Question about Jenn-Air 30 in. JGD8430A Gas Cooktop
JENN-AIR JGC8645ADS SPARK IGNITER KEEPS SPARKING WITH ANY OF SIX VALVES ARE TURNED ON.
  • wes_serv May 24, 2009
    IN THE OFF POSION IT STOPPED AFTER REPLACING ONE SWITCH.
  • steve
    steve May 11, 2010
    You have one or more "sticky" switches.
    To find out which one remove the access panel. Turn on a switch so that it sparks. Turn it past the lite position and start removing wires from each spark switch. When the sparking stops that will be the bad switch.
    Replace it.
    Turn the gas off to do this test.
  • Jenn-Air Master
  • 3,361 Answers
Glad you found the problem.
Hope this advice helped.
Posted on May 24, 2009
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
Test the ignitor first, if the ignitor does not spark should be the ignitor itself.
Oct 12, 2008 | Jenn-Air 30 in. JGD8430A Gas Cooktop
I turn on one of the burners and after it lights it keeps trying to light
A continuously running electronic spark igniter could be caused by a bad flame sensor (usually a capillary tube) or igniter controller.
Jan 23, 2011 | Jenn-Air Cooktops
The spark igniter keeps sparking after the flame has been lite
spark igniter stays on after burners lit. can you help?
Jun 17, 2010 | Jenn-Air JGC8536 Gas Cooktop
The ignitor will not stop sparking.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 23, 2010 | Jenn-Air 30 in. JGD8430A Gas Cooktop
I have prolonged igniter activation even when a burner is lit. I have searched the possible causes for this and none mention a bad flame sensor. I assume the sensor is built into the igniter. Is that...
Your problem is a stuck igniter switch or a bad spark module.
Each surface valve has its own igniter switch. Turn off the gas. Remove the panel covering the valves to access the switches.
With the gas OFF,turn on all surface switches. Move the dial past the LITE setting. The switches should still be making the sparking sound.
Remove one wire at a time from each surface switch.
When the sparking stops,that last switch with the wire removed will be the bad switch. The one that needs replacing.
If you do not find a bad switch the main spark control module will have to be replaced.
Part # 71003385 Igniter switch.
Part # 71002783 Spark module.
Occasionally a igniter switch becomes dislodged from the correct position and can be re-seated. Look at the position of all switches before you do any test. Make sure they are all seated.
Nov 08, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
Igniter keeps firing
The problem resolved on its own. I'm guessing some moisture from my cleaning was the culprit...when the moisture dried the igniter stopped sparking.
Jun 01, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
Jenn-Air 30 in. JGD8430A Gas Cooktop Logo
341 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
