Home | Toshiba | Satellite A300-ST6511 PC Notebook | Error with operating sys...
Toshiba Satellite A300-ST6511  PC Notebook
Problem for Toshiba Satellite A300-ST6511 PC Notebook
Error with operating system
By yokhead on May 24, 2009
i have toshiba a300, and i have a message saying error loading operating system. f8 doesn't work to start up safe mode. how else can i get in to recover my operating system
Comments:
May 24, 2009
- so i did that but the same result. i was just wondering is there another way into advanced mode (f8) other than f8. someone mentioned holding zero while i power on but doesn't seem to work.
Best Solution
posted on May 24, 2009
Helpful)
robnok
Rank: Wiz
Rating: 79%, 110 votes
unplug everything. take out Your hard drive. put Your hard drive back in plug everything back in and try again. That is what is called a hard boot. If that doesn't work then You hard drive is junk. You will need a new one. Hope that helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on May 25, 2009
Not Rated)
Bat1956
Rank: Guru
Rating: 90%, 292 votes
If you are unable to get any repair utilities to work, you may be able to retrieve files that you want to save from your hard disk by using a live Linux system. See http://www.iso.linuxquestions.org there are many distributions available, one of the best for this is Knoppix. Another good one is Sabayon. They will run live from the CD or DVD, and allow you to browse the hard drive and copy files to USB removable media provided the drive is readable at all.
Was this helpful?
Yes
No
Solution #3
Not Rated)
yogeshtri_14
Rank: Guide
Rating: 0%, 0 votes
insert a bootable disc of ur operating system n use REPAIR option.......
this will repair ur os without harming your personal data
if you wish you can also format it and reinstall ur os but this will install a clean copy deleating ur previous settings and data of ur main drive
Was this helpful?
Yes
No
Solution #4
Not Rated)
fougzki
Rank: Wiz
Rating: 85%, 276 votes
Ok if it have a restore disk better to use it. The sign means it cannot see a operating system to load. It maybe the hard drive is out or the files is corrupted.
And also check your cdrom drive, sdcard reader slot or usb drive for pen drive. Maybe a cd disk is inserted, memory card, or usb flash drive is connected.
Ok to be sure if it is not the hard drive goto bios menu check if the harddrive is detected, If detected then maybe its files is corrupted.
You can choose for the best first, repair or restore disk or reformat and install. Depends on the features of your laptop.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A300-ST6511
Questions and Unsolved Problems for Toshiba Satellite A300-ST6511
Do you recommend Toshiba Satellite A300-ST6511 PC Notebook?
Answer
Answer
i cannot install graphic driver for my benq Q41 Joybook
Answer
asuss A6R laptop lcd does not work
Answer
blank white page popping up not letting me go any further. In front of my home page or a game im... (More)
Answer
i have a toshiba laptopi dont know well about pc in my start using period i format my pc for solve... (More)
Answer
I have a Toshiba Satelite A300 Laptop and until recently the Fingerprint reader worked fine.... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite A300-ST6511 ...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 482
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
