Question about KitchenAid KSB560WH 5-Speed Blender
How to know a NEW from the old polycarbonate jug\pitcher that cracks near blades.
KitchenAid KSB560 Custom Blender. ConsumerSearch reports the polycarbonate jug\pitcher cracks near the blades then leaks. A KitchenAid Customer Service rep says the NEW model has fixed this problem. I am about to purchase this model. Q: How do I tell whether the particular model contains the NEW jug\pitcher ? Q: Is there a CODE to look for ? Thanks.
  • 145 Answers
The "code" you are seeking is found in the serial number, which has a specific way of noting when the unit is manufactured.
Buy with confidence and hang on to your dated sales receipt. If the blender leaks, take advantage of Kitchenaid's 1 Year warranty by calling into Kitchenaid Customer Service.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
Kitchenaide blender pitcher blade assembly sticks
You need to lock the blades from turning and undo the bottom clutch drive in such a way as you do not damage it. I use an old motor clutch drive to undo them myself. It has a left hand thread and a block of wood to hold the blade. Then you can remove the blade with shaft from the brass bush to clean and lubricate it. If the brass bush has moved up in the plastic housing you need to press/bang it down again. Then reassemble. If you wreck the clutch drive on the blade you will need to buy a new blade assy if it is separate to the beaker, if not you will need a beaker and blade unit complete.
Jun 23, 2014 | KitchenAid KSB560 5 Speed Blender
Blender won't start
Test motor for continuity, if open circuit locate thermal fuse in windings and replace it. If not open circuit check cable for continuity, if that is ok you are likely looking at a new button control assembly.
Mar 12, 2014 | KitchenAid Kitchen Aid KSB560 5 Speed...
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
How to open Kitchenaid KSB560OB to replace motor
Undo the 4 screws at the bottom. Before you do that though remove the clutch/motor drive. You cannot take the motor out with that still fitted.
Jul 22, 2012 | KitchenAid Blender KSB560OB 5-Speed Onyx...
Kitchenaid blender model # KSB565OB0 is leaking from the bottom. I have taken it apart to try and find the problem. The gasket is fine and the pitcher attaches and locks but it still leaks everytime we...
Check for cracks in the bottom of the glass.If it continues leaking then the gasket is compressed and no matter if it visually looks good, cause it has lost their sealant skills. Replace the gasket
Jun 28, 2011 | KitchenAid KSB560 5 Speed Blender
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
My blender is leaking slightly from underneath the blade. Is there a way to tighten the blade coupling?
I am guessing you have a KSB52. If the leak is through the blade spindle then tightening won't help. The "wingnut" is tightened through use anyway. The most likely cause is a failed seal. The whole blade unit will need replacing, search Amazon for 9704291
May 04, 2011 | KitchenAid KSB560 5 Speed Blender
We own a kitchen aide blender and it has started to leak. This jar does not come apart. do we need to replace the jar?
The Instruction & Recipe booklet for the Kitchen Aid KSB550, KSB560, KSB570, KSB580 5-speed Blender can be found here:
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209709225.pdf
There is no infomration to suggest that the blender blade could be removed for replacement of a seal
On page 27 of the pdf (page 24 if printed) there is contact information for ordering replacement parts. You might ask if the blade assemly can be ordered and replaced separtely but I believe you must replace trhe blender jar and blade unit as one piece.
Mar 13, 2011 | KitchenAid KSB560 5 Speed Blender
KitchenAid KSB560WH 5-Speed Blender Logo
991 people viewed this question
Top KitchenAid Blenders Experts
Appliance engineer
eyecam
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
