lower in resistance at times, and thus is drawing slightly too much current. Replacing the element fixed it.
Apr 02, 2017 | Belling Ovens
Kenmore Classic Wall Oven Model # C97047191-2 Serial # NF91008197 nothing on it works (was fine last night) checked the 3 fuses under the stove and the breaker is good on the electrical panel. Is there...
I think that the ONLY problem is to set properly the TIMER; The TIMER is set OFF and the OVEN does not work; try to push and/or release the timer buttons and it will work. I have the same problem and it is very unfortunate that I have no manuals.....
Oct 05, 2010 | Ovens
Our Chef Sapphire Clock & Oven stopped working suddenly after a power failure overnight. Are there any fuses to be found inside, or any other suggestions please. The stove top is fine and all 4...
This oven needs the time set after a power failure. The LED display will read HELPME and there is a small knob on the left side you need to turn it to set to change the time and use the second knob from left side to + and once done leave the knob on manual. The oven can be timed to turn off but it the time is not set on it the oven and stove do not work.dux_training.jpg
Aug 29, 2010 | Ovens
Electrical output requirement for a buit-in oven and cooktop
Providing the existing switch outlet iscontrolled by a 30amp circuit fuse or trip, then there is no problem connecting the 2 appliances to the same switch.
If on the other hand, it is controlled by a 13 amp breaker, then you cannot connect both appliances to this, you would have to use 2 seperate sockets.
Hope this clarifys your question.
Mar 07, 2010 | Whirlpool RBS275PD Electric Single Oven
Power gone on entire oven
Check fuse of the oven.
Jan 03, 2010 | Ovens
Put in new wall oven and set the clock and a few minutes later I heard a pop sound and the power to the oven went off without tripping the breaker. There is power on the 15 amp circuit but not on the 30...
if nothing on it works there is a possibilty the control borad went out if it has a control borad if it is new the warranty should cover it
Jun 07, 2009 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
