Question about Acer Aspire 4730-4947 Notebook
Need to create a partition in hard disk
I need to divide the hard disk (286GB) into 4 divisiions ie. I need to create a partition
  • Acer Master
  • 1,183 Answers
You can use the following link to help you on the same
http://www.petri.co.il/the-ultimate-guide-to-hard-drive-partitioning.htm
Thanks
Proton
Posted on May 24, 2009
I have a lenovo g560 and my hard disk was partitioned only one local disc ie C and now i want to make another 2 more partitions hw is it possible can any body pls reply
I recommend you to use AOMEI Partition Assistant Server Edition. It is a magic tool to manage your disk better. With its help, it is a piece of cake to create partitions as many as you can, no matter primary or logical. It is really worthy using, because I used it before.
http://www.disk-partition.com/partition-manager-server-edition.html
Mar 23, 2012 | Lenovo G560 - 15.6 - 500GB - Black -...
Tip
How To Recover Lost, Deleted Or Missing Files And Partitions
1. If TestDisk is not yet installed, it can be downloaded from <a href="http://www.cgsecurity.org/wiki/TestDisk_Download">TestDisk Download</a>. Extract the files from the archive including the sub-directories.<br /><br />2. To recover a lost partition or repair the filesystem from a hard disk, USB key, Smart Card, etc., you need enough rights to access a physical device. <ul> <li> <img src="dos.png" /> Under DOS, run TestDisk.exe </li> <li> <img src="win.png" /> Under Windows, start TestDisk (ie testdisk-6.9/win/testdisk_win.exe) from an account in the Administrator group. Under Vista, right-click testdisk_win.exe and then "Run as administrator" to launch TestDisk. </li> <li> <img src="linux.png" /> Under Unix/Linux/BSD, you need to be root to run TestDisk (ie. sudo testdisk-6.9/linux/testdisk_static) </li> <li> <img src="macosx.png" /> Under MacOSX, if you are not root, TestDisk (ie testdisk-6.9/darwin/TestDisk) will restart itself using sudo after confirmation on your part. </li> <li> <img src="os2.png" /> Under OS/2, TestDisk doesn't handle a physical device, only a disk image. Sorry. </li></ul> 3. To recover partition from a media image or repair a filesystem image, run: <br /> <ul> <li> testdisk image.dd to create a raw disk image </li> <li> testdisk image.E01 to recover files from an Encase EWF image </li> <li> testdisk 'image.???' if the Encase image is split into several files. </li></ul> 4. <img src="linux.png" /> <img src="macosx.png" /> To repair a filesystem not listed by TestDisk, run testdisk device, i.e. <br /> <ul> <li> testdisk /dev/mapper/truecrypt0 or testdisk /dev/loop0 to repair the NTFS or FAT32 boot sector files from a TrueCrypt partition. The same method works with filesystem encrypted with cryptsetup/dm-crypt/LUKS. </li> <li> testdisk /dev/md0 to repair a filesystem on top of a Linux RAID device. </li></ul>5. Choose Create to instruct Testdisk to create a <a href="http://www.cgsecurity.org/wiki/Log_file">log file</a> containing technical information and messages, unless you have a reason to append data to the <a href="http://www.cgsecurity.org/wiki/Log_file">log</a> or you execute TestDisk from read only media and must create the <a href="http://www.cgsecurity.org/wiki/Log_file">log</a> elsewhere.<br /><br />6. Choose None if you do not want messages and details of the process to be written into a <a href="http://www.cgsecurity.org/wiki/Log_file">log file</a> (useful if for example Testdisk was started from a read-only location).<br /><br />7. Press Enter to proceed.<br /><br />8. All hard drives should be detected and listed with the correct size by TestDisk:<br /><img src="moz-screenshot.png" /><img src="pctech1.gif" /><br /> <ul> <li> Use up/down arrow keys to select your hard drive with the lost partition/s. </li> <li> Press Enter to Proceed. </li></ul> <img src="macosx.png" /> If available, use raw device /dev/rdisk* instead of /dev/disk* for faster data transfer. <br /><br />9. TestDisk displays the partition table types: <span><img src="Partition_table_type.gif" /></span> <ul> <li> Select the partition table type - usually the default value is the correct one as TestDisk auto-detects the partition table type. </li> <li> Press Enter to Proceed. </li></ul><br />10. TestDisk displays the menus:<br /> <span><img src="Menus.gif" /></span> <ul> <li> Use the default menu "Analyse" to check your current partition structure and search for lost partitions. </li> <li> Confirm at Analyse with Enter to proceed. </li></ul> 11. Now, your current partition structure is listed. Examine your current partition structure for missing partitions and errors: <br /> <span><img src="Analyse.gif" /></span> <ul> <li>The first partition is listed twice which points to a corrupted partition or an invalid partition table entry.</li> <li>Invalid NTFS boot points to a faulty NTFS boot sector, so it's a corrupted filesystem.</li> <li>Only one logical partition (label Partition 2) is available in the extended partition. One logical partition is missing.</li></ul>12. Confirm at <i><b>Quick Search</b></i> to proceed. <span><img src="Vista_check.gif" /></span> <ul> <li> Confirm according to your OS and created partitions to proceed. </li></ul>13. During the <i><b>Quick Search</b></i>, TestDisk has found two partitions including the missing logical partition labeled <i><b>Partition 3</b></i>. <a href="http://www.cgsecurity.org/wiki/File:First_results.gif"><img src="First_results.gif" /></a> <ul> <li> Highlight this partition and press <i><b>p</b></i> to list your files (to go back to the previous display, press q to Quit).</li> <li>If all directories and data are correctly listed, Press Enter to proceed. </li></ul> 14. Save the partition table or search for more partitions?<br /> <span><img src="Search_menu.gif" /></span> <ul> <li> <i><b>When all partitions are available</b></i> and data correctly listed, you should go to the menu <b>Write</b> to save the partition structure. The menu Extd Part gives you the opportunity to decide if the extended partition will use all available disk space or only the required (minimal) space. </li> <li> <i><b>If you are still missing a partition</b></i>, highlight the menu <i><b>Deeper Search</b></i> (if not done automatically already) and press Enter to proceed. </li></ul>
on Feb 20, 2011 | Computers & Internet
Tip
How to properly setup a single hard drive for Windows.
Hello Windows user, setting up Windows on your hard drive is easy, but there is a better way to setup Windows so you will never have problems later, (especially XP users), So before you start setting up Windows, I suggest you partition your hard drive to 2 (or 3) partition, one for the system (usually this is drive C:), one for your data (this is drive D:). Partitioning simply divides your hard drive to several sections, the main advantage is in case your windows system goes bad, or get infected by a virus, you can easily back up your important documents, simply copy all your important files to drive D: (drive D: is not erased if you setup Windows on drive C:)
for example:
To create a partition, on an XP setup, using a 160GB hard drive, divide your 160GB Hard Drive to 2, Press C to create a partition see picture. 80GB for windows system files and 80GB for data files.
Never setup the entire Windows on drive C: alone. create 2 partition. So before you choose where to setup Windows, there is an option to create another partition, input how much storage space you need for the partition in our example 80GB on a 160 GB drive. then proceed to setup Windows on drive C:. (at this point there are two drives, C: and D:)
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
On Windows Vista, although the backup is automatic, its much wiser to partion your hard drive.
on Apr 07, 2010 | Computers & Internet
How to partition. appreciate a step by step instruction. thanks
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
i have used this and found it a very good program and is easy to install
hope this helps you
Aug 20, 2011 | Seagate Freeagent Goflex Desk 3 TB Desktop...
I want to remove my patition
Perform the following steps which dddriver mentioned
But deleting partition means that your data will be lost from that volume.Its better take the backup of data otherwise your data get lost. To retrieved your data from deleted partition with the help of partition recovery tools. These tools are absolutely safe on the data in the drive and their only concern is to get back the lost data without altering the format.
Jun 13, 2011 | Computers & Internet
Not able to detect the disk
We're going to need more information to troubleshoot, but if it's a new drive that's never been set up follow the instructions below. If these instructions aren't helpful, then please post back with more info and I'll help you further.
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click "Administrative Tools."
4. Double-click "Computer Management."
5. Select "Disk Management" under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hard drive.
Good luck and thanks for using FixYa.
Apr 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to make partation in new hard disc using window xp
Hello sir and Windows user, setting up Windows on your hard drive is easy, but there is a better way to setup Windows so you will never have problems later, like back up and searching for flash drives (especially XP users), So before you start setting up Windows, I suggest you partition your hard drive to 2 (or 3) partition, one for the system (usually this is drive C:), one for your data (this is drive D:). Partitioning simply divides your hard drive to several sections, the main advantage is in case your windows system goes bad, or get infected by a virus, you can easily back up your important documents, simply copy all your important files to drive D: (drive D: is not erased if you setup Windows on drive C:)
for example:
On Windows Vista, the backup is automatic, but then again, its much wiser to partition your hard drive.
Sep 10, 2010 | Maxtor Hard Drive
HOW TO PARTITION FREE AGENT 500 HARD DISK. i HAVE NO PRIOR EXPERIENCE AND WOULD LIKE TO ENSURE EXISTING DATA IN FREE AGENT REMAINS INTACT. pLEASE ADVISE
First, copy all of the data from the drive to another as a backup.
Now the drive already has a partition or you would not be able to store data on it. Therefore, you could only be speaking about dividing it into multiple partitions.
Therefore you delete the exisiting partition and then create smaller partitions. In Windows you will be limited to 4-partitions.
I hope this helps.
Sep 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a freeagent go 500gb portable hard drive. Is it possible to divide it into two 250gb partitions?how?
yes it is possible. First you can use a partition software. The second is using the disk management tools, these are the steps.
1.To run Disk Management Tool, click on Start, right-click My Computer, and select Manage from the menu that appears. When you see the Computer Management window, click the Disk Management item listed underneath the Storage heading. You then see the main Disk Management pane in the right side of the Computer Management window.
2.Creating the partition: Unallocated space appears as an Unknown Partition in the Disk Management diagram, you can use it to create a new partition in some or all of the space. To create your new partition, you need to right-click on the part of the diagram that represents the unallocated space, the unallocated space has a black stripe running along the top and then choose the "New Partition" on the menu that appears. To create your new logical drive in an extended partition that has free space The free space has a light green strip along the top, right-click on the free space then choose New Logical Drive from the menu that appears. Now you will see the New Partition Wizard.
The Partition Wizard will asks you to specify the following:
1 The Type - Primary, extended, or logical partition. Your hard drive can contain up to four primary partitions, or three primary partitions and one extended partition. Choose the primary partition if you are created a partition in which you will install an operating system (this is unusual situation). Choose extended if you plan to create several logical partitions within it. The logical partition type is available only if you choose to create the new partition in an extended partition with some free space.
2 The Size - You may use the entire available space, or leave room for more partitions. The Partition Wizard will displays the minimum and maximum size for the partition, this is based on the space where it will be stored
3 The Drive letter or path - Two operating system on your computer. You may select any unused letter, but the wizard will offer the next available drive letter. To Mount in the following empty NTFS Folder, you need an NTFS partition with a drive letter on the same machine. You may select the "Do Not Assign A Drive Letter Or Drive Path" option, this will let Windows assign a letter later, usually the default drive letter.
4 The File system - The default is NTFS (recommended), but you can use FAT32 (not recommended) as well. Both NTFS and FAT32 will efficiently utilize disk space on large drives.
Note: NTFS has better security features, the better recovery capabilities after a major crash, and has file-level compression built in. NTFS will also give you the option of enable compression.
5 The Label - Type a name for the partition, name it something that will indicating what you will use it for, data files, my files, fatboy one, etc.
I hope this solution was helpful.
Aug 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Acer Aspire 4730-4947 Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
