Question about Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White
Electrolux Icon Oven won't self clean - "Remove Racks" displayed
Trying to self clean our Electrolux Icon oven for the first time. Have removed the racks and rack supports. However, when I press "clean" it still displayed "remove racks" and won't start (beeps three times instead). Frustrating!!! I have removed both the racks AND the supports and the remove racks is still blinking. I have an Electrolux EW30Es65GSB electric built in range. It was manufacutred in Nov. 2008. This is the first time I tried to clean it. My entire kitchen remodel was a nightmare so this is par for the course!
5 Suggested Answers
SOURCE: Electrolux Icon Oven won't self clean - "Remove Racks" displayed
I was getting the remove rack error until I finally figured out what it wanted me to remove. When you say you removed the rack supports, do you mean just the sliding parts or the whole side metal rack support? At first I thought they were bolted in, but I read somewhere that they come out, too. Upon further investigation, I found the rack supports just slide into the side walls at 4 points. I had to use a little force to pull them out, but they came out and my oven is self-cleaning as I write this. I just thought I would share in case you or others haven't figured it out yet. Now I will just have to see how hard it is to get them back in...
Posted on Feb 21, 2009
jumptrout51
  • 3361 Answers
SOURCE: How to remove oven racks for cleaning my
Push the racks all the way to the rear of the oven. Lift the rear of the rack to dislodge it from the side rail and pull it out.
Posted on Nov 19, 2009
SOURCE: Racks falling down
I have the same oven and the same problem. Was your problem resolved?
Posted on Aug 17, 2010
Macmarkus
  • 2605 Answers
SOURCE: I am trying to clean
Hello Cynthia,
Welcome to FixYa.
Is this the first time the un it has been set for self-clean ? Or is it the first time you have set it for self clean ?
The reason I ask is based on your post "The racks are removed. When I try to start the self cleaning feature - a message flashes in red to remove oven racks " I really don't think anything is wrong with your oven.
This is simply a reminder to remove your racks before the oven reaches the temperature ( usually above 550 ) which the door cannot be opened even by canceling the clean cycle until it cools down below 550...a safety measure.
If you allow the unit to proceed through the self clean the message will go away after a while and the cycle will continue on it's merry way.
Hope that answers your question or quells your concern. Those darn self clean ovens get so hot they will make your nice racks look like barbecue grills if left in during the cleaning, it is definitely better to be sure now than sorry later though, glad you asked.
Thank you for choosing FixYa. Let me know if you need any further assistance and good luck.
Regards,
Macmarkus :)
Posted on Oct 09, 2010
Message to remove racks when trying to self clean,yet all racks have already been removed.
This message is a reminder to make sure the rack are removed only. If they are removed then continue with the self clean cycle. Good Luck
Mar 22, 2016 | Electrolux 30" Built-In Single Electric...
How do I clean the electrolux oven? It won't start after i take the racks out
As you did not specify the exact model I assume that this is a self-cleaning oven, in other words with pyrolytic cleaning. It has a microswitch which is activated by removing the racks and just because that you can not run the pyrolytic cleaning otherwise racks would be destroyed. Do not forget that the temperature during pyrolytic cleaning is app. 500 degrees Celsius. For that reasons the oven door is locked when temperature increasing to app. 300 degrees and unlocked when the temperature decreasing to the app. 200 degrees. It is clear that when you remove the racks only program that you can run is pyrolytic cleaning.
Dado
Oct 10, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux dual fuel range 316471210 self clean remove racks message displayed and cannot proceed
Hi friend, thank you for your inquiry!
I understand that you are receiving a "remove racks" message on your Electrolux range. The oven racks and supports must be removed before the self-clean will initiate or the control will not allow the self-clean to turn on. I hope this is helpful. -Matt
Sep 04, 2014 | Electrolux Kitchen Ranges
Electrolux Icon range won't self clean - "Remove Racks" displayed
Good Morning Friend,
I understand you are unable to self-clean your Electrolux Icon range, model# E30SO75ESS, due to it stating "Remove Racks", when you already have. Please follow these instructions for cleaning your oven:
1. Remove the turntable from the oven before the Refresh Cycle. No food should be in the oven.
2. The Refresh Cycle is 30 minutes.
3. During the Refresh Cycle some smoke and odor may occur. Open a window or use the ventilation fan in the room.
If this does not help, I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try the "Refresh cycle". I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Icon Oven self cleaning won't start- the lock button keeps flashing. Yes, the racks and rack holders are removed.
Good Afternoon Friend,
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
    1) Place the rack holders and the racks in your oven.
    2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
    3) Restore power.
    4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
    5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
    6) Take the racks and rack holders out and start the self-clean cycle again.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
    -Best Regards-
    WP
May 18, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux icon duel fuel range racks red light wont stop flashing even though I removed all racks, so oven will not start self clean cycle
Good Morning Andrea,
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
-Best Regards-
WP
Mar 23, 2014 | Electrolux Icon E30df74gps 30" Pro-style...
I removed all the racks from my upper oven (including the side racks) to self-clean and am getting the "remove racks" light. I've cleaned the oven before and never had this happen. The...
There is a button on the top receiver bracket on the left side... when you take the rack support bracket out you will see it. Take a damp sponge and go over that area, pressing the plunger/button in several times. That should do it. Sometimes grease build up can prevent the button from popping out all the way, so the oven thinks that the racks are still in there.
Aug 21, 2011 | Electrolux ICON Designer E30SO75ESS Oven
Trying to set it to clean, but it keeps saying remove racks even though the racks are out.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 11, 2010 | Electrolux 30" Self-Cleaning Slide-In...
Nov 01, 2008 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux 30" Self-Cleaning Slide-In Double Oven Electric Convection Range - White Logo
621 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
