Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-32HS510 Red Standby Light Blinks 6 times (repeatedly with small interval between each cycle of 6). I try to turn TV on; it begins to come on (as second or so) but then sh
Sony FD Trinitron WEGA KV-32HS510 Red Standby Light Blinks 6 times (repeatedly with small interval between each cycle of 6). I try to turn TV on; it begins to come on (as second or so) but then shuts off. I see that other people have logged/ reported same issue. Any ideas? The manual says it probably needs service.
3 Suggested Answers
SOURCE: Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Posted on Dec 01, 2008
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Turn on my Sony FD Trinitron WEGA KV-32HS510 32" TV, you hear a click, and then it blinks 3 times pauses and repeats.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672. This is the fault with 3 blinks. If you wish to get more, check the site linked here.http://electronicshelponline.blogspot.com/ Pull up previous posts, either by brand search, or view it in Mosaic / Timeslide / Flipcard option.
Aug 18, 2013 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony wega kv-32hs510
place blow dryer on heat setting to rear of tv and try to turn on set after 5 mins...humidity sensor in board
Sep 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Jul 11, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Jan 19, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
302 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
