Question about Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner
Toro mower is blowing 30 amp fuse
Is the pto on a lawnmower engaged all the time the mower blade is running? I guess what I am asking, Is the coil on the pto energized with 12 volts dc the entire time the blade is running. thank you for an answer, Bill
  • 376 Answers
Yes it is. It is an electro-magnetic device that 'grabs' your blade pulley, that normally free wheels, to turn your blades when there's power to it. Dwain
Posted on May 24, 2009
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
Why my blade wont engage on my toro 74370 zeroturn mower
it has an electromagnetic clutch switch on it,that is more than likely bad. Try this,pull the pto switch out and start the engine,then disconnect the 2 wires coming from the switch and just tap them together and see if they will come on. If they do then you need to replace that switch.
Jul 27, 2014 | Toro Lawnmower 20099 Mower Mowers Lawn
John Deere 265 replaced pto switch on dash pto drive belt and mower deck belt still pto does not engage...also randomly blows 20 amp fuse from time to time when pto would engage previously...checked...
The electrical is part of the PTO clutch assembly. It should only draw 5-7 amps. Ohm reading is somewhere between 1.7 to 2.5 ohms.
These coils do short from anywhere from a partial short to completely.
Jul 26, 2014 | Garden
Cant get the switch to acctavate the mower deck on a cub cadet lawnmower
Check the fuse, tan/blue wire coming off ig switch or tan coming off PTO sw.
If it keeps blowing, check wire going to PTO unit for shorts or defective connection to PTO.
Apr 16, 2014 | Cub Cadet Garden
Toro repair manuals
I have this same problem on my 36 in toro pro line sfs i ohmed the clutch the wire the safety switches and the PTO engagement switch all checked out good if u find any thing let me know the clutch its a adjustable clutch and its supposed to be set at .018 at all three springs there will b a slot that's where u check that but. U can get a multimeter and test the clutch by putting it on ohms and hooking up on both sided of the plug once u have unplugged it.the clutch should ohm out at like .003 or .004 max if more the clutch is shorted out
May 07, 2013 | Toro 52" Cut Wide Area Walk Behind Lawn...
Huysky 25 horse honda gt belw a 30A fuse replaced now pto wont engage. suggestions?
unplug the clutch and see if it blows a new fuse if not pull the clutch off and check for bare wires that may have rubbed against metal
May 18, 2012 | Garden
Cub Cadet 1861 amp light comes on when the PTO is engaged and after mowing for a short time the PTO disengages and now the 30 amp fuse blows and stops the engine
Sounds like you have a short circuit, either in the PTO clutch, or in the wiring that goes to it. Inspect the wiring for any obvious spots where insulation has rubbed off or burned. Also look at the wiring at the back of the PTO engagement switch for these signs. Before buying an expensive PTO clutch, unplug its connector. Drive around with the PTO switch on (even though the PTO won't activate and the blades won't be engaged). If the fuse doesn't blow, the problem must be within the PTO clutch. If the fuse still blows, it must be in the PTO switch or the wiring from there to the clutch. Use an ohmmeter to trace and find the short. Good luck!
Jul 09, 2010 | Oregon Scientific Electric PTO Clutch for...
Starts and runs good but after an hour of cutting when you turn off.. then you want to cut again it will start just fine but when you engage the blades the fuse blows it has a 20 amp fuse is this the right...
I normally see 30 amp fuses to the deck...but it depends on which mower you have. If you place a larger fuse and it does take a 20 amp..you may burn something up. I would check the blades, spindle towers and clean all the stuff on top and inside the deck to look for something catching on the blades. www.nnyparts.com
May 27, 2010 | Garden
I have a Husqvarna Yth 180, the lawn mower shut off when I engage the blades to cut grass. I blows the 20 amp fuse near the wire harness
try unplugging the pto then start the mower next engage the blades and see if the fuse blows if it does the problem lies in the mowers wiring if not the problem lies in the pto. hope this helps
Jul 13, 2009 | Husqvarna Garden
Oregon Scientific Electric PTO Clutch for Cub Cadet, MTD and Warner Logo
514 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
